Real UltraFires are not really budget, more like a Black Shadow or Solar Force level of pricing and supposed quality. Couple of years ago, someone here posted about the real UltraFire branded Small Sun T08 look-alike, but it cost about $50-$60, while the T08 was like $25-$30. Externally they looked the same, but internally night and day - much higher quality machining and parts in the UltraFire.
I’ve bought a few of the 501b hosts on FT and they are cheap quality. Lens is ultra (pun not intended) thin and the switch is a joke, I do think they’re worth $5 though. I don’t know if it’s a fake or not as I just assume that Ultrafire makes cheap crap too. I also got an old gen 504b that is basically Solarforce L2 quality, it’s a tank. And Ultrafire’s websites are a complete joke, I can’t take anything on them seriously. Have they sold one flashlight yet in their precious official store? Interesting nevertheless that BG completely removed all Ultrafire from the shop. Will be fun to see if they return and what they cost if that happens.
Looks that way - Meco is the new no-name name, but they don't have the ZY-T11 clone yet. I got in the one from DX and it's a good one - nice alum. reflector, lock-out on tail thread, etc. Wai'tn on BG though - they should have a better price.
Hey Tom, did you get the Roche LS01 yet? If so is it any good for modding? Like not glued at least and alu reflector. For such a big host it’s very cheap.
Don’t think he sells them anymore, kind of a pity. It was a good quality host. Got 1 of the hosts running an DD MTG-2. Was quite happy with the outcome.
Looks the same yes @ less than Simon had the host for. Think the host was just over $18. I’ll have to check mine, but I can remember the lens was quite hazy, as shown in the above link. Got it cleaned eventually. An AR lens would be great, but to find budget ones (around $3 a piece) in this size is a bit of a pain. Thanks for the link.
Thanks MRsDNF. I almost can’t believe it. I might have missed this, but I doubt if mine has an AR lens… I’ll look closely later today at mine. Where did you buy yours?
Hi Werner. I’d try to stick with OP reflectors for XHP. I hate any form of that dark center spot and its really a pain with SMO reflectors. I believe this reflector is too small for a proper XHP-50 ‘Thrower’.
Does anyone maybe have proper modded lux figures for XM-L2 in this light? Would be interesting to see how this compares to the Maxtoch’s (M24 & 2X). The reflector is quite a bit smaller.
Mine came from the link above. I bought three as they were very cheap. I've had a few looks at the lens to double check if it is AR and it definitely has a very slight blue reflective tinge to it.
Edit. The Banggood link. Don't you love that name.
Edit two. I've just stuck a couple of protected batteries in this light and the tailcap will not screw on fully. Even with the brass pill on the spring removed it still does not do all the way up. There is about 4mm gap before the tailcap will screw all the way on with 70mm long batteries installed. It has mode memory and the reflector has a slight haze to it. Tailcap current draw on high is around 1 amp on high, .5 amp med and .12 amp on low.
