Deal alerts for Banggood.com - BTU Shocker, SolarStorm, Olight, XinTD...
2 x NCR 18650B 3400mAH 18650 3.7 V Lithium Battery for $13.50 in the Flash sale. Ends in about 4 days
2 X 3.7V 3400mAh 18650 battery for Panasonic (non Protected version)
2 x 18650B 3400mAH - My AFF Link / 2 x 18650B 3400mAH - Non Aff Link
I wonder if the new brand may be Meco?
There’s a bunch of them at BG.
Looks that way - Meco is the new no-name name, but they don't have the ZY-T11 clone yet. I got in the one from DX and it's a good one - nice alum. reflector, lock-out on tail thread, etc. Wai'tn on BG though - they should have a better price.
Hey Tom, did you get the Roche LS01 yet? If so is it any good for modding? Like not glued at least and alu reflector. For such a big host it’s very cheap.
It’s great for modding, once you get past the glue. It’s easier to just get the host from Simon’s Ali store
I always wanted a UltraFire UF-T60 because it’s set up for 2S for a easy MT-G2 mod.
http://www.ultrafire-shop.net/UltraFire_Shop.php?view=productPage&product=126&category=10
But when you compare that to the price of the Small Sun ZY-T08.
Don’t think he sells them anymore, kind of a pity. It was a good quality host. Got 1 of the hosts running an DD MTG-2. Was quite happy with the outcome.
It appears to be this light.
http://www.banggood.com/Rocher-LS01-CREE-XM-L2-1A-900lm-Tactical-LED-Flashlight-p-937607.html
Looks the same yes @ less than Simon had the host for. Think the host was just over $18. I’ll have to check mine, but I can remember the lens was quite hazy, as shown in the above link. Got it cleaned eventually. An AR lens would be great, but to find budget ones (around $3 a piece) in this size is a bit of a pain. Thanks for the link.
I'm looking at one now and it has an AR lens standard. It has a slight blue tinge to it.
Thanks MRsDNF. I almost can’t believe it. I might have missed this, but I doubt if mine has an AR lens… I’ll look closely later today at mine. Where did you buy yours?
Which size does the reflector have? Is it like a zyt13 or t08? Or smaller?
I always wanted to try a xhp50 and I guess this would make a quick mod but I am unsure how well the reflector throws in stock form…
Smaller.
Hi Werner. I’d try to stick with OP reflectors for XHP. I hate any form of that dark center spot and its really a pain with SMO reflectors. I believe this reflector is too small for a proper XHP-50 ‘Thrower’.
Does anyone maybe have proper modded lux figures for XM-L2 in this light? Would be interesting to see how this compares to the Maxtoch’s (M24 & 2X). The reflector is quite a bit smaller.
I thought there were deals here in this thread :frowning:
Yes that’s the one. It’s very big (heavy at least) and cheap but if it’s glued I might get something else instead.
Price lowered on: A multi-color copycat on Xiaomi ‘miLED’ LED USB 1.2W Light for just $0.99 / NON-REF /
Mine came from the link above. I bought three as they were very cheap. I've had a few looks at the lens to double check if it is AR and it definitely has a very slight blue reflective tinge to it.
Edit. The Banggood link. Don't you love that name.
Edit two. I've just stuck a couple of protected batteries in this light and the tailcap will not screw on fully. Even with the brass pill on the spring removed it still does not do all the way up. There is about 4mm gap before the tailcap will screw all the way on with 70mm long batteries installed. It has mode memory and the reflector has a slight haze to it. Tailcap current draw on high is around 1 amp on high, .5 amp med and .12 amp on low.
30-PCS only sale: ‘A zoomer’ CREE XPE-Q5 LED Flashlight 1xAA/14500 for $1.45 / NON-REF /
2 x NCR18650B 3400mAh Protected Rechargeable Lithium Battery / Not aff link: here US$15.95 (valid next 4 days)
If you are planning a gift for dear person that is also flashlight noob this are the best cells to give.
