Yes, it is two cells. With AA/AAA it is often 4 cells, but that is only to get a picture of the package.
With unusual battery sizes I either has to make new test scripts or process them the same ways as a already defined size, for the above it would probably be fine to run them the same way as C cells.
These are very good at 4A they beat hands down the EFEST V1 14500 on my sample, as you stated in one post they are the same as yours windyfire, capacity it’s almost constant from 0.5A to 4A, i could not make a constant current discharge over this value, as I’m blocked by the 20W max discharge dissipating power of my charger
I have tested them, with my REAKTOR and they are very very good, if you wish I could publish some graphs
With those efest 26650 , capacity is well below their ratings(in my samples), even at low amps, If I recall correctly the 4200 it’s like about 3800mAh, and the 5200, has the same percentage of mismatched capacity
… if I have still the data of the fresh cells lying arond on my hard drive, I’ll publish it.
I've quoted my original OP below; I think many of us would be interested in a teardown of the quality and effectiveness of the retro-fitted protection circuits, as much as the cell efficiencies.
There is a lovely thread I found here by RMM of Mtn Electronics, for the protection circuits used by Keeppower (widely considered the gold-standard of Protected 18650 cells), https://budgetlightforum.com/t/-/22519
This is a teardown with pictures of the Panasonic NCR18650B cell as wrapped by Keeppower and EVVA; with the inclusion of their Seiko protection circuits and button-tops.
It would be great to see something similar with these 'stock' unbranded re-wraps, as obviously not all protections are made equal...
Even if the used chip is good, it do not necessary make the protection good. Each chip exist in lot of models, each with slightly different parameters and only some fits a typical LiIon cell.
You could take a chip with one parameter set and it would be very good for a 3 transistor driver, but the same chip with another parameter set would not be good for 3 transistor, only for 1 transistor.
+1 on the Soshine 26650 5500mAh, they seem really good from n10sivern’s test of them. If you could i would be very interested in the performance both with the protection & with the protection removed.
And @ DX you can find them much cheaper than that https://www.msitc-shop.com, that was just ridiculous expensive for a single 26650 battery………
And +1 on the green Efest 26650 4200mha battery, Mitko’s testhas indicated that it is possible the strongest in single 18650/26650 batteries 5-7A flashlight applications of any high drain battery with a DD driver & full round of low resistance mods and even stronger than the Efest purple 26650 4200mha & Efest purple 26650 3800mha.
I don’t want to miss out on any of your future tests, so wonder if you maybe could have a mailing list or something similar, so we can get a heads up when you have published new tests.
