I do agree and because I saw the earlier discussion about it I have already ordered it.
Because you posted it, somebody else is probably going to publish it the charger thread and I will have to answer again (Sorry, but I would like to get the request in the relevant threads).
Perhaps you should put links in the OP to your other review request threads. Help direct people to the right thread. Someone may stumble upon one of your review request threads just because it popped up in BLF recent threads and they may not realize there are separate thread for other requests.
This is also very new, I wanted some way to keep a list of requests and asked the owner of this board if I could do it here and he said yes (A big "thank you" to him for that).
I do hope it is going to work and people do not get to impatient. I have probably got work for a month in one day and this does not cover the request I get from elsewhere (Like dealers/manufactures contacting me for reviews).
I will try to be very open with what I directly order, what I definitely want to test and what I will keep on the list for a period with few requests.
Hi HKJ,I would like to request a test on the MKNE 26650 3.5Ah available at Fasttech.The reason is that I suspect it is MKNE cells under various rewrap brands in the 26650 size high drain category like Keeppower and Efest ,but it would be good to have the data on the base cell if that is the case.I have a pair of these cells and they have lower internal resistance than the 4 King Kong ICR 4.0Ah cells that I compared them to.
I think mine took 2 months to arrive via Netherlands post. Patience is a virtue
It has been reviewed as a rewrap. This list is good to check specific cells: http://lygte-info.dk/review/batteries2012/batteryIndexUnprotected%20UK.html
Hi,thanks you old friend .keep in touch.
Thank you for your recognition except the 18350 700mAh and 18650 2500mAh ,we also have new product 26650 3500mAh battery .
