FWIW, you can probably fix your CMG Infinity by hitting it with a hammer.
Seriously.
Get a straight slot screwdriver, place it strategically by the threads around the driver, and tap it with a hammer. Here’s how it looks after four taps:
The issue is that the driver loses contact with the body, and by deforming the body a bit you can restore contact. Quick, easy fix, and then it’ll probably perform as it was originally intended.
OTOH, mine was only about a lumen of light and had a tint of like 8500K. It was cool fifteen years ago, but now I just don’t really care about a lousy blue lumen, even if it’s bulletproof.
That is probably what happened to mine… It is long gone now. Nice work on yours, if only this forum had been around back then…. I agree on the output, mine was at the most a couple of lumen, but it beat lighting a candle or the heavy incandescent lights of the time for what I wanted. It and a spare AA would have given a week of light all night, spectacular for the time. I used mine for about a year before it just gave up the ghost, maybe three AA’s digested by it.
How hard do you think it’d be to replace that LED? I’m thinking my favorite PC Amber Rebel, if I can get a 10mm Sinkpad in for that (not sure I can find that size for the Rebel, yet)
The “pill” and LED are one unit, so it looks like the entire assembly has to be replaced. When I have time, I will cut the old pill apart to see what is in there. For a rebuild, I am kicking around a joule thief idea, perhaps with a UV LED, just ideas at this stage…
Huh, so it’s just a section of tubing with everything “potted” making it a solid lump, you can’t pry out the board the LED is on, nor the board the spring is on, to get inside that thing?
So any piece of plumbing copper might replace that whole pill?
If you are done with your CMG infinity, then you can put it into a galvanized pipe nipple with two hand tightened, threaded caps (CMG wrapped in plastic before inserting), or in a piece of 3/4” copper pipe with two caps, to make it a EMP protected, last ditch flashlight. Even if you aren’t much interested in such a thing, at $2.00 or so for parts, it is still worth considering as a bullet proof storage holster.
Already have a dozen AAA lights but could not resist pulling the trigger after reading your review.
With some support from M4D M4X’s deals page (at the end of OP) the damage was only EURO 4.19
After 4h 43min I got a mail from Banggood that my order was shipped.
Now I only have to beat my wife in the race to the frontdoor.
LOL, thanks on the review compliment, sorry you have to race the missus to the door, but leave flowers if you lose….
It is a nice little light, try the scotchbtite trick to make it more floody if you don’t like the stock beam….
I like the way you think sir! Unfortunately the CMG was trash canned when it gave up the ghost, was not so handy with electronics back then… But I have a couple of Manker AAA’s sitting around…
Got one of these today, think I paid like 5 bucks, cant beat that.
How are you guys getting the “pill” out? I hope its not threaded in, since there arent any holes to stick plyers in.
Would like to do the mods you guys have done to it.
Light output is nice, but if I can get rid of a bit of the blueish hotspot it would be great.
I use the end of a sharpie or other marker similar to the sharpie. I then take just the head, and put it on a flat surface. Press the end of the sharpie as squarely on the top of the LED, then just press until it pops. I have had about a dozen of these, maybe half needed this kind of pressure.
Once the pill has started out, take the head in your hand and press it the rest of the way out using the sharpie or your finger. The best mod on this light is the scotchbrite/light sanding of the LED, it really whitens the light up.
Just the thumb did not work for me. Had to use a wooden plug and a small hammer since the pill was glued. But no worries, the led will survive the torture…
