LUMINTOP SD75 XHP70 4000 Lumens great price with GearBest -----------CLOSED -------------------
Damnnnn will it be able to push past 5000lumens with basic mods? The K50 is pushing 5k lumens! Attractive price btw! Time to save up!!!
oh my lanta…. :drool:
Maybe a BLF SD75 that with a copper DTP MCPCB and driven harder to get 5000K+? Asking for a driver to do 5-6 amps isn’t being unreasonable since it has automatic step down.
Well, thanks for taking this on. Hope you know what you are in for.
Lumintop has been down the road before, so they should know.
It would need to be a DTP Copper mcpcb for sure.
It would need to have a driver that will push more than 5 amps stock and be able to be modded past that, with a simple resistor change.
Well under $200. Seems like all the stock lights here at BLF, now are priced like CPF lights. Seems like budget is gone by the wayside here and everything good now sells over $200 in stock form.
PM me the price if you want. I would like to know. I will not be buying any lights, but I would like to know.
+1 thanks - but be careful not to burn out - the floodgates of PM/email is coming!
FWIW / FYI - the cheapest I have found the k60 is $145
Hi mate, also interested in price to decide if it’s something to raise to the top prioirty of my ever-expanding want-list!
Please kindly PM me too.
Many thanks, keep shining!
Interesting - PM sent.
Thank you!! Someone will have to help me add resistors because my soldering skills is really bad and I will destroy the pcb :frowning: That’s means I will have to ship the pcb out! I will include native snacks with the shipment! :wink:
Interested depending on price
Interested!
Yep, I’m interested! Interested also in seeing some distant beam shots, with that smooth reflector? It might be a challenge to contend with the K60 at the price jmpaul stated and also the K60 reflector
Interested depend on the price but it has rechargeable feature?
I hope not as bad as *ce*be*m
Will pm for price, is that a smooth reflector? I wonder how it compares to the K60…
Built in charging ! there should not be a problem because this is the system we have seen many times already with 2S2P 18650
Other then DTP on copper mcpcb is not even considered. Also I have ask them for confirmation that the driver will deliver at least 5A to the LED,because previous version of this light was with MT G2 and stated for 2100 lumens. They told me that new version
will have new driver with much more power !!!
Here is some video of this light with old version driver and MT G2 Q0 2100 lumen vs Fenix TK75 2900 lumen, so you can imagine 2X more light,and see the beam from that reflector……
I’ve seen the video and got a question,do i need to access the swith on the tail to turn it on?
Or just enough from the side switch?
Tail switch is only for powerbank function, and battery status. Side switch is the main for light, so tail switch can be turned on or off, doesent effect the light output.
Pm me
NEW!! XHP70 Flashlight - 4000 Lumens-Lumintop SD75 from Lumintop
