Nice work again, Mike :beer:
You are doing some great work with the driver development, & I'm sure a lot of people on here would like to utilize your creations.
Thanks. It was when writing this firmware I really took a liking to the dual switch approach, hence my thread asking for them. I’ve got an idea on how to use this seamless level selection on a 17mm driver with 8 x AMC7135s and a FET, and put it into a small triple XP-L HI. This is why I was interested in yours I’ve got an idea that’s a little different than yours but should work, the driver boards are designed and ordered.
Been thinking about this a little. Problem I’m currently having is that I always seem to have the next version on order before really finishing the existing version. Just when I think I can’t cramp anymore functionality in I come up with some must have feature that gets me all crazy. Like this seamless level thingy, once I started liking it I couldn’t stop myself and now have new driver boards for my triple M6, headlight project, 17 and 20mm drivers, all waiting for new firmware… the frenzy never ends.
Enjoy the hobby :beer:
Would you please link the PCBs?
This light is one of the lights I don’t have (yet) - and with this mod and a MT-G2 laying around here, this is even more interesting!
DO you know what the max. LED PCB Diameter could be? My MT-G2 sits on a 25mm copper disc.
Thank you!
Not quite ready to share this yet. Also, the MCU on it is the 12 pin ATtiny84, and I’m not quite ready to share that firmware either. Depending on what features you want I might be able to offer you one, depending on what functionality you want. I always get three boards from OSH Park and therefore have a few of each version left over . There is however someone waiting in line (who has been waiting for a long time) who gets first choice amongst the boards that I have left.
25mm MCPCB is what I have in mine and fits nicely, it’s the largest that will fit. The solder joints will interfere with the reflector, so they should be as low profile as possible and the reflector needs to be isolated so it doesn’t short the wires.
Thanks!
I only need the rear switch - I will use a zener modded Nanjg Driver
Thanks!
I really want to do a series conversion with a custom driver like this…
Is there a reliable source for quality T08’s? I know RMM stopped carrying them because the quality went way down.
I hear you. Gotta try out the new version with the FET first though.
I got mine ages ago, so I don’t know myself.
Light and driver has had a major overhaul… again… Details in OP, original post moved to #2 (yippee, I found use for that reserved post).
Do you have a link to the switch you used? I’ve been trying many things, but have yet to work out a good switch housing when adding an eswitch to a light.
Mike, please give your suggestions about copper pill design for this light.
Nice work! I have one and have a few ideas about it. The tail switch would break contact between the cells rather than between the host and 2B~~. Leave the existing contact board in the head as is and make a new oval one to fit in the head end of the battery tube with solder bumps on the top (both at 2B+ potential) and copper tabs at the ends to ground the host that get sandwiched between the head and battery tube. On the underside of this board are a B+ and B~~ contact. This way the rotation of the battery tube is irrelevant to polarity.
I knew you had reserved a post for a good reason
I’m not sure how I missed this one. Nice work. I’ve been playing with this light myself lately having made a couple with the batteries in series. Is there a link to Oshpark for the switch board?
Yeah, I’ve had some issues with that too. This is the switch I used for this light: http://www.newark.com/c-k-components/k12c12-5n/switch-1mm-travel-2-5n-ip67-seal/dp/58T4766
For smaller lights I did this: Mod: My take on the convoy S series with side switch mod.
Check the last photos, I ditched that switch that was taped to the outside.
I would definitely like a copper pill for this one, but the light I have is quite old and I’ve read here that the newer ones have declined in quality. Someone would have to confirm though. If the new ones suck it might be a waste of time making a copper pill for it.
I’ll have to make it a habit now, I’m hooked!
I had one shared before, but changed the design just a little later on… I’ve now shared it again: https://oshpark.com/shared_projects/gqQMuyMr
I have actually attempted something very similar. The tail switch I have already breaks contact with the cells, not the host, but earlier I designed plate to sit on top of the cells, and had changed the underside of the driver so rotation wasn’t and issue. However, fixing this plate was too much of a hassle, and as I use this down in dark abandoned mines I want to be able to replace the cells rather easily. I couldn’t get this solution to work smoothly so I switched back to the original design.
Here are my driver boards with the similar design as your suggestion (it was when I was using ATtiny84 for this driver):
Edit: The + and - signs on top of the battery plate are incorrect, + is the middle circle, - on the two outer.
Thanks Mike for the switch plate. I concur with the issues of alignment with the batteries to the driver board. I have resorted on my test light screwing the battery board to the battery housing which is a pain changing batteries.
