KD (kaidomain): Deals and new products thread
Hello BanL,
Can you tell me if you still have any of these 50mm coated lenses in stock? I believe this might be an old link, but it still works. But, I can’t find anything when doing a search on 50mm lens. Thank you.
http://www.kaidomain.com/product/details.S004327
Hi Willy,
SKU 4327 is in stock. Thanks
Thanks for the code, BanL.
I got these drivers in record time! They are genuine NANJG 101-AK-A1 boards stuffed with 3x AMC7135’s
http://www.kaidomain.com/Product/Details.S009744
The modes are the still the classic setup. https://www.youtube.com/watch?v=CYC7SqvJ0pw
Not exactly according to the description on the site, but consistent with the video.
So in fact, it is a 17-mode driver with a 10 second beacon thrown in.
These are perfect for bicycle tail lights!
Thanks for your ordering and supporting to KD.
We would continue to bring the good driver to all of BLF members.
And we continue to improve KD.
Thanks
I noticed today that the “blf” code does not work for items that are on special.
Is it possible to buy the silver KD HAIII BUCKLE V6? Like 3 pcs to avail of the bulk pricing. Thanks in advance for your help.
I just added 3 of the olive ones to my cart and applied the bulk discount and BLF coupon. The result was a total cost of $11.82 for all 3 posted, which works out as $3.94 each
Yeah I just ordered 3 olives for the same price as you and also 2 of the c8 3 mode which is on sale for $10. I want to order silver ones.
Olive is silver…. They have it mis labeled I think. Though it does have a very slight greenish tint… I mean slight…
If the Olive is closer to silver I’ll probably buy one myself soon as that’s my preferred color. I bought a Blue one months ago and I’m very pleased with it. Great value for such a good quality small torch. On 10440 it runs very nicely. I think this is one of the best deals around for anyone wanting a AAA/10440 size torch at a low price.
Good to hear the ones I ordered are the silver ones. Looking forward to these lights. Where can I get decent 10440 batteries?
I received a pair of Ultrafire 10440’s years ago (5+) as a free gift on a purchase on Dealsextreme if i remember correctly and only used them recently for the KD Buckle and found they were still working after all those years.
I found a similar set on Fasttech
https://www.fasttech.com/products/1420/10000930/1078100-ultrafire-10440-3-6v-600mah-rechargeable-li-ion
These should be ok, there are probably better around. Mine provide 25 minutes of runtime.
thanks rolz, will check them out.
Those have been fine for me too, but I can’t say I use them a lot. I’ve had them for years without any issues though.
The EFEST 10440's are far better - mtnelectronics.com EFEST. RMM shows the HKJ's comparisons, comparator here: http://lygte-info.dk/review/batteries2012/CommonSmallcomparator.php. The UltraFire's in capacity, stay with the EFEST up til 0.5A, but higher, the UltraFire's fade away.... I still have a bunch of UltraFire's, but really prefer the EFEST's. There's not much choice out there though.
That doesn’t surprise me at all. I would get the efests without a second thought if I needed some new ones. Good link and info.
What is a good charger for these? I am using a nitecore I4
That's always a problem with these very low capacity cells. The best charger is one with a 200-250 mA charge rate. The UltraFire's, even though they say 600 mAh are actually about 350 mAh, so normally you want to charge at or below 1/2 the capacity (0.5C), though some say up to 1C.
I use the OPUS BT-3100 for these now, but the XTAR MC0 looks like a nice quality, cheap charger for this: mtnelectronics MC0 for $5.90. Also the "VP" series of XTAR's Richard sells will work fine. Richard is listing these chargers the right way - he won't say a charger supports 10440's unless it supports a low enough level. Others advertise chargers supporting 10440's just because they can physycally fit -- big difference...
Thanks Tom E, I already ordered the MC0 from gearbest as they have a sale going on. Will order the efest batteries from mtnelectronics.
If you have a charger that can charge LiFePO4, I have been using the Soshine LiFePO4 AAA’s in my buckle with a good increase in brightness over Alkaline. Not as much as a 10440, but runs cooler too… Just an idea.
