Any chance you would do some LiFePO4 batteries of any sizes HKJ? I have an 18650 and AAA size ones that are doing fine by me. Albeit with shorter run time, and somewhat less output on Turbo (DD). I know on paper these are not that appealing…
An interesting new SKILHUNT 26650 5500mha Protected At Banggood
I wonder if SKILHUNT is one of the fakers when it comes to capacity or if they are one of the honest manufacturers.
I have a few FASTTECH links to the LiFePO4 batteries in 18650, 16340AAA and AA sizes for you to test if you have the time.
I am mainly interested if they live up to the MAH claims and how they hold up during high loads. I do not know if you have a way of testing their supposedly higher recharge rates either.
Thanks and if you have too much already on your plate, no problems.
I just hope, somehow, you could put the latest state-of-the-art 18650's to the top of the queue. These are the cells, I think, that are of most interest in which we have no test results on. In this vein, it would be much better to test the original cell brand, not the re-wraps that are so common - obviously this is getting harder and harder to figure out though. But if you stay with the latest offerings from Sanyo (GA), Samsung (30Q) and LG (HG2), that would be a great start. Also it's both selfish and thinking of you -- rewraps are sort of a waste of your precious time and energy.
Right now, we have a slew of high performance cells coming out at 3000 mAh, and moderate performance ones at 3500 mAh - these are the ones.
BangGood got a notification from UltraFire to stop using their name, so MECO is the brand name they are using in place of UltraFire. That's the word I got from a BangGood rep. One day I noticed all UltraFire brands dropped from the BG site, so I asked. I was hoping they would bring back the UltraFire ZY-T11 clone under MECO branding, but it's not there, yet.
I sure wouldn't trust the MECO brand cells, same as not trusting UltraFire cells (real capacity, charge cycles, etc.).
Both the 3500mAh LiNiCoAl and the 3000mAh LiNiCoMn are pushed by the major brands at the moment and it would be very nice to compare GA, BL, MJ1 and 35E, as well as HG2 and 30Q with each other and its predecessors.
We all know that rewrappers often use these cells, but we never can be sure which it is and which one it will be in the future - as they are also known to bait and switch. Buying the Panasonic/Sanyo, LG or Samsung cells (from a reputable source) gives so much more value. There are only a few tests missing. Perhaps you could adapt your queue, slightly…
Well, I truly don’t mind. But as of today even dampfakkus.de does not yet cover the GA, the MJ1 and the 30Q in the range of 2-5A.
And the HG2 was only added in the last 48 hours.
dampfakkus has a big advantage compared to me, they do not test at low currents and only test one cell! This means they can do their test in one or two day(s) and not one week as I need.
Can’t thank you enough for your thorough testing. That’s why I would never ask for a change in testing procedure - but I do second TomE’s motion for a tiny little shift in the queue.
And i have to chime in on the request for HKJ to put these new cell at the top of the queue. The real original cells from Samsung, LG & Sanyo/Panasonic needs to be tested before the rewraps if they are available.
