Yes, that’s the pic I found explaining series cells, but here’s a better explanation directly from LED4POWER
“1.Change 0402 750kOhm->0402 250kOhm on spring side,solder jumper is number 2!
2.Change shunt from 1mOhm->2mOhm
3.Change max. Current set resistor 0603 150kOhm->0603 180kOhm(or 225kOhm if you want 2A).”
This sets up the LD2 to make the correct power level through a change in the shunt as well as the sense resistor on the inside of the board, and a change in how the driver see’s the series stack on the outside of the board.
I have the required components on the way from Mouser. (hate it when I have to stop a build and wait for parts! I forget what I was doing!)
I've been seriously working on a small booster for about 4-5 days now. It is easy to copy a reference design and hook up a half-cocked constant-voltage single mode booster, but to make a full-fledged LED driver (constant current, modes, low voltage protection) it is much more involved.
Here are the issues with most high-powered boost converters that will actually fit on a small board:
You need to convert from constant voltage to constant current
While you can make CV kinda work, it isn't right for an LED load
Add current sense resistor which provides feedback instead of voltage divider
You need modes
Bias the feedback pin for modes if you want constant current
You can switch into different resistors for limited set modes (ala DQG Tiny 26650 boost driver) or;
You can use an opamp and RC/LC filter to convert the digital PWM to an analog voltage to bias the feedback pin
Otherwise you can use a parallel shunt FET (quick and dirty, but not optimal)
You need low voltage protection
You can use a uC or discrete voltage cutoff solution to pull enable pin low
Now, take all of that stuff and stick it onto 17mm board with a suitable inductor and keep it from overheating.
the driver poped when it went to high
the voltage regulator vaporized…
i converted a king clone to 4S using the original driver as contact plate and measured 16,4V at my plus and minus
hooked up the driver ( which worked when i tested it with a 12v primary (cell from a remote)
Could you send me PM with some pictures,to see what exactly happened?
MCP6H01 is rated as 16V opamp,17V absolute max. rating,so it shouldn't burn in theory.
(actually I picked this chip having 2s in mind,3s and 4s combinations are very rare for 17mm driver format;it's very hard to find high voltage IC in very small packages,there are very few higher voltage opamps in sc70 package,but they have high quiescent current).
How hard could it be to modify a SRKFET driver to run on 12v? If on board regulation of the components other than the FET could be done, it would be rather simple, right?
Something similar, maybe a little more sophisticated, to the Zener mod.
This regulator should be a good way to run the MCU on a DD driver. It requires a cap on input and on output. The data sheet says proper ESR is critical on the output cap. It says a resistor value of 500-mΩ to 1-Ω must be used in series with output cap for ceramic caps to simulate ESR. I have a few on the way to use in 4S buck drivers. I'll report how they work out, but I don't expect any problems.
I don't have exact figures because my sphere is not calibrated to measure this way, but here is some data I compiled today.
The main reason for the test was I really wanted to see where the dead fall for this emitter was. I found that I could drive it to 3.5A with no problem, but I still suspected this was too high.
My guess was that this is 4 XPE dies and from past tests I know that 2.2 is about the max per die for those. On the SC5 platform we did gain a hair over that but not what I was expecting. At 2.5A this one is completely tapped out.
This was done with a C4 bin high intensity.
Cree XHP-35
FC
volts
estimated lumens
1A
244
12.8
813
1.5A
327
13.4
1090
2A
381
13.9
1270
2.5A
411
14.5
1370
3A
408
15.1
1360
3.5A
336
16.2
1220
Again the lumen numbers may not be are not perfect, but the percentage of gain at higher current is going to be very close. This was also done on a sink that is better than in any flashlight, so that will be a consideration too.
I reflowed it to a copper bar, and set that inside a pan of water. Very effective.
Honestly I really cant say that I am impressed with this emitter. Granted if I had a top bin high density vs a 1 bind down high intensity the lumen output would have been a few hundred more.
I guess I should have read the data sheet more carefully before I got my hopes up with this.
Even if my numbers are a bit skewed ( they could be). I have de-domed U4 bin XML2s that are properly driven 4ish amps that out perform this emitter. Both higher lumens and equal or greater lux.
Great job VOB! Thanks for testing these. After playing around with cree’s characterization tool a few weeks ago and comparing with other emitters, I had a feeling these would turn out to be duds. But then, we would never know till someone quantified the results while overdriven for max lumens… something cree falls short of in providing data past its recommended maximums. Thanks again! :bigsmile:
There goes my plans for a 12 x 18650 BTU shocker mod with 3 XHP35’s.
VOB, thanks for tackling the extended current chart. I thought we had a good LED here your chart was a 1/3 less than the product chart how ever. One hope left the High Density top bin claim about 1 1/2 times greater out put than the LED bin you tested. Gains in current I think showed the trade off max at about 1.5 amps before gain really slows down. Still 20 watts is a lot to bleed out in a conventional light design. I still would like to see a single cell driver for these voltages as we still have the XHP-50 and 70.
According to CREE PTC we should have at 50Celsius - 1178umens, 12.58Vf for XHP35 HI C4 bin.
I would not be surprised if someone else would measure more than 1178 lumens at 1A, you know hose these things are.
Thermal resistance is phenomenal for this LED 1.8C/W, a bit weird to see such weak results when overdriven.
Can you measure the exact die size (even if there are like 4 dies in there)?
Ya, I'm a little disappointed too. As mentioned my sphere is not perfectly calibrated for this function, but they are going to be close with this emitter. I tested this in a light too for lux, and also did a visual side by side, which had the XML2 as the winner as well.
In ONE test I was able to squeak out slightly higher lux with the XHP35, but it was nothing major, and the reflectors were slightly different.
Yes, as fart as lumen output I would still expect this emitter to exceed an XML2 by a slight margin ( 200-400 lumens).
If I can get my hands on a couple of the very top bin high density I would be willing to take another swing at it.
Success! I fixed up the LD-2 like Neven said, put an 180KOhm sense resistor on it… mounted it to a large copper disc that then fit in my Maxtoch that came with an SST-50. (It’s unbranded, I’ll have to look up the model)
Running 4 Sanyo 18500 flat top lap pulls it does …
0.02A for 80.04 lumens
0.48A for 648.6 lumens
2.39A for 2018.25 lumens.
This is with the XHP-35. I messed up and went by the bond wires reflowing the emitter. BUZZ! Wrong answer!+ On this one, the bond wires go to the side, you have to go by the anode mark on the pads on the bottom of the LED+. I shorted it the first time, couldn’t figure it out so I searched the datasheet then double checked the physical emitter and sure enough, the first time I put the pads across the Noctigon.
Works, tickled to death, but have the 3 modes and I put moon components on it. Have a feeling there’s something I’ve forgotten…
