You are probably to young to remember the boombox and amplifier wars. Back then, you could buy a 1500 Watt Stereo system for $50!
There were terms like “Instantaneous Peak to Peak Power” etc.
Here is how the term “Instantaneous Peak to Peak Power” can be used (mathematically) to inflate power ratings.
Watts = E x I, but I = E/R so E x I can be expressed as E squared/ R
So say you had 100 volts AC across a 50 ohm resistor, the power would be 100x100/50 which calculates to 200 Watts.
But in AC voltage, the voltage varies as a Sine wave. That 100 Volts is an “RMS” value (sort of an average voltage) and actually hits peaks of about 1.4 times that. 140V at the peak. Now if you use THAT number to calculate the power you get 140x140/50 which NOW comes to 392 Watts!
But we are not done yet! AC voltage varies both plus and minus, so the difference from the peak plus voltage and the peak minus voltage is twice the 140, or 280 “peak to peak” Volts. Plug that number in and you now get 1568 WATTS
So, just by doing some math, they could now say 1568 Watts instead of what it actually is, 200 Watts.
Still not finished though. The term Instantaneous. The thought was that the output wave form could have spikes that peaked at over 140V, if only for an instant, so lets use that number. And on and on. So when the wattage was rated with the “Instantaneous Peak to Peak Power” method, they could use any number they wanted.
The lumens and mAh ratings from these guys follow a similar (dishonest) formula, I just never have bothered to try and figure it out.
And then there were the wattage ratings of speakers………………
This is already going on for a while: I just checked an ultracheap 'dive light' that I bought ages ago, can't find it back but it was somewhere in 2014, this is the led:
I was not too young to experience the time period that you mentioned. I was just not in the USA. (Probably as an electrician in a small town thanks to the cultural revolution initiated by Mao at that time. But that’s another story.)
As for the lumen and mAh justifications, I don’t think these people even bother to do that either. They just put the numbers on their product to catch people’s eyes and not many people will bother to check. Another thing I am puzzled about is: Even with such fake claims, where did they got so many positive reviews.
To another extreme, now I don’t trust any of the claims. That is why I would like to put my hands on some testing equipments that I can use to verify or dis-verify these claims. Battery capacities are easy. Lumens are more difficult.
Another discerning "feature" I've noticed is that most of the Cree LEDs silicone have a stippled or "orange peel" appearance on the flat part of the die. The RGBW Cree XM-Ls also have the stippled appearance like the XM-Ls. [After reading this, the next batch of LatticeBrights will probably also be stippled].
Interesting, i wonder how long the sellers have actually been sneaking these Cree fakes in under our noses before we finally caught on now to whats been happening.
I opened another flashlight, i.e., one of those “2000L Zoomable CREE XML-T6 LED 18650 Flashlight” flooding the market. Sure enough, it is a LatticeBright version 2.0. I am starting wondering if any of these with the name of Ultrafire on them are real Crees or they are all LBs.
It is not that bad actually except for a little lower light output. They should just mark as LB rather than Cree.
i found what appears to be a fake xp-e in one of my sk68 clones yesterday. i bought one of the gearbest camo-sk68 a while ago, and that horrible bluish tint had to go, so i de-domed it.
when i compared it to a couple of my other xp-e sk68 i was surprised. the de-domed focused led had only a slightly smaller hotspot than one of the others. when i looked closer the led looked like a xp-e but with a smaller die.
i thought that maybe it’s a xp-c then? but it had three strips and two bond wires, just like the xp-e but with a smaller die.
so after reading this thread a bit more and looking at other fakes i suppose this is a fake cree led, since the phosphor seems to extend outside the die, and the dome isn’t clear like the cree.
the tint isn’t good, can fake cree be de-domed as well?
Question is: XM-L2 are so well cloned that are indistinguishable from a real CREE XM-L2? I ask because all I see is these old generation emitters being discovered as fakes while LB clearly makes XM-L2 style clones.
What you are talking about, frustrated with, and experiencing disbelief over was exactly me as a newbie a few years ago, and then I found this forum.
They do put lots of fake reviews up, which can be bought for very cheap. But I don’t think most of them on many sites even need fake reviews.
I think the real reason is what I have tried to explain quite a few times, at least in Ebay and Amazon type sites goes like this…in shortened form: newbie buys a fake Cree “2000 lumen super bright!” (really 500 lumen XML2 T5 or LatticeBright) light with ultrafire “5000mAh” battery (really 1500mAh recycled battery) and goes to try it. Since his old light that he thought was bright is 150lumens, this new light outputting 500 lumens is incredible!! His run time from his Ultrafire batteries are really only 1500 mAh, but since the LED is only driven at 1.5A max, he can get a whole hour runtime, which to him seems reasonable. He probably doesnt even use it on max very long and probably doesnt use the flashlight often. He really doesn’t have much else to compare to except his old 150 lumen light, resulting in a really “AWESOME BRIGHT LIGHT” review and “REAL POWERFUL 5000mAh battery runs my light a long time!!” review for the battery.
To make matters worse, most flashlight users don’t run thier flashlights for very long anyways, some barely turn them on for 5 mins a couple times per year. He probably is also pretty used to batteries getting old and failing, and so he’ll never notice his batteries only would last 50 recharges and drop capacity the whole time. In fact he probably barely gets the light out and 1year later just tosses them and buys more “Ultrafire super power 6000mAh!” batteries next year, because, well they must be better! And then he writes a positive review for these too…
Repeat this pattern for most uneducated consumers and you get an avalanche of happy customer 5/5 star reviews on fake bad products.
On ebay, there is the addition of this “feature”: sellers will reward any complainer who recognizes they got a bad product with free items if they write a positive review, or don’t post/delete the bad review at least. Why not, Ultrafires are $.25 each, if the seller sends off 4 free batteries to replace the dead/bad batteries the buyer bought in the “$8 for 4 Super High Power Ultrafire 5000mAh!!” deal, he still makes money: $8 - supplies (.25x8=$2) - shipping ($2?) = $4
