Nichia 219C, testing a 5000K 83CRI emitter, comparing with a XP-G2 S4 2B and other leds
So where, how, and how much for these LED’s?
Henry, you know where to get them, stop playing games with us. :stuck_out_tongue: :beer:
Here’s some of what I was thinking about, when encompassing the “high” forward voltage changes we are seeing over time, and just general LEDs we are seeing as time moves ahead. It’s important to look at another industry to understand where I’m leading.
If you think about the core technology driving the common white phosphor-LED, most know what it is. I think just a grade of silicon semiconductor, just like Intel and AMD use to do processing with computer chips—with LED silicon arranged to do a much different type of work when made. If you think about the core “product” in these LEDs that can make them potent for throwing, then, it’s really not the phosphor, the bond wires, or the domes really; the “nuts and bolts” are the same between most of the MFGs. Manufacturers are capable from what we’ve seen, of making near identical components like those, and arranged how they want them. I would ask what it is that they (LED makers) cannot completely control, then, and again I think of the semiconductor.
Silicon semiconductor wafers are usually something a large company buys from another large company who specializes in the production of intricate, advanced semiconductor growth through advanced methods of stereo lithography types of production. The LED maker implements that final chip somehow into their product as they see fit, to do its job as they see fit, which includes handling heat dispersal methods. The silicon itself has much different standards than the rest of the LED, but likely similar in many.
It would not surprise me then, if some LED makers used the same exact silicon wafer material in their LEDs.
This is also why I brought up the ‘quantum wells’ looking similar, or the “holes” you see in an LED die surface now instead of line traces—between Cree and Nichia.
Have you ever heard of Moore’s Law? Take a look at computer processors of recent years. “(Moore’s Law)”:Moore's law - Wikipedia It’s not an actual law, but it, for the most part held true for a very long time as a ratio to product.
Then silicon makers started meeting the end of a dark tunnel; they were getting close to exceeding the trace limit width, defined in our physical world by the size of a few atoms. Talk of this started happening as far back as 2010. We cannot break this law, fundamental to nature, or make something smaller than an atom. Computer processors adapted, instead of increasing transistor count by making the chips smaller with more micro transistors and traces, they condensed more CPU chips into one piece of silicon, creating larger, multi-core processors, that weren’t actually smaller inside; the overall package and footprint remained the same. It was like taking a Prius car, and combining 4 of their engines, but still inside one Prius. :wink: The “engine technology” is there which is efficient and now, and power still grows. Oh well, Moore knew his ‘law’ had to have an end someday. :wink:
Someone mentioned on BLF the fact that chips have gotten bigger, brighter, but for this many years to go by, surface intensity has not increased exponentially above the old XR-Es we would likely have expected back then while predicting forward.
If you feel this same sort of parallelism between silicon makers, it tempts me to believe the LED world is running down that same tunnel. They can get the silicon to do a little better, and a little better some more, but to get the lumens they need, they went to mutli-chip use instead of driving up the intensity, regulated by the silicon semiconductor inside. I believe we will see LEDs stop at their current sizes, and possibly start to grow outward. This is even showing by Cree claiming new intensity, by simply applying little dome material. If they could, the dome would stay, and we would see those big intensity gains. The market isn’t calling for it. Efficient chips, with high L/W are needed.
My point with all this is not a great one, I just think it might offer some explanation as to why we are seeing things that make us flashlight users frown at times, like high Vf.
So unless everyone out there forgets about flood right now, starts buying aspherics, and showing what a sucker they are for big THROW, Cree simply isn’t going to pay any attention to us. Ha, if only… :bigsmile:
Whew. That’s a lot of words, MEM.
Here’s one picture:
Recent news from Intel shows Moore’s law to be stumbling and staggering a little.
On the other hand, Haitz’s law, which applies to LEDs, seems to be healthy.
Note the logarithmic scale on the vertical axis.
Great test and results djozz, great to see how far these new gen emitters can be driven, the new nichia certainly looks much improved and the xpg2 out put is impressive, thanks for posting, much appreciated.
I’ve been in contact with a company to buy 219C’s. I’ll probably be ordering them tomorrow, with extras to sell.
LEDs are not built out of traditional silicon. They use things like indium, gallium, nitride, with a sprinkle or two of stuff like phosphorus. Some LEDs use a silicon carbide base, others use a sapphire base or some other exotic material. There is a LOT of work going on to find a good way to build LEDs on cheap silicon substrates.
All of these materials are a lot harder to work with than pure silicon. The bare material wafers used to build LEDs are smaller than what is used in IC manufacturing. The performance/characteristics of the device are very sensitive to minute thingies in the atomic structure of the device… much more so than a silicon IC. This makes the manufacturing processes harder to control and harder to get consistent devices.
I thought I'd read somewhere here that they weren't going to be manufactured.
DBcustom had spoken to a Nichia representative who told him that the 90+ versions were not going to be produced, other CRI's like obviousky the 83CRI one of the OP, are (somewhere) on the market. Apart from Lumitronics, they are at Ledrise now (also Germany, same types as Lumitronics has).
The R8000 (Ra 80min) version? Tint? Any chance it’s R9050 (Ra 90, R9 50) instead? :heart_eyes:
bummer :frowning:
Thanks djozz. Yes thats what I read but couldn't remember the details.
What I plan to order is 20-50 of the following: Nichia NVSW219C 280lm white, 5000k, 83Ra. I’m debating the quantity because I don’t know what the interest level is for these on the forum. Every time I convince myself to just get 20 I find a bunch of excuses why I should order more.
Shipping is the killer, they don’t generally ship to the US, so I have to arrange shipping, and it’s not cheap. This is the main reason I keep thinking about a bigger order, to defray the cost of shipping.
I plan to grab some other LED’s as well. Some for playing around, some for builds.
If they have them in stock you could consider getting some of the 5000K 70 CRI 219C's, they should have 15% more output than the 83CRI version. With a sliced dome (hoping that that would come close to the effect of a full dedome) it should outthrow everything, even the XP-G2 S4 at 6A (which is not possible on a single battery).
They don’t appear to have the 70 CRI version.
Just got an estimate on shipping, $145. :_(
It’s not looking good, I’m not going to pay that much for shipping unless I’m really confident that people are going to be interested in these in the US at almost $10 each for bare emitters.
It doesn’t help that they quoted a package size of 10”x7”x2.5” and 3lbs. It’s hard to believe even 100 LED’s would take a box that big OR weight that much.
Maybe a European member could offer to forward the package?
Where do you plan to order?
Lumitronix was the plan. Even going down to a half pound only dropped shipping to $100.
I have bought some for blf members and am ok to do that again. For 10+ it is ~3.70dollar, 100+ 2.70dollar. Shipping is under 10 dollar.
I'm ok with it if I can send the lot to one person in the states, I'm not fond of sending multiple packages.
I’ll order some through you (a lot). Do you have to pay the VAT tax when ordering from them? I’ll PM you the order details and then PayPal you money.
I have NVSL219C inbound in 4000k 83RA but dont know what flux bin until they hit
