Nice job with the review.
Thanks. I’ll improve on my next attempt.
Thanks for the review Rolz. That must of been you flashing the light around last night I saw. It looks like a nice light.
Thank you very much for the work.
If I’ll buy a C8, will buy one like this, XP-L rulezzz! :bigsmile:
Hi
Thanks for the review now the HD2010 at 6A only 40 kcds? Something here is not right :~
Thanks guys for reading the review. I was happy to give it a go and I’ll produce a couple more in weeks to come. It’s interesting in working through some of the steps as I learnt more about the performance of the some of the other torches I have. I tend not to leave torches as stock but just changing out batteries can result in sizeable improvements in brightness. Based on the feedback I need to improve my light measuring techniques to be more accurate. I’ll look at another light meter and also test out more of my torches and compare the results to what others have measured.
Good job!
How did you test the lux @1m? Did you put the lux meter directly in the light spot? >20000 lux sounds high to me. How large is the light disk at 1m in your case?
The method of testing for lux was to initially use the Nitecore torch to gauge the accuracy of the setup. I placed the light sensor on the floor and then observed the reading when I pointed the torch centre spot at the sensor. At a height/spacing of approx 1.1m between the sensor and the torch head I read 9000 lux. This was my reference for the next readings. For each of the other measurements I included in the report all were taken with fresh batteries at the adjusted spacing of 1.1m. The readings that resulted varied so I took a typical figure not the peak nor the lower end. Earlier this morning I did a recheck again with fresh batteries (HE4) and reduced the spacing to 1m. The measured lux was about 55k, it peaked at around 61k. The spot size of the light beam at 1m was about 9-10cm
I think you should measure a minimum of 6 meters….
O.K. Thanks. I will try it once I receive my Convoy C8.
Do you know the KD C8 that you reviewed has reverse battery protection?
Appears not. I checked the Kaidomain site and it lists the following comment for the driver
Do not short circuit, do not reverse battery polarity, warranty does not cover user damage.
I’ll aim to do that tonight outdoors and see what I measure. I’ll also take out the HD2010.
9-10 cm is a very tight disk. I tried my WF502. It can get over 12000 lux for such a small disk, so it is possible to get larger readings with C8.
It doesn’t appear to be correct. I’ll re-test outdoors at 5-6m. I’ll do some checking to see what should be expected from a stock HD2010 5A+. Do you know what Lux reading I could expect
1m?
I’ll try a couple of batteries too. The actual measurement was 6.3A on the HD2010 which amazed me.
In a thower If you look at the beam pointing to the sky you’ll see that in the first meters in the center beam has no light in the central part, for that reason is the error in reading a few meters…
My HD2010 standart xml was around 48/50 kcd std 18650 (not INR)
I’ve measure the Lux @5m and found the KD C8 scores 1260 and the HD2010 1590. These translate to results similar to what I list in the table. Both torches perform very well outdoors with a nice spot light. Possibly my light meter. I need to explore further to work out whats wrong.
You get 31.5kcd by measuring at 5 meters? That is strange. :~
I think your lux meter is fine. I always use my cheapo HS1010 lux meter from Fasttech to measure my lights and the readings make sense (I made comparisons with other forum members here), and I believe your LX1010BS is even better than my HS1010.
You use HE4 and measured 55kcd at 1m, but when you measure it at 5m it is 31.5kcd, something seems to be not right to me…
Anyway thanks for your effort to share and answer our questions here.
Hi,
For the rings, can you adjust the position of the emitter relative to the reflector hole (without shorting things)? I don’t know if that matters since the emitter is dedomed, but might help.
Guys thanks for your feedback again. My lux figures seem too low. The torch visibly performs very well outdoors and throws almost as well as my HD2010 @ 6A. I’ll need to review my process as it’s not yielding results that are consistent with whats expected.
Hi,
May be possible via removal of the white LED protector that covers the wiring terminals. I’ll have a look later to see if its ok to do so without shorting. It would only result in a very minor shift of the placement of the reflector relative to the LED. That may be all that is needed.
