why not? It’s throwy, long runtimes, big enough to use as a club and has a new emitter. It’s because of the 8 batts? Just get one of those nitecorn 8 bay chargers and your’re set.
I understand flashlight with Ni-MH is great combination, especially for long period in-vehicle storage due to its low self-discharge property. For emergency or general vehicle light, I would prefer something more floody than thrower. I have enough chargers for at least twenty 18650, but that does not mean that I will enjoy the charging process, carrying boxes of batteries and constantly figuring out which batteries are fully charge later. Moreover, quality Eneloop batteries are as expensive as 18650 in my country.
Sadly, this reminds me that I will need to buy Ni-MH to replace my aging Eneloop for my 4x camera speedites by the end of the year.
They say you should never leave LiIon batteries charging unattended. Well I’m damned if I’m going to spend my life watching batteries charge. NiMH can be left alone quite safely, and I can happily keep the charger indoors, in my server cupboard without fear that my house will burn down. 8xAA is fine. The only issue is the weight, a torch + 8AA is not light, no pun intended. But it is manageable for general use.
In my car I have…
… and now side by side with its predecessor…
The D80A with the predecessor of the EA4
For charging eight Eneloops AA… No problemo for me… I have several NC-MDR02NU.
If we can get a good price… I want one.
P.D.: in my country are hard to find Eneloop…
There is always exceptions. SWM's design looks way more sexier.
In Europe you can get legitimate loops from the bay pretty cheap.
Fujitsu LSD and Duracell Duralock 2450mAh cells are the high capacity Eneloops, but be careful as some Duracells are Chinese, as are some Eneloops!
Antiparanoico: since you too own a D80a, what is the low brightness level on yours like? Do you reckon it is about 30 lumens as claimed or more?
Looks impressive, however, not sure that I would need one because I already own EA8, which I rarely use simply because I rarely need flashlights :D!
And yet your post count is 2038!
It is 2039 now, but I still dont need this flashlight :D!
8 x Eneloop (the XXX 2450 ones) and you are good to go
Will add another 2c of mine…
Same here, bought D40A, EA8W, BA20 to get the most out of NiMh chemistry and then started slowly crawling into Li territory with A60 and now S2+ and some others :)!
Still, IMHO, cant go wrong with so much power in 8xAA size! Love my EA8W, even though, just like most of my lights, it has seen very little use, in fact, the least of them all :D!
Interesting thing is that even though EA81 has more than twice the lumens of EA8, it still lacks in throw and has less peak lux than EA8!
The problem is who wants to have to recharge 8 x AA?! :Sp 4 slot chargers seem most common. It would be fine if it also had other battery options, like an 18650.
If you have at least two good, fast charging 4 slot chargers, your set ;)!
I dont see people with i4 charger complaining when charging their lithium batteries in all four slots at 350mA speed ;)!
So, dont see a problem with charging 8 NiMh’s with two good chargers here :D!
Been thinking today, how good can EA8 be at modding? Would like to squeeze as much as possible out of this thrower on AA’s :)!
Heres a tear down post and mod post of the EA8 by Old Lumens.
EDIT: I want to state here, for anyone else reading, that this whole thread (or most of it), was based on MY uninformed, knee jerk reaction to something I saw as a problem. The Real problem is my lack of knowledge when it comes to anything other than conjecture. I did what I Normally do and I ran my mouth without having any real knowledge. It's what I do, it's how I am. I develop my own thoughts based on non-scientific results. which ends up being useless words. So, what I am saying is, that…
Well, since the tear down thread already got fairly long, I figure I will start the modding thread and see where it goes. [ea8z1a] So here's the body, tail cap, head, reflector and heat sink to start with. Wait.... that head doesn't look right. [ea8z1b] Well, it looks a little different than it did a day ago. There's a little story about that. Heating the light was the only way I could think of, to get the head off, since it was loctited on. Unfortunately, it was still so tight that …
Thanks for those, I guess it will take a while for me to get to modding it, I was thinking something more simpler than that, simply replacing LED with never one and depending on LED's requirements might take a look into replacing driver.
It would be much easier to do, if not for head that cant be unscrewed the normal way :D!
Basically Im looking at modding it with off the shelf components with little soldering involved and definitely nothing hardcore, yet improving throw considerably.
Is that real?
Anyone did a review on the ea81? I’m about to buy one or the EAX.
I would go with the EA81 over the EAX.I have the EAX and the beam is really strange. The spill looks like Mickey Mouse ears! I just got an EC4S and Nitecore did a good job of getting ride of the death cross that is common to quad die emmiters.I would assume that the beam for the EA81 is simmilar if not a bit throwier with the larger reflector.
Thanks for the heads up. The EA81 is cheaper too, but don’t have the voltage readout thingy.
Power Tips
Right after battery installation,or when the mode switch is pressed with
the light off, the blue LED built into the switch will blink to indicate
remaining battery power. The power indicators will blink three times when
power is above 50; twice when power is below 50; and once when
battery power is close to depletion.
from the user manual of the EA81
Oh….good to know. Thanks.
