You can do this already if you research a bit and donāt mind German text around the discharge graphs.
Well, I truly donāt mind. But as of today even dampfakkus.de does not yet cover the GA, the MJ1 and the 30Q in the range of 2-5A.
And the HG2 was only added in the last 48 hours.
dampfakkus has a big advantage compared to me, they do not test at low currents and only test one cell! This means they can do their test in one or two day(s) and not one week as I need.
Canāt thank you enough for your thorough testing. Thatās why I would never ask for a change in testing procedure - but I do second TomEās motion for a tiny little shift in the queue.
I was not talking about dampfakkus.de, but the German flashlight forum. Just google battery name + ātestā and youāll find it.
Edit: I donāt see any rule forbidding links to other forums so here we are:
Samsung INR18650-35E
Panasonic/Sanyo NCR18650GA
Samsung INR18650-30Q
That is right here at BLF we arenāt scared of information from other forums
And here are the same links but auto translated to English
And i have to chime in on the request for HKJ to put these new cell at the top of the queue. The real original cells from Samsung, LG & Sanyo/Panasonic needs to be tested before the rewraps if they are available.
Here is another list of recent battery tests. I believe most of the tests are at higher currents.
Ok, got it. But following the links I donāt see graphs or charts, TLF seems to suppress pictures, so itās not that useful.
Normally it doesnāt. Pictures appear even when Iām logged out. Must be some other problem.
Edit: apparently it actually does if youāre not registered (tried in incognito mode). Not nice. Sorry. You could of course register to TLF, itās free and doesnāt hurt
Please test the AOSIBO IMR18650 60A 2600mAh cell, they claim incredible performance
I hope it is true, we can always use a stronger 18650 cell
They are curiously heavy for a 18650 at 50g, that is even heavier than the 3600mha Panasonic at 48,5g & most 2500-2600mha is around 44-45g. Maybe they really have found some new special componentā¦ā¦.
These look interesting also
The same, but different wrapper?
http://www.szaosibo.com/product_view.asp?id=132
http://www.szaosibo.com/product_view.asp?id=136
30A cont, 60A āpulseā
I donāt think it is the same cell, to much is different.
Old 30A/60A cell
46g
18mm
New 60A cell
50g
18.3mm
Plus the + pole looks very different.
But who knows maybe they just have an extra layer of rewraps, that could account for the extra width & weight.
Please test the Vapex AA 2500mAh low self-discharge Rechargeable batteries
On order
I do only have a few NiMH in queue, but I do not know when I will test them (The test station is used for chargers at the moment).
Efest IMR 3000mAh.
I thinkā¦ That all the 3Ah rated IMR batteries we are gonna see from now on should behave very similar to the 30Q
anywayā¦i do not know if HKJ has the necessary stuff to test 200/400A peak currents but it is now few months Iām intrigued by this
Hi!
If possible, could you review one of these: http://www.banggood.com/9V-800mah-USB-Lithium-Rechargeable-Battery-p-986563.html ?
I think itās an interesting concept and 800mAh wouldnāt be too shabby for a 9v battery.
According to the reviews on the item @ banggood, you get about 300mha to 400mha depending on how low volt your 9v equipment works at. Not bad but it is not 800mha.
I ordered that battery a couple of days ago. I forget to turn off my dmm sometimes, draining batteries in vain. so I hope this battery will work in my dmm.
Iām still curious about red trustfire imr-batteries also.
