I ordered 2 days ago, but there’s still an option to cancel the order on my Ali account. I left Simon a message asking whether he can adjust or if I should cancel and reorder.
Thanks! Please let us know if it works.
I’ll still be happy even if I don’t get a discount. I’ve never been disappointed with Convoy lights. Improvable? Yes. Let down? No way!
Unfortunately the time difference is a factor here. I just happened to place my order while he was still online, probably just before he wrapped up for the night. There are sometimes delays of near a day but he always comes though. Simon has to sleep too.
Yeah sorry buddy. I didn’t even think about it when I made the OP so I had to ask him and wait for his response. You can always send him a message and ask if he can do anything.
Interesting. I didn’t realize the switch wasn’t waterproof. I took mine apart just now though, and verified that it’s not. It appears to be at least slightly water-resistant though.
And now that it’s apart, I can fix the spring that I nearly melted with too much current. Add a bypass. I really should have done this when I built the thing initially.
In any case, I’ll probably wait until RMM has the blue host in stock. I want one, but I haven’t figured out what to do with it yet. With so many lights, it’s getting really hard to find a purpose for any new ones.
It’d also be really nice to have a triple spacer sized for the S2+ instead of having to find old S2 pills to swap in. I build almost everything as a triple now, since the beam and output are so much nicer.
Correct. That’s what Simon told me. The silcone switch cover is the waterproofing for the switch. The stainless while still tight and beautiful to look at IMHO is not waterproof. Water resistant maybe but that’s where it stops. Beauty always comes at a cost…
The CNQG brass light managed to stay waterproof with a metal switch, and it’s really compact, but it used a totally different method. I’ve never seen it used elsewhere in any way which actually worked. It’s basically a metal cover for a rubber boot.
But it also has threads on the inside so water can leak through the spiral gap. The CNQG brass lights have threads on the outside, and pressure holding the boot against the inside wall, so this isn’t an issue.
The BLF Ti could probably be made waterproof by adding teflon tape inside, but this might interfere with getting power through the body.
In any case, the S2+ metal switch isn’t waterproof. But I like it enough that my red one is one of my favorite lights anyway. I don’t have the head waterproofed either; it has an optic directly pressed to the metal with no o-ring or glass. I’d add those, but the triple spacer I’m using doesn’t leave room.
:bigsmile: :bigsmile: Awesome! :bigsmile: :bigsmile:
Thank you Richard for such wonderful products at oh so reasonable prices and thank you for the info Hank! Then again… dang it Hank… now I feel I have to turn mine into a triple… wife, family and friends already think I’m nuts. :money_mouth_face:
Seriously… this forum is trouble… but I LOVE it!
It’s wasn’t me that needed a triple I swear!
It was some guy with a moustache… and a big hat… :face_with_monocle:
Sure. The outer metal button piece screws into the red aluminum tailcap. It’s very very tight, but doesn’t appear to be sealed. The inner metal button piece has a rubber skirt which rests against the inside of the red part of the metal, but without any force. It mostly seems to give the button a springy feel, but also provides a bit of water resistance. No other switch pieces have any significant effect on waterproofing.
I expect it would stand up to splashes or rain with no issue, but being underwater would allow water to leak in fairly easily. There is only a little rubber-to-metal surface area blocking water, and it’s not held by any meaningful force. But it looks and feels very nice.
Thanks ToyKeeper.
Looks like it could be modified to be waterproof fairly easily. Just need a thin sheet of silicone sandwiched between the white(?) button washer and the face of the tail. I have a laptop keyboard protector silicone sheet that is even thinner then it would need to be but it’s still surprisingly strong. I’d round the edges of the white clicky actuator a bit. A gasket designed for the switch would be better though.
