And i have to chime in on the request for HKJ to put these new cell at the top of the queue. The real original cells from Samsung, LG & Sanyo/Panasonic needs to be tested before the rewraps if they are available.
Normally it doesnāt. Pictures appear even when Iām logged out. Must be some other problem.
Edit: apparently it actually does if youāre not registered (tried in incognito mode). Not nice. Sorry. You could of course register to TLF, itās free and doesnāt hurt
I hope it is true, we can always use a stronger 18650 cell
They are curiously heavy for a 18650 at 50g, that is even heavier than the 3600mha Panasonic at 48,5g & most 2500-2600mha is around 44-45g. Maybe they really have found some new special componentā¦ā¦.
According to the reviews on the item @ banggood, you get about 300mha to 400mha depending on how low volt your 9v equipment works at. Not bad but it is not 800mha.
I ordered that battery a couple of days ago. I forget to turn off my dmm sometimes, draining batteries in vain. so I hope this battery will work in my dmm.
Iām still curious about red trustfire imr-batteries also.
Just seen you already have tested the 10180 battery for DQG SPY/HOBI
Iām curious because with my charger @50mA charging current , but also with the specific DQG charger for micro usb, i never pass the capacity is ridiculously lowā¦ And I mean ridiculously
Tested the blue and the white versionā¦ Both are pathetic in the same way.
Another rewrapper who fake specs & even make a fool of themselves by questioning the result while showing big holes in basic understand about how cells workā¦ā¦.scary stuff.
I am glad i am not a vaper because it seem it is the wild west out there in rewrapper land & most seem to target the vapers with inflated max amp ratings.
