Of the (many, various) 80+ CRI leds that I dedomed thusfar, dedoming makes the tint warmer but the tint always stayed nice, and colour reproduction stayed good. I can not measure CRI, so it is a guess, but I think CRI is not much ruined by dedoming.
This shaved Nichia 219C led I guess at 4500K, so it had a limited tint shift (may or may not have something to do with the quality of the dedoming effect)
My gut tells me that CRI is the product of the phosphors used, therefore unaffected by dome slicing. But obviously the dome has an affect on tint, so…… I wonder if MEM has tools for measuring CRI….
A lot of high-CRI led have the magic high-CRI producing fairy dust mixed into the dome material. I saw some microscope shots of some Nichia LEDs where red granules were embedded in the dome.
We do a lot of spectral testing here for customers, as a comparative point. When you test with and without a secondary optic you can get up to 300Kelvin shift, the logic would say a dome on a led is a primary optic so the same shifts should be expected
Djozz, they are the same dome style as a 219B, correct? Very similar? I have dedomed a few 219Bs, they can fool you. Nichia has a clear-coat layer ON the phosphor. It’s perfect after the de-dome, to explain what I mean, the die looks like one of these CREEs after a de-dome (picture below), making you believe there’s extra material stuck on because it’s glossy—I found it to be filled with phosphor. You do not want to remove the glossy layer after the dome, then.
I use a 2-step de-dome procedure now that is a chemical de-dome in about 4 hours, I did a time-lapse video showing the dome detach right around 4-5 hours if done with a fast solvent followed by a slow solvent because of varying plastic types in the dome. I first attack the base glue, then swell the dome until it pops by itself. No slitting, I do not touch the dome.
Sorry, I had completely missed where you had asked about CRI measurement before I last posted. I have a tendency to catch the start/end of threads when I’m in a hurry to read. I need BLF-subscribed posts on a 24/7 audio translated PA stream that I can listen to as they come in over horn speakers throughout my home and shop. :bigsmile:
OK, to explain this, you must first understand how difficult it can be for one to fully explain. Even the simple answer of a yes or no, it’s always dependent on a few different refractive properties, phosphor thickness, bonding, sealing layer contour, etc etc. IMO, I think a good de-dome is still going to change CCT noticeably enough. However if you read on…
We deal with two primary rating systems: CCT & CRI. We expect CCT to directly impact CRI-rating, in some reasonably predictable fashion. People go as far to assume this is an automatic change and the two are linked. We know CCT will change with a de-dome, and that means a CRI change. Well, technically that is not true. CRI is independent.
About the CRI, first of all. The latest “news flash” of high-lux LEDs that also have a “high CRI” rating is something we mostly have not been used to seeing or hearing about—especially when our focus gets affixed on CREE LEDs and their numbers. These trends tend to form opinions about CRI with some mistruths involved about de-doming. I would highly recommend that you read this webinar from OSRAM Opto, about the entire nature of CRI, and newer CRI rating types which exist (Ra, R9), that take things like color saturation into consideration, as well. This PDF will help many better understand how “CRI” is developed, what “CRI” actually is telling us, and also how effective the CRI rating system can and cannot be across the large scope of all available LED choices out there.
So even though intensity increases, and CCT will change, the same colors are technically still there in the LED. Those individual wavelength regions are further influenced by lens design, such as if the lens collimates all available colors at the same image projection without throwing some color away, due to aberration, for example.
I have a method I feel might possibly work. I have a 50”x50” fresnel lens in a frame, with a white wall near the back. The effect is interesting, because the fresnel seems to take on the full tint of the projection, and it is this displayed, like a TV channel. So I’ve wondered about the Adobe CIE color system combined with “RAW” photos. Let’s say I aim the camera so that the entire image is the fresnel lens lit by an LED projection, the photo should measure the tint, to some degree better than a human eye I would expect. This data can then be seen in Adobe. So I would setup, take a few baseline images, then de-dome, redo the test, and see what Adobe says the new CIE data is composed of. Seem or sound logical? I haven’t tried this yet, until I realized how well the entire surface took on the tint, even if hit by a 3x3” square of light, the entire lens still glows evenly. I could do some tests, but I haven’t thought this all the way through, so I don’t know if it truly is a good idea to start doing. I suppose it’s better than catching the pure hotspot alone in a photo and trying to analyze that—then other tints are involved (from small objects, wall reflections, etc) and would create erroneous (though possibly minute) extra color data.
I will try it, but must get some bezels turned out right now. Cerakote runs in the morning. Won’t be tonight.
I think I understood most of that. I’ll be interested in the results if you do decide to do some kind of test.
However, maybe I should just convince myself that slicing the 219c’s dome will actually improve the CRI, then live in blissful ignorance of the fact that I am probably wrong. It’s all in the head.
I can say this much. A solvent de-dome provides much cleaner and more repeatable de-domes (especially on hard to do emitters, apparently Nichia for those doing “hot” de-domes). CRI should not grow higher necessarily. CCT just drops in kelvin. This doesn’t expand the color range to include any more red, for example, or any more colors, just slightly changes their ratio. This is why I posted the PDF.
A LED dome is made to take on heat and stay bonded to the phosphor (to extent). It’s not made to resist solvent. Attack it at the weakest link in the chain. Only makes sense. A dome has enough buoyancy to “pop” after a swell, and lift itself right off with a very small swirl of the fluid if still attached anywhere. If you’re not having this happen, something isn’t right. Like I said, I never slit domes, that is to finish, or to provide a de-dome aid. The plastic is highly porous when in solvent, slits aren’t needed and will possibly negate from the desired “full dome” lift.
After a de-dome, untouched by tools/razer, a full dome lies at the glass bottom:
The 5000K 83CRI 219C that I butchered dedomed and used for last evenings Supfire S1 mod, as described in your DIY-trit-replacement thread, has tint shifted visibly, the current tint I estimate at (a beautiful :-) ) 4000K. And as with all higher CRI dedomes, the light quality has not decreased (but increasing CRI by dedoming sounds very doubtful). As pointed out above by MEM, the phosfor mix has not changed by the dedome, so that must still show.
That looks like the perfect way to dedome Nichias.
Would you be so kind and tell what kind of solvent you used?
Some kind of nail polish remover, acetone or simply gas?
I have not seen it through a coated lens, and there's many types and quality of coated lenses around, so one would not tell much.
This dedome might not be typical: a thin mess of silicone leftover on the die, the sides with the white stuff cut away.
This will be a subjective description as I have no way to measure tint and CRI apart from estimation with my own (trained) eyes.
That said, I compared the light to a (newest version) Oslon Square 4000K 92CRI that I have in a flashlight with similar beam, and the colour temperatures are comparable (so ~4000K), the tint of the dedomed 219C is more a clean white, which looks more rosy compared to the Oslon which is slightly green, it reproduces all colours really well, just in the saturation of bright reds the Oslon is a bit better despite the greenish appearance of the tint (but as expected from its high CRI).
Please don’t take this the wrong way, but holy moly that’s an ugly dedome. It looks like chemical dedoming is going to be the way to go with these. That or slice and polish.
LOL, I agree on the ugly dedoming procedure and looks. I actually made a video of this dedome, the idea was to do the dedoming procedure entirely while the led was on the heatblock that I slided under my stereo microscope for good vision, the block temperature was just under solder melt temperature. It did not make the dome stick less wel to the die/substrate unfortunately. After what you see in the video I cut away the sides of the silicon and the white stuff.
So the idea did not work out, but this ugly dedomed led did the job anyway: noticable tint shift, improved throw, draws more than 5A from an Efest 16340, with 800 initial lumen OTF, that is close to 1000 ledlumen. I love the tint.
Thank you for all these dedome method attempts djozz! Great info.
As one that sees beauty in functionality, that latest one pictured above . . . oh, who am I trying to kid. It may not be pretty, but it's getting the job done and that is a truly redeeming value for me.
Dedoming increases the action of the phosphor, so it makes the tint warmer. That might increase the CRI.
The optics matters because the light re-emitted at longer wave length from the phosphor goes in all directions, so it comes out at wider angles than the blue band directly from the die. So zoomies have cooler spots than reflector lights do.
I have not been able to observe CRI. I don’t remember the color bin, but I have a neutral white Cree LED with about the same tint as my Nichia. Comparing the two shined on flowers and colored pens, I can’t see any difference. Using a camera and Gimp, would be more sensitive, but not necessarily meaningful because it would depend on the camera’s color response not on anyone’s eyes.
