KD (kaidomain): Deals and new products thread
If you have a charger that can charge LiFePO4, I have been using the Soshine LiFePO4 AAA’s in my buckle with a good increase in brightness over Alkaline. Not as much as a 10440, but runs cooler too… Just an idea.
Bring you guys a promotion on Cree XHP-50 and Cree XP-L HI (Only LED)
Cree XP-L HI V2 1C $5.99
http://www.kaidomain.com/product/details.S024235
Cree XP-L HI V2 1B $5.99
http://www.kaidomain.com/product/details.S024340
Cree XHP50 6500K $7.31
http://www.kaidomain.com/product/details.S024312
CREE XHP50 5500K $7.31
http://www.kaidomain.com/product/details.S024311
New Cree XHP-70 5-Mode LED Flashlight is arrived to KD
SKU S024364 $54.55
5-Mode (Hi > Med > Lo > Str > SOS)
Can be used for 2 x 18650 / 2 x 26650 or 3 x 18650 / 3 x 26650. Extension Tube is included.
BanL, you forgot one.
SKU S024408 $40.04
Mode Arrangement: Hi > Mid > Low > Strobe > SOS
Battery Configurations: 3 x 18650 / 3 x 26650 Li-ion batteries
Cree XHP50 White 2000 Lumens 5-Mode LED Flashlight - Black (3 x 18650 / 3 x 26650)“:http://www.kaidomain.com/product/details.S024408
what actual bins are the xhp50?
or are 6500k and 5500k of same brightness?
This XHP50 flashlight is 6000K to 6500K.
i asked CS and got very fast response:
@ our Pros:
how good are the hxp50s?
Sorry for some typo mistake from us.
Cree XHP50 6500k (S024312), it is J4 1C
Just noticed that Kaidomain has some new XPL HI Stars.
Cree XP-L HI U4 7A2 3000K-3500K LED Emitters with 20mm x 1.6mm Copper Base
http://www.kaidomain.com/product/details.S024424
Cree XP-L HI U4 7A2 3000K-3500K LED Emitters with 16mm x 1mm Copper Base
http://www.kaidomain.com/product/details.S024423
Could you tell what the point of a u4 bin is? Surely that’s a step back from the xml2.
Marc.
That wouldn’t be the main target of the production run.
Binning takes the output of the run and sorts them by color and efficiency.
The odd bins collect the emitters that came out a bit off the target; they get sold cheap by discounters to people willing to buy small lots or single items.
https://www.google.com/search?q=led+binning
But the u4 bin is not as bright as an xml2 u2?
Marc.
U4 is brighter than U2… but they are not as bright as the V-bins.
I’m seeing 869 lumens for the XPL U4 VS 1119 lumens for the XML2 U2.
I don’t see the point in the XPL at this bin.
Please tell me if I am missing something as I have no experience with the XPL.
Marc
Hmm… seems that I was wrong. I assumed, that the XPL and XML2 bins would be equal, since the die size is the same. They are not.
at 3A, XPL U4 should give 869-920 lumens, and XML2 U2 1119-1193.
XM-L2 U2 is comparable to XP-L V4 or V5 in brightness.
But you aren’t going to find a 7A tint XP-L HI in a “V” bin anytime soon.
The warmer tints typically produce less lumens, and the HI produces less lumens.
U4 isn’t a bad bin all things considered.
Compare the 7A tints: XP-L HI to XM-L2 - that's more equivalent. I think the XM-L2 7A's were like T2 or T3 - way lower than U2's. There are 7B3's now though in a T4 bin.
They’ve just added the Cree XP-L HI V3 1C 6500K LED Emitter to their list for $5.79
http://www.kaidomain.com/product/details.S024438
Also listed is a clearance sale of older SSC torches for $10. For some it may be a good value host for modding.
http://www.kaidomain.com/category.128
Do you know a way to filter that site for things in a category that are on sale?
Hi,
Thanks! I picked up a couple of the $10 lights :)…
