I was going to get a loom + bulb socket from the wreckers , and then I could measure current , maybe even build a lightbox , as a direct comparison between bulbs ...
ATM I simply position the light meter in front of the tail light , much like measuring throw for a flashlight ..
Perhaps not the most ideal method , but I want to know how much light is going out the back , and it works for that . ( That's where I need to see more )
Im after the brightest , and current (?) or power ( Watts ) is very secondary ..
Plan is to be more thorough - but I'm not taking it that seriously yet .
Its what I can see out the rear view mirrors , having a bad back I find it hard ( painful at times ) to twist my body to look out the rear window .
Which is why I put in a camera ( reversing camera ) , but at night the camera is ?? not that flash - I need more light .
I was thinking of just cutting the bumper for a light bar , but then you might run into Australian design rules ( ADR ) ..
A light bar for reversing??
Please don’t put it in reverse while I am driving past, I like to see so I can miss you
With having enough light for the camera, have you thought about infra-red, security cameras are readily available and 820nm and above are invisible to our eyes, push out as much ir light as you like :bigsmile:
Cheers David
Edit, had a look at the ADR for reversing lights, other than you can only replace the lights (including globes) with ones approved by the ADR (like, who cares)
None standard lights should have an external switch that cannot be reached from the inside, have been booked for this one
I know what you are saying, and I will do the same myself when my eyes, and back, mean I need more light, what I would/will do is to hide the light just under the car, take the power through a switch and relay from the standard reversing light wiring so the light can only be turned on while in reverse, using the standard lights only when around traffic which usually means there is enough street lighting anyway and turning the big guns on only when needed.
Liking the review
Reversing is always an issue in my work van at night- there is precious little light and it’s by outside mirrors alone. A medium rain and I can’t see anything which doesn’t reflect at least some light. I was considering some of these but most reviews aren’t useful- your’s definitely is! FYI there is a 50W Incan bulb made on this base pattern but 2 problems emerge: circuit load and heat. The latter is probably OK as these lights aren’t operating for long, the former could pop a fuse or toast wiring. I haven’t tried this myself.
Illumination for reversing doesn’t need a lot of ‘throw’ so perhaps a small light bar aimed downward would work, letting the refracted and reflected light do the work. That could be totally hidden under a car and would have the advantage of lighting the back of your car so other driver’s couldn’t miss seeing you and what you are doing without blinding them.
@David, the relay inter-tie should eliminate legal problems but most vehicle codes will allow accessories to assist with medical conditions such as old4570’s back problems and it would be a rotten Cop and Judge indeed who took someone to task over such a thing if it were explained to them as such. I think the worst end would be them telling you it has to be removed with no fines, but likely would be the charge being summarily dismissed.
(sarcastically) Just what I need, another project needing to be done.
(seriously) Good Job and Thanks!
Phil
Back when I was driving a cheap Chinese scooter to work every day, I had bought a lot of these 12V LED automotive bulbs, and the variety you showed as your first attempt was the only one I could find that worked well. I’ve tried several of the various bulb styles available, and this style was the brightest, by far, with good output pattern to work well in automotive reflector fixtures. I was concerned about heat, especially as these are enclosed in a module with no air circulation, and are used constantly while the vehicle is operating, but I never noticed any issues. I’m still using one of the bulbs in my newer bike as the main brake/taillight bulb, and it’s still going strong.
When I bought these, I was trying to free up enough surplus power in the weak charging system to let me upgrade my headlights. The factory bulbs were the Chinese style 35W bulbs. By replacing the factory cluster, brake/tail, and signal/running lights, I freed up enough wattage to upgrade the headlights to automotive H4 45W bulbs which made a huge difference. For about another month of use before the main crank bearing died, effectively killing my brand new bike after six months of use and only 5000 miles. |(
i put a luxeon altilon 1x4 in each of the reverse lights of a 71 olds 442.the lights are metal and can take the short term heat.at 1a each thats about 900 REAL lumens.EACH!it looks like daylight behind it in reverse.
i thought of a switch to flash them to back off tailgaters.the bare led is nasty to look at directly.the lense softens it a bit.
Kind of crappy picture comparing stock w16w bulb and “50W” ebay led (link above in my previous post).
It’s hard to notice any big difference, except for the tint.
Whooaaaa. Thanks for these pics. You even got me interested in this solar light! This read led light looks hella bright. Just what I might need! Is it just a remove and replace bulb or is some modding needed? Any heating issues? Re-reading the thread meanwhile for answers!
