Ouch! Thought someone said that, wasn't sure. Still, it's a great power pocket light for a newbie - good giveaway candidate with the USB charging. There's glue then there's glue. I recall with the TN31's, I ran across every possibility of threads being glued light, heavy or not at all - zero consistency, so you never know... I modded several of them - seemed like no two were the same.
I've opened several glued and very tight lights others couldn't get apart, not all, but many. We'll see - might have a challenge here...
Don’t take me the wrong way, $20 is still a great price and if it had a clip I would probably deal with the glue and buy one anyways. I just can’t see myself using it much without a clip, no matter how much I like the built-in charging
I grabbed one of the Rambler torches for $20 too. I read pilotdog’s comments on the glued head and it didn’t put me off as I wouldn’t be looking at modding it.
I also dont quite understand why do manufacturers glue the heads?
W00t?!? Lucky you!
Well…never won anything in my life…, and the only one i won something (and it was by my friend’s skill and not even by luck) i did never received it from banggood…oh well…nothing I’m not used to
According to my points balance sheet I have “used up” hundreds of points to spin the wheel and I have won absolutely nothing. Some of the points were from the spins but the last couple of hundred were spent from my balance
But good to see the wheel was working - Congrats to the winners and thanks to Banggood for the opportunity.
