I’m not intending to argue (but I guess I am), but it seems like the problems that some (a lot?) are having with lights not working because of slightly different tube dimensions because the threads are anodized are way worse than the positives mentioned? The button is not stick out of the rear, so it seems like it’d take some effort to turn it on accidentally when in pocket especially with the clip?
In my case, I lucked out and my light seems to work ok, but if the end of the tube was just slightly too short and prevented the contact to the retaining ring, then… no light…
Anything volatile is going to evaporate and deposit further inside the light.
LED emitters are known susceptible to contamination from anything volatile — that’s why there’s sealant over the emitter, but it’s not a perfect protection.
Anything — temperature control gunk, O-rings, solder/flux, cruft, penetrating oil — is going to volatilize to some extent.
The reflectors are really not easy to clean without scratching; if your light’s bezel/head is removable (with all the precautions about pressing on the glass while rotating the bezel, being careful not to dedome the emitter) then you might take the reflector away first and leave the LED open to the air (sit the thing on an open grid/mesh)
One drop of whatever, with that drop led around the groove with a toothpick, and let it work its way in.
Don’t mind me, I’m just nitpickery about this stuff.
Pics added! function check, tools, spring bypass, sanded star. Member vinte77 found an awesome pocket clip of you’re into that sort of thing check in the opening list for a link.
@dudunphy, what a great thread you have started! Your OP is full of useful, and informative information. It has also prompted some of the brightest forum members to add their helpful input. This thread, in my opinion, gets right to the heart of what BLF is all about.
Thanks for your contribution!
Hi didunphy, the driver spring bypass you show in the OP is kind of tricky because with the bare wire used and the retaining ring in place, if the wire is not positioned perfectly, there's a chance of shortage against the ring and that is a direct battery short. Using silicone wire makes it less critical even tough it still must be done with care.
— Chouster, in the main thread at Thu, 09/03/2015 - 15:12
Has anyone tried substituting one of those “butterfly” type spacers, that seem to stay on the emitter board rather than move around with the reflector as the bezel is turning?
If the driver retaining ring turns a little then stops, don’t force it. Instead, turn it to the middle of its loose range, grab it with tweezers, and turn while lifting up. It may need a bit of help to “catch” the next set of threads.
On some units (including the EE ones), it seems there is a small gap between two sets of threads there. It can be tightened easily since it falls from one set to the other, but unscrewing it requires a more delicate touch.
How about I re-post a bunch of stuff?
(in case it’s interesting to anyone who missed my long ramblings the first time)
The modes are:
|. Group 1 |. 7135 power |_. FET power |
| Moon | 0.8% | 0 |
| Low | 8% | 0 |
| Med 1 | 43% | 0 |
| Med 2 | 100% | 2.7% |
| High 1 | 100% | 22% |
| High 2 | 100% | 54% |
| Turbo | 0 | 100% |
|. Group 2 |. 7135 power |_. FET power |
| Low | 8% | 0 |
| Med | 90% | 0 |
| High | 100% | 35% |
| Turbo | 0 | 100% |
It means modes between 5 lm and 155 lm will keep the same lumen level for most of the battery’s life because those modes are regulated.
Modes above 155 lm will gradually decrease as the battery charge drops, with the effect being most noticeable at the highest modes.
Moon will also gradually decrease with voltage.
Another way to look at it:
Mode 1: … moon is always weird; gets dimmer on a low battery
Mode 2: regulated
Mode 3: regulated
Mode 4: 85% regulated
Mode 5: 36% regulated
Mode 6: 20% regulated, mostly direct-drive
Mode 7: 100% direct-drive, drops with voltage
The semi-regulated modes will still drop with voltage, but the slope of that curve will be less steep than if it were direct-drive.
The highest output the 7135 can do by itself is about 157 lumens. This is used only on the biking flasher. Other modes are calibrated to be evenly-spaced, and none fall exactly at the maximum level for the 7135 chip.
One of the common gripes for the BLF X6 v1 was that the levels weren’t spaced evenly at all. The output levels I measured were:
low: 5.5 lm
med: 240 lm
high: 560 lm
turbo: 922 lm
On a visually-linear (cube-root) scale, the X6 v1’s perceptual brightness goes 1.77, 6.21, 8.24, 9.73. These represent how bright it looks to a human eye, in arbitrary units. Big gap at the beginning, then only small gaps for the rest of the range. The gaps are 4.44 visual “steps”, then 2.03, then 1.49. The brightest mode looks about 5.5 times as bright as the lowest mode.
This is fixed in the BLF A6 and in the BLF X6v2. The approximate output levels of those are (so far):
0.35 lm (visually 0.70)
11.8 lm (visually 2.28)
65.9 lm (visually 4.04)
190 lm (visually 5.75)
427 lm (visually 7.47)
832 lm (visually 9.41)
1494 lm (visually 11.43)
The “visual step” gaps here are: 1.58, 1.76, 1.71, 1.72, 1.94, 2.02. Those last two are a bit brighter since it was calibrated without spring bypasses, and this sample had a spring bypassed. In stock form, each level is about 1.7 “perceptual units” away from its neighbors. And the brightest mode looks about 16 times as bright as the lowest mode (though in reality, it’s ~4200 times as bright).
Or in the 4-mode group…
143 lm (visually 5.23)
588 lm (visually 8.38)
These gaps are: 2.95, 3.15, 3.05.
So, this is one little thing which got fixed since the original BLF X6.
Hi, just a quick update with lumen measurements from a totally stock production unit in 3D tint. I used a Samsung 25R cell charged to 4.18V, and measured the initial output (not at 30 seconds).
Lumens at each mode, group A:
A1 : 0.55 lm (visually 0.82)
A2 : 11.79 lm (visually 2.28)
A3 : 71.03 lm (visually 4.14)
A4 : 197.6 lm (visually 5.82)
A5 : 450.0 lm (visually 7.66)
A6 : 874.1 lm (visually 9.56)
A7 : 1351 lm (visually 11.06)
Lumens at each mode, group B:
B1 : 11.81 lm (visually 2.28)
B2 : 147.4 lm (visually 5.28)
B3 : 613.8 lm (visually 8.50)
B4 : 1351 lm (visually 11.06)
The “visual” units are a cube root of the lumen output, based on the “visually linear” scale used by selfbuilt. They represent how bright it looks to the eye, in arbitrary units.
Perceptual mode spacing: (visual increase per level)
Group A: 1.46, 1.86, 1.68, 1.84, 1.90, 1.50
Group B: 3.00, 3.22, 2.56
The levels could be a little more evenly-spaced, but it’s not bad. I calibrated the sample to 1.70 perceptual units between each group A level, and IIRC about 3.00 units for each group B level. But it’s close enough that it looks pretty even in person. And I expect it will vary per-unit anyway, so the spacing should be pretty close overall. Also, the space between upper levels will increase with a spring bypass.
So. The light performs according to spec. This is good news!
Someone asked me if the Solarforce L2 clip would fit the BLF EE A6. The answer is yes, but it will need a piece of wire or something inserted into the tailcap to fill in the gap between two contact points. It also will have a ledge sticking out a little past the body, all the way around.
Here’s what it looks like:
Paperclip cut and bent to fit into the tailcap:
FWIW, I usually try to keep my cells somewhere in the middle of their charge. Discharging too far can damage the battery, overcharging can damage the battery, and even resting unused at 100% charge for long periods can permanently reduce the capacity. I hear the recommended storage voltage is about 40%, to maximize the number of years a cell will last.
So, I generally charge a cell to 4.18V (picked a charger on purpose which stops a little early), use the light for a while until it’s down to one or two blinks, then switch to a different light and repeat the cycle. This way I get to use all my lights, and I avoid the conditions which reduce cell life.
The LVP functions should work reliably, and are intended to let you get the last few drops of power out of a battery without actually getting into dangerous territory. Draining a cell that far will use up its lifetime-in-years faster, but it won’t actually destroy the battery.
Quoting a guide from Texas Instruments… “Another easy way to destroy an Li-Ion battery is by discharging it too far. The Li-Ion cell should never be allowed to drop below about 2.4V, or an internal chemical reaction will occur where one of the battery electrodes can oxidize (corrode) through a process which can not be reversed by recharging. If this occurs, battery capacity will be lost (and the cell may be completely destroyed).”
A 2.8V cut-off is a balance between using as much power as possible and avoiding cell damage. There’s only like 2 or 3mAh left at that voltage, so you’re not missing much. It also provides a longer window for the operator to react and click the light completely off.
The way it behaves in testing is:
While the light is on high, voltage slowly drops to 2.7V.
LVP kicks in and drops the output to medium.
The battery recovers to 3.0V and runs for a while.
Voltage eventually drops to 2.7V again, so LVP activates and puts the light into low mode.
The battery recovers to 2.9V and runs for a while.
Voltage drops below 2.8V again, but there is no lower level to drop to. LVP shuts the light off and enters deep sleep mode.
This has mostly been tested on a bench power supply though, since I have no 3.0V cells to test with and don’t want to regularly inflict this kind of abuse on my 3.6/3.7V cells. Plus, it makes testing a lot easier and faster.
If the light was in a blinky mode when LVP hits, it’ll “step down” to medium then proceed normally. You can also bump the mode back up if desired, but it will probably step itself down again within a few seconds.
Also, here are some shots showing a cross-section of the beam. Some things to note:
The AR coating on the lens is real, as shown by the blue halo. Expensive name-brand lights often do the same thing.
Tint is different on the two power channels, so it will gradually get cooler as it gets brighter.
Tint varies between spill and spot, as usual for Cree emitters when aimed by a reflector.
Here’s mode 3 and mode 6 with a default auto-exposure and fixed “daylight” ~5000K white balance. The light is resting about 2cm above a white table, aimed parallel with the table:
Here is the same thing but over-exposed to show the dim parts of the beam better:
Although these pictures are straight from the camera, they show the tint variation a lot more vividly than what you would see in real life. Human eyes adjust to the tint so it’s not as noticeable.
Also, I made something else which curiously changes color while you look at it. If I toggle between the BLF A6’s 7135 power channel and the FET power channel at the same lumen level, the LED changes tint! I don’t have a proper youtube account to host it on, but if you like you can still see a short video of the effect from my site. It’s the one on the right; the Nichia 219B light on the left is only for tint reference.
I took some beam/tint shots showing what happens if you replace the lens with a non-AR one, and what happens if you put DC-Fix on the stock lens. The result is pretty subtle for AR, but pretty significant for DC-Fix.
First, a close-up of the stock lens (left) and a plain glass lens (right), showing the blue halo effect. This shows that the AR coating is actually there on one and not there on the other:
Then a shot of the two beams side by side, with automatic white balance. It shows that the hotspot is warmer than the spill, and if I examine the image with a RGB color hex tool I can see that the AR lens produces slightly more green than the plain lens. But I don’t see much difference by eye:
… and again with a Nichia 219B triple in the middle.
Now, the halo shot again… but this time the one on the right has the stock AR lens and DC-Fix:
… and the beams with DC-Fix on the right:
… and more of an oblique shot to show the difference in beam shapes better:
Oh, the AR coating increases lumens and throw by a few percent… but it also changes the tint. It causes a slightly warming green shift. This works like a prism, bending light depending on the color, diverting blue to the side while other shades pass straight through.
The effect is mild on the Manker lens, but EE’s lens has more of a medium-strength green shift. Neither is as bad as some of what Olight or Eagletac have used though.
If a light is intended to have good tint, it needs a non-tinted lens. If it’s designed mostly for throw, an AR coating may be more appropriate. It would be cool if we could get clear glass on the neutral white units and AR-coated on cool white.
On the left is the Manker lens, right is a Convoy (uncoated?) lens:
For comparison, here’s an Eagletac lens (totally ruining the CRI of a Nichia 219B):
These each show how much blue light is being diverted sideways. This makes the center of the beam warmer and greener. And I don’t have a shot comparing a Manker vs EE beam slice, but I do have one showing their AR coating. EE’s lens is bluer, which I don’t like.
EE is on the left, Manker on the right:
As for the light which passes through into the middle of the beam, this shows the approximate tint shift to be expected after blue has been diverted.
Olight lens on the left, plain glass on the right:
I just made a photo-collage of the two springbypasses that I did this evening with 22AWG silicon wire:
Did it help? I did not measure before the bypass, but I have two BLF-A6 lights, both 5A, and for both I had a fully charged Samsung 30Q. These are the outputs in 'djozz-lumen' (which may or may not be 9% too high):
7-mode group for the flashlights resp. without/with wire bypasses:
moon 0.66lm/0.55lm
2 11lm/10lm
3 70lm/70lm
4 190lm/205lm
5 395lm/475lm
6 750lm/920lm
7 1240lm/1495lm at start
7 1215lm/1410lm after 30 seconds
That looks like a 16-20% gain on the high modes (if assumed that the lights performed identical before the bypasses, well, everything looked identical to me ). Also nice is the low output-drop from 0-30 seconds, we're having a good working DTP-board in this light :-)
Just keep it in all in the OP, I'd say. (not sure if names should be in the title).
And perhaps, if you mention the output numbers with the springmod instruction (the soldering quality is not that pro btw ), you should add that these numbers come from lights with 5A leds (1A and 3C would have higher numbers)
Hi! My 3D A6 came in some days ago, I already wrote it is not working correctly, maybe it is due to a short tube? It is 2.333’
Tightening it with Greyskull Power, I could have it light up and behave badly but consistently: it will not turn on on first click, but on third or so, and then it can cycle modes, but again it is weird: it has no moonlight, first two modes are identical, then a sort of medium, then last two higher modes are identical too.
So, what is going on? Shall I ask for replacement or just a longer tube?
I’ll take the reward!! :party: This is by far the strangest behavior I’ve seen from a flashlight before…
I made a little video, It was set on 4 modes group, but the same happens when set to 7 modes. a more detailed description:
1st mode: ramps from low to turbo, holds there for a few secs then goes back to mid.
2nd mode: ramps from high to low, holds for a few secs then turns off.
3rd mode: about 30% of turbo
4th mode: about 40% of turbo
5th-7th mode: same as 4th mode.
Starts in the 3rd mode to give an idea of the brightness. Double hard click used so it can be heard when changing modes.
That’s not a tube length issue, that’s a bad or badly-soldered 7135 chip on the driver. It’s the chip with 3 legs on one side and only 1 on the other.
I finally acquired one which acts this way so I can test and debug it, but as far as I can tell it’s entirely a hardware issue. I think someone already reported that they fixed one by re-soldering the chip, but I still need to try that.
You know you don’t have to actually click the button to change modes, right? All it needs is a gentle half-press like what one might use to get a camera to focus without taking a picture. A full click is only needed to turn it on or off.
In any case, I have no idea why it would behave that way. The code doesn’t have anything even similar to ramping built in. It’s like it’s running totally different code.
Ugh! Well, thanks for letting me know.
Unfortunately I have close-to-zero electronic skills, let alone the time to figure how to re-solder a 7135 chip on the board.
I think I will contact Neal and point him to this discussion to see if I can get a replacement.
