It sounds like the 219C should do okay with a FET as long as it only uses low-amp cells like the NCR18650A. I think. Does this sound right?
I want to put one in my CNQG brass 18650, but it only has room for a single-sided driver… so that means 4x7135 or a FET+1. Does a FET+1 and NCR18650A sound like a safe combination?
With DD drivers extra voltage is burned off in LED,since DD is just low resistance switch;with linear drivers extra voltage is burned off in driver itself.
Excellent work, btw! From the beamshot earlier you posted, looks like the 219C doesn't tint shift much when de-domed.
Is this the same one you reported earlier with the SS collar? It sounds like it would do the same on a KK cell. I can fit the KK 26700 cells in my 1405's - the 26700's have high capacity and pretty good low resistance.
What's the SS collar? I recall discussions - can't recall if it helped much. I tested one hand made by O-L way back but didn't get any noticeable improvements.
Should end up at around 1240 emitter lumens, according to the chart. Close to the maximum but, more importantly, on the left side of the output curve. So I think the main remaining issue then would be heat, with is a bit easier to deal with. I may even use this as a testbed for thermal step-down features on an attiny25. In such a small driver cavity, the MCU should have a relatively easy time sensing the pill temperature, especially if I cram in a thin piece of thermal-conducting foam.
I reflowed 3 of these on a (slightly well used) triple board. I will see this evening how much they draw from a FET driver and a 25R
Ok, I measured the triple at 12,8A with a fully charged 25R and at 10,8A with a fully charged 18500 IMR Efest.
I’d expect an Efest Purple or LG HE-4, Samsung 30Q, to do higher than 12.8A. Hence my 15A wager…
Still, very impressive lot of output in a High CRI rendition, no doubt! :bigsmile:
Edit: Assuming you did spring bypasses, right? Through board on the switch? What size wires did you use? I’ve taken to using 18ga for these projects to allow every possible bit of current to flow. 16 ga if I can fit it in.
When I measure current the tail cap is not used so the switch does not count.
But with this high currents, I will do the through board switch bypass soon.
On my DMM I used 20cm short 18 AWG wires, but I think it is not that accurate at over 10A.
edit: Still happy with the light, the triple is installed in a mini S2+. I managed to squeeze a 18500 cell into it using the shorter S2 pill. The low modes are very useable and on the highest mode it is a very (!) bright, very small, floddy light. But also after 20 sec in the highest mode the light is too hot to hold
This is what I was trying to decipher from that photo. On my monitor, the S4 die appears way too yellow compared to anything I’ve seen in a 2B tint. The Nichia looks like the 2B tint, and the 2B looks like it would be the 219C. But as I linked to before, kelvin actually tells us nothing about true CRI. It still doesn’t explain that extremely deep yellow tint in the die corners on an S4 2B bin. I suspect the remaining polymer on the die of the 219C is actually messing with the amount of blue within focus, acting somewhat like a pre-collimator. It’s just that, it usually doesn’t occur so much without a full dome. Or I should say, usually doesn’t occur that much, with so little dome left.
The 219C appears closer to an “off-white” ~4500K with slight red fringe around the image, the Cree G2 S4 2B looks like it’s across the spectrum on my monitor, like 3300K tint in the corners. It looks de-focused, because of the corners shifting towards red spectrum and the center being colder in appearance. Hmm…. Beats me!
