Not sure if this has been asked before, when one uses a linear driver to drive the 12V XHP-35 emitter, wouldn’t the 4S batteries kill the XHP-35 immediately due to the extra 4V?
Yes I did read your test graph (thank you for that!), and yes I do realize that the Vf of the LED would increase as the current increase, but how about when the LED is in low mode (i.e. 0.1A or lower) while the Vf is still around 12V only?
Anyone has tried to mod the Acebeam K50 with this XHP 35 emitter? The K50 does look like a good candidate for it as it has 4S batteries configuration and comes with a big reflector.
3000 lumens, possibly 250+kcd, and that really sounds like a HID flashlight.
The only change I had to make from the 2S board was to upgrade my 10uf cap from a 10v to a 16V. All my other components were already 16V or more.
Initially I ordered the 16v caps from Richard, but since you asked about the other components I updated my bom with a 16v cap. Here is the list. I have not tried the 16v cap in this bom yet, but it has exactly the values as the ones I got from RMM so it should work.
Its been my experience that XHP-70s on a 12V board can be driven directly on about any 4 cells. The XHP-35 I have found in some cases you need to dial the PWM back just a hair or use a small resistor.
In some setups like when I used 4 x 26650s I changed the PWM value from 255 to like 225 to take the current down a hair. With perfect heat sinking 2.5A is really the max for this emitter.
IIRC using 4x 18350s I think I ran it wide open at 255. The lower powered cell in combination with the tail spring/switch was enough to keep the current where it was need.
All of the above info assumes direct bond thermal path ( sinkpad/noctigon) and good thermal path etc from there.
Kenjii I think RMM uses all 16V components so you should be good to go with that. Like I said above it will depend on what cells you use to power it. If you get more than 2.5A to the emitter you may need to either reset the PWM or add a small resistor.
Another way this LED could be used and current could be set to what ever is needed would be to use a zener modded 7135 based driver like a nanjg 105.
http://asflashlights.com/en/-diy-parts/34-3000ma-led-driver-board-custom-modes.html
You could pull a chip or two off one of these and add the zener diode. Then regardless of what cells you used the max output would be stable. The capacitor on this might also have to be changed though because I think they are 10V.
Has anyone ever run 4S into 7135s? If they are even doing minimal regulation they will burn up muy rapido. f=
Also, 7135s are only rated for around 7V output. We get away with 2S cells, but 4S? I guess someone will have to try to find out, but I think you'll probably get some magic smoke.
Yes, I have. Used an LD 2981 low drop out voltage regulator instead of Zener but the 7135’s were remote mounted on a separate heat sink as they were taking around 2V overhead. The biggest problem with series cells is the huge differential between full and empty cells, 16.8V down to 11V. It’s that 5.8V differential that makes 7135’s unworkable.
Thanks for the information. If I am gonna zener-mod a stock Nanjg 105C driver to work with the XHP 35, do I only need to change the capacitor into 10uf cap to a 16V one?
The extra resistor and the zener diode still remains R200 and 4.3V 200mW respectively?
EDIT: Just read Richard’s comment, and how about replacing all the 7135 on the Nanjg 105C with a single FET?
So the normal zener-mod with R200 resistor and the 4.3V 200mW zener diode would be able to work with 4 batteries in series to drive an XHP 35? Using FET driver.
