XHP-35
I think that makes sense, thank you.
Anyone has tried to mod the Acebeam K50 with this XHP 35 emitter? The K50 does look like a good candidate for it as it has 4S batteries configuration and comes with a big reflector.
3000 lumens, possibly 250+kcd, and that really sounds like a HID flashlight.
Hi,
is this FET-Driver in 4S setup suitable for the XHP35 HI or will it get too much current?
http://www.mtnelectronics.com/index.php?route=product/product&path=67_117&product_id=463
Greetings
Kenjii
in my test i DDed the emitter…
a driver just lowers the Amps at 4S…
maybe 4S2P might kill it :smiley:
The only change I had to make from the 2S board was to upgrade my 10uf cap from a 10v to a 16V. All my other components were already 16V or more.
Initially I ordered the 16v caps from Richard, but since you asked about the other components I updated my bom with a 16v cap. Here is the list. I have not tried the 16v cap in this bom yet, but it has exactly the values as the ones I got from RMM so it should work.
http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=96d1691809
These are the boards I use.
https://oshpark.com/profiles/ForgivenMatt
Its been my experience that XHP-70s on a 12V board can be driven directly on about any 4 cells. The XHP-35 I have found in some cases you need to dial the PWM back just a hair or use a small resistor.
In some setups like when I used 4 x 26650s I changed the PWM value from 255 to like 225 to take the current down a hair. With perfect heat sinking 2.5A is really the max for this emitter.
IIRC using 4x 18350s I think I ran it wide open at 255. The lower powered cell in combination with the tail spring/switch was enough to keep the current where it was need.
All of the above info assumes direct bond thermal path ( sinkpad/noctigon) and good thermal path etc from there.
Kenjii I think RMM uses all 16V components so you should be good to go with that. Like I said above it will depend on what cells you use to power it. If you get more than 2.5A to the emitter you may need to either reset the PWM or add a small resistor.
Another way this LED could be used and current could be set to what ever is needed would be to use a zener modded 7135 based driver like a nanjg 105.
http://asflashlights.com/en/-diy-parts/34-3000ma-led-driver-board-custom-modes.html
You could pull a chip or two off one of these and add the zener diode. Then regardless of what cells you used the max output would be stable. The capacitor on this might also have to be changed though because I think they are 10V.
Has anyone ever run 4S into 7135s? If they are even doing minimal regulation they will burn up muy rapido. f=
Also, 7135s are only rated for around 7V output. We get away with 2S cells, but 4S? I guess someone will have to try to find out, but I think you'll probably get some magic smoke.
Yes, I have. Used an LD 2981 low drop out voltage regulator instead of Zener but the 7135’s were remote mounted on a separate heat sink as they were taking around 2V overhead. The biggest problem with series cells is the huge differential between full and empty cells, 16.8V down to 11V. It’s that 5.8V differential that makes 7135’s unworkable.
How about using the dual pwm set up with a resistor+7135 on one and FET on the other.
Thanks for the information. If I am gonna zener-mod a stock Nanjg 105C driver to work with the XHP 35, do I only need to change the capacitor into 10uf cap to a 16V one?
The extra resistor and the zener diode still remains R200 and 4.3V 200mW respectively?
EDIT: Just read Richard’s comment, and how about replacing all the 7135 on the Nanjg 105C with a single FET?
You may be right. Now that I think about it the most I have done this with was 3 cells to 3 emitters and I did it slightly different even then.
Doing this it worked.
http://www.candlepowerforums.com/vb/showthread.php?201392-Poorman-Mutli-Lux-setup-method
4 may be a touch too much.
If you are using a zener mod then a 10V capacitor will still work because the zener diode limits the capacitor voltage.
So the normal zener-mod with R200 resistor and the 4.3V 200mW zener diode would be able to work with 4 batteries in series to drive an XHP 35? Using FET driver.
http://www.candlepowerforums.com/vb/showthread.php?201392-Poorman-Mutli-...
I don't believe you are subjecting a 7135 to 16.8 volts when you hook up to 4S cells. You have to take into account how much voltage is being used by the emitters. For instance, when you hook up 4S emitters directly to 4S cells, you are not subjecting each emitter to 16.8 volts. Each emitter demands a certain amount of voltage for the current available. Cell voltage sags as current increases an equilibrium is found.
When current is limited by the 7135's, there is less sag. So an excess voltage situation is created. This is the voltage that the 7135's see. The data sheet says voltage limits specified are relative to ground. That is just my theory and not based on anything I have read. So it could be completely wrong.
That makes complete sense. The voltage across each 7135 is going to change as the battery drains, as long as the Vf of the LED is within 7v of the input voltage all should be fine.
PWM is where I start to get hazy, with the driver still putting out short high current bursts to create a lower RMS power, will the 7135’s act like they’re driving an output with a lower Vf, or will the interaction be just like when PWM = 100%, just pulsed?
If it doesn’t act like just a pulsed version of the full output, that could be why they might die in a setup like we’re talking about.
I don't understand that aspect either. I know that 7135's hate heat and they run cooler as lower PWM's. I guess the breaks between on pulses allows them to cool off some.
I really can't picture 7135's dissipating 7 volts though. Even 1 volt gets them real hot. Proper heat sinking is critical.
My bad. RMM was right. Just now I tried this with 4S behind the zener modded 7135 driver + an XHP-70 and it does not work. I was never able to get more than 600ma from the driver, and the modes would not change.
I also tried this with 4 gen 1 XMLs and the poor mans setup and the result is not much better. I was able to get full power but only for a short time and after a bit I was not able to change modes again.
Neither setup killed the driver, but it did get hot very fast. In the XHP-70 test I even had it pressed into a copper slug similar to a C8 pill. Running it like this for long would have killed it I think.
The 7V limitation really only applies to the Vdd pin since the voltage drop from led- to ground is whatever is left after deducting the led Vf. There isn’t a hard ceiling as far as I could find other than above 700mW heat sinking becomes critical to maintain operation. 700mW translates to a drop of 2V. The other fine print item I’ve mentioned before is noting the benefit of up to 1000^2 mm of trace area for heat sinking each chip. Pretty sure there isn’t that much trace area available unless you mount each one on a 12.6mm board with nothing else but copper on each side(pi x 12.6 x 12.6 x 2 = ~1000). Given adequate heat sinking they can be driven much harder but I don’t believe they can share that sink with another heat source unless it is sized for both.
This seems ideally suited for a MTNmax driver set to 2-3A though.
