I’d expect an Efest Purple or LG HE-4, Samsung 30Q, to do higher than 12.8A. Hence my 15A wager…
Still, very impressive lot of output in a High CRI rendition, no doubt! :bigsmile:
Edit: Assuming you did spring bypasses, right? Through board on the switch? What size wires did you use? I’ve taken to using 18ga for these projects to allow every possible bit of current to flow. 16 ga if I can fit it in.
When I measure current the tail cap is not used so the switch does not count.
But with this high currents, I will do the through board switch bypass soon.
On my DMM I used 20cm short 18 AWG wires, but I think it is not that accurate at over 10A.
edit: Still happy with the light, the triple is installed in a mini S2+. I managed to squeeze a 18500 cell into it using the shorter S2 pill. The low modes are very useable and on the highest mode it is a very (!) bright, very small, floddy light. But also after 20 sec in the highest mode the light is too hot to hold
This is what I was trying to decipher from that photo. On my monitor, the S4 die appears way too yellow compared to anything I’ve seen in a 2B tint. The Nichia looks like the 2B tint, and the 2B looks like it would be the 219C. But as I linked to before, kelvin actually tells us nothing about true CRI. It still doesn’t explain that extremely deep yellow tint in the die corners on an S4 2B bin. I suspect the remaining polymer on the die of the 219C is actually messing with the amount of blue within focus, acting somewhat like a pre-collimator. It’s just that, it usually doesn’t occur so much without a full dome. Or I should say, usually doesn’t occur that much, with so little dome left.
The 219C appears closer to an “off-white” ~4500K with slight red fringe around the image, the Cree G2 S4 2B looks like it’s across the spectrum on my monitor, like 3300K tint in the corners. It looks de-focused, because of the corners shifting towards red spectrum and the center being colder in appearance. Hmm…. Beats me!
What is missing from the analysis is the fact that it’s not a white wall, creamy beige PC color is more like what it really is. I’m sure that’s why they look so yellow. The image was more for intensity, size, and relative color difference as opposed to a controlled white wall shot. It would have been good of me to state that it wasn’t a white wall in the original post of the picture
I received my 219c's from Cutter today. They were very well packed, but I was very disappointed that they were not on Noctigons as the product page indicated. The Page clearly shows them on 20mm Noctigons and says mounted on 20mm base. It does not say an aluminum base. I would prefer them to not be on any base if not on a Noctigon. Now I have to buy some DTP bases and subject the emitters to reflow heat 2 more times.
Hmm yeah I definitely thought they came on Noctigons. I almost ordered some 4000k from them because I figured the Noctigons would make the cost worth it.
Oh noooo. for some reason I thought these were bare. That is a really, really deceptive listing. Cutter has a presence here and posts - can't find the name, but if you find it, maybe you can pm. Really weird they don't offer them bare. I know their site is many times wayyy out of sync with what they really have. I think Mrs.DNF told me.
Before you panic, check those stars. Cutter has their own DTP mcpcb’s and they are no different from Noctigon or MaxToch or SinkPAD. See if you can detect the thermal pad beside the emitter and touch it with one probe while contacting the base with the other, checking for continuity. My bet is your DMM will beep at you and all will be well with the world.
welight is the Cutter contact here. I wonder when you ordered them ImA4Wheelr whether welight was on holidays (he still is) and there is a mistake? I picked up six from there today myself along with the Noctigons separately.
I haven't run across an aluminum DTP that worked nearly as good as a copper DTP yet. None the less, these don't appear to be DTP. I don't want to do any testing that will mar them in case I end up returning them. They have no markings and the thermal traces indicate non-DTP. I could not get continuity on any of the thermal pad solder blobs, but I didn't try to clean and scrap them to make sure flux coating was not interfering.
I imagine the ad or lack of Noctigons is just a mistake. I emailed Cutter last night. I just PM'd welight.
