I’m really surprised forward switch is most popular. I can’t think of any custom BLF lights tha use forward switches and we seem to do a lot of custom runs.
I like forward switch, I wish more budget lights used it.
That failed, IMO, because of switch/driver issues when switching to next mode gave no output and threads, that are made out of plastic on plastic body, wore out with very, very little use.
True story bro, thats how it is on mine. Bought two, one for me, one for friend, but not sure if he ever used one so cant report on his specimen.
I have the DQG AA in Stainless Steel Neutral White form… Great light. Tiny… Very bright… Great tint… and also tough.
Not a big fan of the “twist off to turn on” approach though… Because it also switches off again if you twist it “too far”… so you have a small area of movement between on and off. This is alleviated a little by the head not having much “play” in it… not much chance of it switching modes accidentally while being held…
If it was a clicky, it would be much better (but obviously also probably 1-2cm longer).
It’s also a nightmare to mod… I wouldn’t even try it I don’t think… I let the Mrs have it (oo err), as it fits in her handbag quite well.
I think any future AA flashlight I would want to be able to easily mod - even if its just an emitter/reflector swap etc… To help future-proof it a little…
Umm… forward clicky and e-switch are two very different things. What exactly are you trying to say about forward working with e-switch? Do you mean two switches?
Okay, I’m still a newbie, so, what advantage do you get with a forward switch in the tail versus a reverse switch or no switch at all, on e-switch lights?
I wonder if Simon/Convoy would build a 1 X 14500 / 2 X AA light. I would like a well made, affordable, 2-3 mode, no blinkies, maybe an XPG2 or XPE2 light. Shadow made a cool looking Mini TC6 that I never got around to purchasing.
I recently got a Jetbeam WL-S1. My every day pocket carry is a Single AAA light but the Jetbeam is very versatile. It can use CR123a, RCR123, 16340, Alkaline or NiMH AA, 14500 (without carrying an extra battery tube) but what I use in it is a lithium ion that combines the diameter of a CR123a and the length of the AA, a 16500 purchased from eBay. With this battery and its larger head and reflector, it approaches the BLF A6 SE 18650 power and will still fit well in a loose pocket.
That would certainly be a cost effective and popular choice. A slimmed down S2+ using an 1 X 14500 / 1 X AA + extension tube option would be excellent.
The problem with forward clickie is that switching modes is a bit awkward with it. When you have 2 switches, you can have the momentary on at the tail switch (that is advantage for some), and switching modes with electronic switch.
I am personally fine with reverse clickie or e-switch only.
