Thanks, I think I understand now. For me, a reverse clicky is fine and just e-switch is better. No need for two switches on any of my lights!
Instead one driver that supports both aa and 14500, why not have two heads with different drivers, and we can order with either or both heads.
I very much like the 1xAA format, in fact it’s what got me hooked on flashlights.
I would be the first to buy a custom BLF 1xAA light if it happened.
My ‘bug-out’ gear is AA powered or compatible so I could use something like this, and it would be a very good ‘gift light’ for non-flashaholics too. 14500 compatibility would be nice but not a deal-breaker. L-H or L-M-H would be all I need, L could be moonish but not too low. Priced right, I’d be up for a few or more.
AA is a world-wide standard, no matter where you go these are readily available, which can’t be said of many cell sizes we’re used to.
Phil
Im a big AA and 2xAA light fan.
I like them for ease to get batteries for and to use with eneloops.
Include me, as well, the AA camp....would be very interested in a 2xAA.
There were some very good EOS 1xAA drivers available for a while from Int-Outdoors, but that supply seems to have dried up. I’ve modded three of my old Fenix L1P carcasses into very useful 3-mode lights. Those drivers would tolerate 2xEneloops in good humour, but over-volted at the sight of 2 alkies - and went plumb haywire with 2 lithium primaries. I only have a couple of those drivers left; I wish I could source some more.
Of the current crop of 1xAA’s out there, the one I’m lusting after is the Lumintop ED15. Very impressive run times. It might make a good BLF candidate, with a neutral emitter of some sort.
I very much like the 1xAA format, in fact it’s what got me hooked on flashlights. I would be the first to buy a custom BLF 1xAA light if it happened.
BLF members rule number 1.
All late comers to the end of the line.
Pulling rank huh?
:bigsmile:
I personally like drivers that support both 14500 and nimh
The joy of pocket rocket without worry over hard to find batteries
I don’t like them, because it is too easy to run down a 14500 battery. Some expensive drivers try to keep track of what voltage type the cell is, but I can’t see that being reliable. I suppose it would avoid having to carry one more light sometimes, though.
pleas let it be something that can run on single or double AA! I love the 14500 format too!
It would be awesome if we could provide the whole package, as with the new K6: design the light and design the AA boost-driver with Attiny and BLF-firmware.
But who will be 'we' ??
'We' is someone with a lathe who can make a goodlooking host as an example for a manufacturer to copy, that is compact (compact is what AA size is about IMO) but still uses some standard parts, like 16-17mm switch board with small Omten, 14x8mm tail cap, and a 17mm driver, perhaps with a 18mm reflector like the Ultrafire C3 (the C3 is my personal favorite AA flashlight shape, but it has many -easily resolved- design flaws, so it should not be literally copied) or even the standard 20mm reflector that is also in the BLF-A6 (giving it a head diameter that is a bit wider than 'tubestyle).
And 'we' is also a gang of driver fiddlers who go ahead with the Attiny13 boost driver project and make firmware for it with nice modes.
And 'we' is someone with good contacts with seller and manufacturer to make the production and sales happen.
Hehe, two heads you say :D? AA regular one and 14500 wider and deeper reflector for throw?!
I PMed Simon to see if there was a possibility of a Convoy AA light in the near future. If he can give us one with a few choices like he does with the 18650 lights than that might be an easy, affordable solution. I am not sure if he will get back to me though; he has been AWOL for a while.
There’re a couple of reviews that just popped up this morning for the Manker T01. That seems close, but it’s a side switch only.
(warning: personal opinion coming up) I like everything about the Manker T01 except the styling: too MadMax for me, and I dislike grey too. And although I love its wide reflector for its performance, for a BLF-AA I think it is too big. (we should lend the Manker driver design: 500 lumen OTF from a single NiMh battery is a great achievement, just the UI is awkward)
Wow, that T01 does look very good!
A Convoy S6 style AA light would be great; its the kind of thing I am after (hence my use of a Thorfire TG05 currently).
Narrower, and shorter than the S6 obviously.
With the driver performance of the Manker T01 driver, if possible.
Although I would be perfectly happy with just 500ma going to the LED on Max…
That Manker T01 with an optional extension might just fit the bill!
The only good looking AA lights I can think of are the Sipik SK-58 and a 2 x AA that looks nice but came with very cheap works. There is a type of 1xAA light with similar shape to the SS-5039, but it isn’t nice. I can’t say why except that the metal is too thin and the surface too smooth.
