There were some very good EOS 1xAA drivers available for a while from Int-Outdoors, but that supply seems to have dried up. I’ve modded three of my old Fenix L1P carcasses into very useful 3-mode lights. Those drivers would tolerate 2xEneloops in good humour, but over-volted at the sight of 2 alkies - and went plumb haywire with 2 lithium primaries. I only have a couple of those drivers left; I wish I could source some more.
Of the current crop of 1xAA’s out there, the one I’m lusting after is the Lumintop ED15. Very impressive run times. It might make a good BLF candidate, with a neutral emitter of some sort.
I don’t like them, because it is too easy to run down a 14500 battery. Some expensive drivers try to keep track of what voltage type the cell is, but I can’t see that being reliable. I suppose it would avoid having to carry one more light sometimes, though.
It would be awesome if we could provide the whole package, as with the new K6: design the light and design the AA boost-driver with Attiny and BLF-firmware.
But who will be 'we' ??
'We' is someone with a lathe who can make a goodlooking host as an example for a manufacturer to copy, that is compact (compact is what AA size is about IMO) but still uses some standard parts, like 16-17mm switch board with small Omten, 14x8mm tail cap, and a 17mm driver, perhaps with a 18mm reflector like the Ultrafire C3 (the C3 is my personal favorite AA flashlight shape, but it has many -easily resolved- design flaws, so it should not be literally copied) or even the standard 20mm reflector that is also in the BLF-A6 (giving it a head diameter that is a bit wider than 'tubestyle).
And 'we' is also a gang of driver fiddlers who go ahead with the Attiny13 boost driver project and make firmware for it with nice modes.
And 'we' is someone with good contacts with seller and manufacturer to make the production and sales happen.
I PMed Simon to see if there was a possibility of a Convoy AA light in the near future. If he can give us one with a few choices like he does with the 18650 lights than that might be an easy, affordable solution. I am not sure if he will get back to me though; he has been AWOL for a while.
(warning: personal opinion coming up) I like everything about the Manker T01 except the styling: too MadMax for me, and I dislike grey too. And although I love its wide reflector for its performance, for a BLF-AA I think it is too big. (we should lend the Manker driver design: 500 lumen OTF from a single NiMh battery is a great achievement, just the UI is awkward)
The only good looking AA lights I can think of are the Sipik SK-58 and a 2 x AA that looks nice but came with very cheap works. There is a type of 1xAA light with similar shape to the SS-5039, but it isn’t nice. I can’t say why except that the metal is too thin and the surface too smooth.
I think a modded hugsby xp11 or 12 would be nice, Tom E’s modded TG06 would fit the bill and last but not least a BLF version of the olight s15 would be great too.
Beautiful shapes have compound curves, so they are almost impossible to prototype on a manual lathe. The best way would be to make a prototype in clay and then have it produced on a numerical control lathe. There was someone on here who had worked with NC. There was a thread of beautiful 3D printed lights, but none of them could be mass produced.
Surely the majority of people would want a slim pocket friendly light rather than anything too shapely, tactical or otherwise? The look of the Convoy S6 shrunk down suitably I would have thought would have been ideal.
The battery tube of the SS-5039 has a smooth curve to it without being any fatter or heavier or weaker than a cylinder would be, and without taking any longer on the machine. It is a bit thinner near the center and a bit fatter near the ends. That makes it beautiful and easier to hold and improves the overall strength relative to a cylinder or any combination of cylinders with the same average radius. The head has a bit of extra metal, that has little function until I put new insides into it so that it needs the extra for cooling.
That is a curvier shape, though I miss the flutes. I might like a light the shape of the 5050 if it were made like the 5039, sort of solid and with an interesting grippy surface. They say beautiful pottery is supposed to “breath”, to look like it were alive, rather than mathematical like Ancient Greek potter. The 5050 looks almost like the curve could be expanded in a few terms of a power series.
My other favorite shape is the Yezl t9, but that is not the sort of light being discussed here.
Added: I don’t see the SS-5050 on the Smiling Shark Web site. Maybe it isn’t really a Smiling Shark, or maybe they aren’t emphasizing it.
