Hey Tom, sorry for the slow response to your question. The method I now use to measure amp draw at the tail is this (thanks to Dale);
I use a 3” piece of 12ga, solid copper romex, bent into a u shape. I then do the standard bypass procedure on the tail. As you can see my readings have went up considerably since I began using this method. I, like you, was frustrated at how much different my readings were compared to other peoples, even on the same lights. The A6 that I won in Dale’s generous giveaway showed somewhere around 1A less than he achieved, when I received it and measured with my “thick short leads”.
Here’s an FYI to add more data to this topic. I bought 2 A6’s in this GB. 1 with 3D tint bin, the other with 1A tint. The 1A was the light that hit 6.7a after both springs were by-passed. I have now done the same mod to the 3D light with different results. 5.9a@4.18v with the same 25r cell, measured with the clamp meter. So it appears that binning does have something to do with the hi amp reading (as mentioned by Djozz, and Dale.
I never got around to building a “light pipe” to measure lumens, so I don’t have that data to add to the story. I did however, measure before and after lux on both lights and will post if anyone is interested.
I really dunno what's going on. I used to have a pretty high confidence in my UNI-T DMM equipped with the 14 AWG short length wires. It's certainly dead-on with 7135 based drivers all the way up to 4.9A or so. I work with a super tech who swears the internals for measuring amps in the UNI-T is as good as any Fluke meter. This guy has like 6 UNI-T's he uses regularly, plus a couple of Flukes. It's hard to describe this guy (the super tech), but he is one of the smartest people I know, so I always have a high degree of confidence in what he states and recommends, when he is serious that is...
I know there's a lot of anomalies going on at times in my measurements - things I can't explain. I suspect mostly it's contact/ground issues. Wire ends need to be cleaned or re-soldered (oxidation), contact by holding a wire end against the lip of a light tube is not always the best method, etc. Still, there could be major inaccuracies in 5+ amp range I didn't know was there.
If moon doesn’t work but everything else does (modes 2/3 and 3/7 should be visibly different from each other), it’s also possible that the 7135 chip could be a different type. The 350mA ones generally have a lower and more consistent moon level than the 380mA ones, and I expect there are more than just two types.
The firmware says to use 2/255 phase-correct PWM, which actually works out to 4 on “frames” in a row out of every 512. Some 7135 chips need 3/255 or even 4/255, and it also depends on the type of emitter. Old XM-L LEDs need a higher moon level than a newer XM-L2 or XP-L.
In other words, moon is pretty sensitive to relatively small hardware changes. This is a lot of the reason why cheap torches generally don’t have moon at all. And if any component changed or was out of spec, it could cause moon to fail without visibly affecting anything else. I hope BG can send you a new driver.
Ha! Cool. You are correct TK. I have many Dr Jones programmable drivers with super low moonlight modes. They are quite inconsistent depending on the hardware. I think you are correct in your theory. Good call.
I'm a bit confused here .. you have two lights that work . why not just figure out whats wrong with it and fix it . they don't all have to lego since they are the same light .what does lego have to do with it and what would you do with an extra couple bodies and a tailcap?..
sounds like you need a body or a taillcap . not three .
at this rate it may just be more prudent to do some work on the tailcap if you can ...it sounds like what you have is a common problem on some of these lights. but what do i know i'm still waiting on mine ( while you guys are having all the fun )
i still reserve the right to complain at a later date ...
I just checked my current sense resistor set-up with the power supply set at 6.0A (ps reading=not dead accurate, ~0.1 á 0.2 A wrong): voltage measurent with probes directly on the resistor leads: 57.7mV, probes on top of the terminal block connectors (this is where I place the probes for current measurements): 60.3mV, probes at the end of the solid copper leads: 72.0mV. So the whole of connections of the sense resistor gives 2.4 mOhm on top of the 10 mOhm of the sense resistor. so the current drop from a XP-L at 6A caused by the sense resistor in the circuit is about 0.3A.
For perspective, I measured the voltage over a BLF-A6 tailcap with 22AWG silicon wire spring-bypass, measured from the top of the spring to the aluminium ridge that is screwed against the battery tube. When applied 6A, I get 124mV, causing 0.5A drop for the XP-L compared to directly connecting the batt- to the battery tube. So adding a well-build tailcap in the circuit is causing a bit more voltage/current drop, but is in the same range as adding the current sense set-up. That is convenient.
One of the things that is contributing to what burnsd is saying is that the threads on the A6 are anodized, and so the way that the light is designed is that the end of the battery tube at the tailcap end HAS to be able to contact the retaining ring inside the tailcap in order to complete the circuit. If the end of the battery tube is “short” by some tiny bit, it won’t contact the retaining ring and you won’t get any light no matter how tightly you screw in the tailcap (so note that this is not a battery length problem either).
That’s why putting a wire inside the tailcap helps sometimes… basically it moves the contact point of the retaining ring “forward”.
I had to put a wire ring inside my A6 in order for it to work.
I have one of the unanodized A6s coming (it is taking FOREVER to get here) and that should NOT have this problem since the battery tube is not anodized, the contact is made by the threads themselves, rather than by the end of the battery tube contacting the retaining ring inside the tailcap… that’s the theory anyway :)!!
As far as I see it, the A6 tube is not in contact with the tailcap retaining ring (too small in diameter), it only gets in electric contact with the bare (not anodized) part (ring) of the tailcap.
This is one of the things I don’t understand in the construction of the A6 host, the other is the placement of the seal in the head (behind the glass lens).
Yes, “shelf” seems to be a good description for this part of the tailcap.
(English is not my mother language, so it’s sometimes difficult to find the right technical terms. )
Sometimes we get carried away when obvious solutions are right in front of us.
3 solder blobs on the ground ring of the driver, about 10 seconds, and the problem of a short tube is fixed.
I have yet to see one with the contact at the tail cap having issues. Again though, pull the retaining ring on the switch, put 3 blobs of solder on the ground ring around the outer edge, replace the retaining ring, and there should be no problem. A matter of seconds if indeed a short battery tube thread is the issue. Not sure what the answer will be for non modders, but a paperclip bent into a circle and placed under the retaining ring will do the same thing as a few solder blobs and take little more time as far as the tube length issue goes. Anyone should be able to accomplish that one.
I have been finding that this driver they built is sensitive to the 7135 regulation chip. So it could be that chip causing issues. TK is doing a lot of testing on that line, so she’ll probably have it figured out directly.
Is the resistance of a paper clip going to be a problem? I’ve found that I have to tigten the tail cap way to often.
Every time I need a light, tube is not making contact.
You can always find a short piece of solid copper wire, like that in House Romex. The center wire from a bit of cable wire (Television cable, that solid center piece) works fine.
The conductance of iron is lower than brass or aluminium but the path is so short (1mm) that you will not notice (compare to a steel spring: a path length of several cm)
i received my unit but unfortunately i see that the base where is the led, it’s not with thermal paste, or at leats there is thermal paste but it is NOT attached to the aluminum pill of the head, so heat is not dissipate
realista, are you able to de-solder the leads on the emitter star and remove it? You can file off or sand off the edges so the star will fit better and then it will seat properly.
I have no idea why they made the emitter shelf area that tiny bit too small instead of the other way around.
Sorry to hear about the issues.
I gotta say folks, having just recently started working with a lathe (the BLF Lathe of all Lathes) I am learning that every tiny detail MUST be right or the other bits and pieces dont’ fit cleanly. It’s much more difficult than one might think.
