I’ve been stuck with a DOA BLF A6 since August 24th. I ordered two and one works flawlessly. I was able to take the tail cap from the working light and it makes both lights work. The tail cap from the non-working light will not work on either light. The switch is fine, the contact point is the issue. Neal sent a new tube, which I received yesterday and it didn’t fix the issue. I asked him to send a tail cap to begin with but he said that it was an issue with the tube. The light is still dead…
BG just confirmed they will send me a replacement head. I told them there was no need for a entire new head since only the driver is bad, but they insisted.
There is also a small problem with the centering ring being too tall causing it to “turn” the LED when tightening the bezel, but a bit of sanding and a reflow minimized the issue. Meanwhile my A6 remains unused, I’m a bit disappointed since I waited so long and expected a lot from this light, really wanted to see the A6 FW in action.
I’ve been pretty busy lately but I wanted to post that I received another 5a and a bare 3d. I tried to lego the bare with two of my anos to no avail. I didn’t put a caliper to anything but used my knife as a depth guide and the bare tail cap is definitely deeper to the “shelf” that meets up with the tube compared to the others. The bare would have no doubt been a d.o.a. had it been anodized.
I would recommend people first ask for a tailcap and/or new tubes as the tube thread length on mine seem consistent. But not the tailcap depth.
I guess I’m missing something but it seems to me that it’s less effort to put a few solder blobs on the retaining ring or put a metal shim under the retaining ring to raise it enough to make contact. It’s only a $25 light and if fixing it takes less than 15 minutes then that’s the approach I would take.
I agree. Had mine come in doa -I personally would have. But at the same time I can’t blame people for wanting bg/manker to make it right. I think the idea being that if manker is going to do more business with us (cu/ss lights) they should at the very least test everything that leaves their shop. But in the end…… solder blob/paper clip is way less headache!
I like that idea! But on the tail the tube is really meant to touch the cap outside of the ring. I just looked at one of mine and you’d be lucky to get another ring threaded in but there is one thread showing.
I finally modded my A6 with a triple and bypasses inside both springs. Output (and heat) is really stunning for such a small light.
I get a verry audible whine as well. The higher the current the louder it gets. Retouched all solder points on the board, and it’s also there without the springs and tailcap! Would drowning the whole board in epoxy help to get rid of the sound?
I understand that this is caused by rapidly switching between no current and 10+ Amps.
Basically had problems with bad soldering on 7135 chip. Could not get the head open, maybe mine was glued, I don't know. Contacted banggood general customer service email on 23 September. Got reply on 24th, offered to send me driver only. Declined as I suck at soldering and I can't get the head open, insisted on full head instead. Agreed and head was sent out on 27th September. Today it cleared customs and on the way to me, should receive it sometime next week.
Pretty prompt response I would say... on another note, how do I open up the head?, pliers and elbow grease?, I'm assuming it unscrews at the groove right above the logo.
Both wires have dry dry solder joints.
This may not be the cause of your current problem, but it will not be reliable as is.
If you have problems with the low modes, the 7135 chip probably needs to be re-flowed.
(Try to see if the there is solder below the tab on the back of the chip.)
Flashlight won’t turn on at first press of switch, nor second most of the times. When it does, non-click presses scroll through a weird set of modes, with no moonlight but two identical low modes, a mid, and two identical high modes (this is as far as I recall) and the light will eventuality turn off itself.
How to reflow the 7135 chip? Completely de-solder and remove it? I have very basic soldering skills, this is the most advanced stuff I have ever done, but I don’t get any reply from “support”
Add some liquid flux at each pin and the tab. Then add a little bit of solder to each pin with a hot (750 F) soldering iron.
The flux will make the solder flow where it needs to go.
Do not spend more than 2-3 seconds per pin with the soldering iron. Do not heat it up so much that comes totally free, allow at least one pin to cool down so the chip stays in place.
OK, so, the switch is FRIED.
Maybe I killed it definitively, maybe it was defective beforehand. Any suggestions? Can I cannibalize another light’s switch?
