DC-Fix Diffusion Film Sale
Pm sent. Thanks.
awesome, thanks Boaz. I have DCFix on a couple of lights and it def does the trick.
Again, thanks! Ordered... Look'n forward to trying it out.
Pm sent. Thanks.
Thanks Jeff!
Did you change the emitter as well, or just try the film? Is the DC fix good, but just not good enough for this?
I pls on reflowing a Nichia 219C on mine…
I swapped to Nichia 219. The film is good for many applications. I just wanted a very floody beam and it wasn’t enough for the xtar.
Boaz,
Thanks for bulk-buying this for us, and then sending little strips of it all over the world.
What a hobby!
PP sent.
Cheers,
Splott-Light :slight_smile:
If like me you're a beam profile snob
This diffusion film does a great job
Of creating a light
That is evenly bright
Why be part of the glaring spot mob ?
I am going to try it, worse come to worse, there are two sides to the lens that I can DC-Fix… Lol
Agreed, thanks Boaz!!
“What a hobby!”
-Yakov Smirnov
:smiley:
PM’ing you - would like 4 sheets (or whatever they are)…
Jim
Boaz:
Received mine in the mail today. Thanks!
Now, which flashlights should I try first? :nerd_face:
Got mine in, thanks! I am impressed, most of the accessories like this seem overhyped, but the DC Fix works very well. I think I will be using this on more than I thought, including o e of my BLF A6’s!
How do you ‘stick’ it up on the lenses? Thanks
Remove lens from light . Clean it with alcohol . Cut a piece of film slightly larger than the lens . Peel backing off film and apply it to the lens , making sure to get all of the bubbles out . Use a razor blade to trim the film by cutting flush against the edge of the lens at a 45 degree angle .
I usually put the lens back in with the film on the inside . This allows the bezel O-ring to seal properly .
Any questions ?
I’ve got a kinda throwy headlamp currently XM-L T6 that I want to put a 365nm UV emitter into but would like the beam to be more floody… has anyone tried using this film on UV lights before?
Could not be more well explained than this. Perfect and thanks _
Nice Jack !…
Thats the proper way to do it . I usually just take out my socket set ,find one that fits inside the bezel and use it to trace a circle , Carefully cut it out and stick it on the outside of the lens .You want to do a pretty good job so you don’t have any light leaking around the diffuser .
I now have this on my BLF A6, the one I have an XPL HI swapped in place of the stock emitter. The previous hotspot is now well blended into the edges of the beam. It really does give a good smoothing to the beam profile.
