testedandbaked, it was 4 of em…read Quad… I built a Quad with Carclo optics in a Convoy M2.
As such, a Quad with Cree’s won’t draw 17A even with 18ga leads. I knew my Ti X6 did 21.3Amps on the 20ga leads so I tried to limit this one a bit with smaller wire.
Single Cell, only one 18650, I’ll probably test an LG HE4 and Samsung 30Q as well as the Efest 35A, but I used the LG HE-2 for this one initially.
Point being, the lower Vf of these Nichia’s can lead to some crazy high current being drawn, so be careful what you build with them!
Interesting test Dale, but I’m curious as Djozz tested the 219C to produce over 1000 lm at 4A, but you’re only getting 3300 lm? it is because of the loss with the carclo optic?
You easily get this loss in a flashlight. 17A is 4.25A/emitter, in djozz-lumen 1125lm/emitter. Out-the-front Dale measured 825lm/emitter, that is 27% less. This is not bad. The factors involved are optics loss, heat loss, and differences between Dale's lumen and my lumen (the variation between the personal 'lumens' appears significant, we all try the best we can and it can still easily differ by 20%)
Like djozz says, there are variations between testing styles and equipment. I believe djozz bench tests while I test an actual flashlight, so it’ interesting to see what the emitters are capable of vs what we can expect in real time.
Also, on this light, the small TIR in the optics is going to be less efficient than a larger single TIR or reflector, just primarily due to the small size necessary. Remember, there are 4 TIR’s crammed into a 24mm diameter optic here. 4 of these 219C’s in a larger quad with bigger lens/optics would almost certainly yield a very different output.
Maybe I’ll put 4 of these into my SupFire M6 and see what they do with the larger reflectors in a modified soup can light? It’s doing around 5000 lumens now with XM-L2’s.
Edit: By the way, a freshly charged Samsung 30Q showed 17.86A for 3456.90 lumens.
Another question, when swapping the XP-G2 for a Nichia 219c, how do I align the Nichia? I see nichia's "cathode mark"; do I position this corner of the Nichia where the XP-G2 has its "dot"?
I searched for "XP-G2 cathode mark" but couldn't find a clear answer. Are all LEDs marked with a "cathode mark"?
If you’re looking at the pad with the positive contact strip on your right and the negtive contact strip on your left, then the Nichia 219C has the larger white blob bottom left. That out of sorts white blob is the cathode marker.
How does that relate to the XP-G2? The XP-G2's dot would also be at that bottom left? (i.e. Nichia blob is same location as XP-G2's dot? This is a quad board out of a bike light I'm working on.
I've not tried it yet. I'll post up pics and my impression in my bike light thread when I'm done (see link in my signature). I plan to also post my emitter swap video along with pics over in the MTBR BT40S thread.
i almost finished the mod of a Roche F8 in desert yellow.
The light got a heatsink with 18mm height with 4mm hole. The heatsink is screwed to the pill with two M3 screws. I plan to fill the gap between heatsink and head with Fujik for better heat transfer, but that is a separate step. The 3XP MCPCB is soldered to the heatsink.
Fully assembled. The light uses a Carclo 10507 optics but i will try 10508 later, because i think the beam could be i bit broader. I don´t need much throw from this one. The light is powered by a MTN FET Driver and a LG HE2 battery.
Here in comparison to 2x BLF Ti (XP-G2 S3; Nichia 219B) and a Sinner (Nichia 219B dedomed). Multicolor
I measured lumens via ceiling bounce and got 2800 Lumens at startup The light gets hot pretty fast but not as fast as i thought. My multimeter can only measure up to 10A but i think here are flowing more than 12A. Based on Dale´s Quad Nichia this was the plan on mine I really like this light! I am still a bit scared about the tiny little tailcap switch to melt …
Same here. Just added one to a C8 (replaces an DD XM-L2). With a stacked 7135 driver (~2.7A) its pushing around 35K lux (XP-G2 in S4 bin should be around 38K with the same setup). With the linear driver its still pushing 2A with the battery down to 3.5V (1/3 of capacity left) so looks like the low voltage will help it stay in regulation for quite some time. I think I will be adding these to a number of Eagle Eye X6s and Convoy C8s for friends and family.
Can’t same I’m blown away by them (was hoping for a little more throw) but they are a nice alternative to XP-G2 and would be excellent for headlights, worklights etc. Cheap to.
