Like djozz says, there are variations between testing styles and equipment. I believe djozz bench tests while I test an actual flashlight, so it’ interesting to see what the emitters are capable of vs what we can expect in real time.
Also, on this light, the small TIR in the optics is going to be less efficient than a larger single TIR or reflector, just primarily due to the small size necessary. Remember, there are 4 TIR’s crammed into a 24mm diameter optic here. 4 of these 219C’s in a larger quad with bigger lens/optics would almost certainly yield a very different output.
Maybe I’ll put 4 of these into my SupFire M6 and see what they do with the larger reflectors in a modified soup can light? It’s doing around 5000 lumens now with XM-L2’s.
Edit: By the way, a freshly charged Samsung 30Q showed 17.86A for 3456.90 lumens.
Another question, when swapping the XP-G2 for a Nichia 219c, how do I align the Nichia? I see nichia's "cathode mark"; do I position this corner of the Nichia where the XP-G2 has its "dot"?
I searched for "XP-G2 cathode mark" but couldn't find a clear answer. Are all LEDs marked with a "cathode mark"?
If you’re looking at the pad with the positive contact strip on your right and the negtive contact strip on your left, then the Nichia 219C has the larger white blob bottom left. That out of sorts white blob is the cathode marker.
How does that relate to the XP-G2? The XP-G2's dot would also be at that bottom left? (i.e. Nichia blob is same location as XP-G2's dot? This is a quad board out of a bike light I'm working on.
I've not tried it yet. I'll post up pics and my impression in my bike light thread when I'm done (see link in my signature). I plan to also post my emitter swap video along with pics over in the MTBR BT40S thread.
i almost finished the mod of a Roche F8 in desert yellow.
The light got a heatsink with 18mm height with 4mm hole. The heatsink is screwed to the pill with two M3 screws. I plan to fill the gap between heatsink and head with Fujik for better heat transfer, but that is a separate step. The 3XP MCPCB is soldered to the heatsink.
Fully assembled. The light uses a Carclo 10507 optics but i will try 10508 later, because i think the beam could be i bit broader. I don´t need much throw from this one. The light is powered by a MTN FET Driver and a LG HE2 battery.
Here in comparison to 2x BLF Ti (XP-G2 S3; Nichia 219B) and a Sinner (Nichia 219B dedomed). Multicolor
I measured lumens via ceiling bounce and got 2800 Lumens at startup The light gets hot pretty fast but not as fast as i thought. My multimeter can only measure up to 10A but i think here are flowing more than 12A. Based on Dale´s Quad Nichia this was the plan on mine I really like this light! I am still a bit scared about the tiny little tailcap switch to melt …
Same here. Just added one to a C8 (replaces an DD XM-L2). With a stacked 7135 driver (~2.7A) its pushing around 35K lux (XP-G2 in S4 bin should be around 38K with the same setup). With the linear driver its still pushing 2A with the battery down to 3.5V (1/3 of capacity left) so looks like the low voltage will help it stay in regulation for quite some time. I think I will be adding these to a number of Eagle Eye X6s and Convoy C8s for friends and family.
Can’t same I’m blown away by them (was hoping for a little more throw) but they are a nice alternative to XP-G2 and would be excellent for headlights, worklights etc. Cheap to.
I got the bare LED's from Richard, so I had to reflow.
I had a spare board that was the same diameter & thickness as the original, so I just flowed the 219c & it was a straight swap over, although I took the opportunity to replace the lead wires with 22awg silicone wires. I re-used the original thin insulating gasket.
Note that the board is very thin (1mm*14mm), compared to most boards (~1.5mm). With such tight clearances in this light, using a thicker board might be an issue if the cell is on the long side.
I couldn't say if a 16mm board will fit - there was plenty of clearance for the 14mm board, but I didn't test a 16mm on the pill.
