Thanks for the info Halo.
How about just 1x7135, 4C and 5%low, 30%med and 100% high? Would you know approx how many lumens will these settings provide? Might be near enough to what I want.
Never tried one with 1 x 7135 myself. I read in your other thread that you have a 3 x 7135 version. The low for 1 x 7135 should just be around 1/3 of the low on your 3 x 7135 version.
Yes, my grey S2 has 3x7135 chips with a 10%low, 40%med and 100@high settings. If I follow you correctly, the 5%low on 1x7135 would be 1/6(?) of the low in my grey s2? If so, then that’s quality light with very looooong runtime. And I would definitely place my order. :party:
BTW, sent Simon a PM in his AE store regarding this query.
Thanks for the suggestion.
Can I order just a 1x7135 chip version? My goal is to have an 18650-based EDC that will have a low low mode and very long runtime.
I’m not sure if Simon will do that, but you could ask.
You could also order a driver from RMM with whatever specs you want. For example, his FET+7135 driver provides the low low and long runtime, but it also gives the benefits of really high high modes. Or you could ask him for a 1x7135 with STAR and custom levels. Or whatever.
@all
Just got a reply from Simon. He can do a 1x7135, 4C version for me with 5%low-30%med-100%high modes. That will give me around 4-5lumens on low. Not the low low that I want but it will already be useful to me. I will just use my quark when I need moonlight mode.
Simon has both the blue and red short tubes available in his store now for $2.95 each Minimum quantity listed as two but yo ucan message him and mix and match and usually work out whatever you want. Simon is really easy going about that stuff. I’ll add this to the OP as well. Enjoy!
He will have no problem mixing and matching them for you. He’s still working out details with the factory but deep carry clips are in the works for these too. We’re in discussion about an “ultimate edition” for the S2+ with both short and standard tubes and a deep carry clip in all three of the new colors. Oops… Did I say three? 0:) More info tomorrow. Way past bedtime for me.
