76% and going strong. There sure are going to be a lot of data points on the runtime graph.
76%
Down to 74% now. Wonder if it'll still be lit in 9 hours time when I get up in the morning?
72%. Off to bed so I'll stop boring you with updates till the morning when a runtime graph will appear. Assuming it has decided to turn off by then. I reckon another 3-5 hours should see it.
Long enough Mr. Admin? Or do I need to get some higher capacity cells?
Dude with higher capacity cells that light should last a year with low running...lol.
This has been a real white-knuckle thriller for me, percentages trickling in all day long, I love it!
24 hours or I'll eat my hat.
58% and still going. Better look out the hat seasonings!
We're now below 50% but it is still emitting light. I'll let it run till the cell protection cuts in. Now 47%
Still lit. Down to 29% Now 15,555 data points.
Looks like it'll still be lit when I go to work. It is just possible that hat eating won't be necessary.
Now down to 6%. Don't think I'm getting a whole day out of it.
How are you going to cook your hat?
Steamed....lol......with a little bbq sauce for good tasting. Thanks for doing the runtime....the light is still doing a good job at lighting up, have you tried turning the light off to see if it will come back on.
Came home to see to the hound - it is still lit. Now down to 2% after 28hr 20 minutes. It is about as bright as a sick glow-worm but it is still shining. Now 20,385 data points. This is impressive, I'd have thought the cell protection would have cut in by now.
That's a very impressive light then. And it sounds like most of the time the light was actually strong enough to be usable. But are you sure it has cell protection?
I'll save my dinner for another day....
The dropin won't have protection, but the cell does (or at least ought to have). Will see when I get home again in about 3.5 hours. There will be a lot of data in the graph. I have seen the protection circuit work in several of these Trustfire cells - couldn't say for certain about this one. If the voltage at the end is less than 2.5V I won't even try to recharge it. The protection circuit is supposed to cut in at 2.75V.
Once I get home, I'll try switching it off and leaving it for a bit before I try to turn it on again. Of course, it could be like some that will run, but not start when the voltage gets too low.
Ah, the CELL has protection? I didn't know that. My Akoray K-106 has an option cell protection feature in which it will not run when the current is too low, that's why I thought that it was up to the flashlight to protect the batteries.
The beauty of these lights is that the battery "rejuvenates" itself when it sits. (Maybe our in-house chemist could explain this Don?) So assuming that you were lost in the wilderness with only one battery, you could theoretically use the light all night long, then turn it off during the day, and it will turn on again the next day again at almost full brightness.
Well protection can go both ways.....the circuit on the cell will cut-off or the light will have one built in causing the light to turn off or give you a warning like blinking and such. If the light has built in low voltage protection then thats when i like to use unprotected cells.....nice to see that the the light is still going.
31.5 hours now. 1%. Dim enough that I can now look into the LED. Time to check the cell voltage. 2.68V which is after the cell protection should have kicked in. I'll let it stand for a few minutes then see what the voltage recovers to. 2.86V - even gives some usable light though I suspect, not for long.
Excel doesn't like time data that goes past 23hours 59minutes and 59 seconds. Obviously the next tick is 0 hours, 0 minutes and 0 seconds. This does make charting a bit tricky. I had just typed up a wonderful rant about this, but you are all lucky as I seem to have hit the browser's back button instead of posting it. Back to the fight with Excel - I feel much refreshed after a good rant about $£%^%$&*& Microsoft and its $£$@^%^$*&^*(&%^awful software. So back to the battle. It was still producing light at 31 hours 27 minutes and 6 seconds. There will be a runtime graph even if I have to download and install OpenOffice to do it. Excel 2007 and I just don't get on.
I once spent weeks trying to get it to plot 24 hour probability density functions for various revolting medical and budgetary reasons. It can't so probability density functions and my knowledge of Mathematica (which can do such things) is rather less than my knowledge of the dynamics of galaxy formation. That question in the exam paper earned me exactly 0 marks and a note at the bottom saying, "I suspect you weren't at the lectures". Sad bit is - I was at those lectures.
At long last, the runtime chart on low. It runs for a very, very long time on low. I gave up at 31hr 27 min 6 sec as I was concerned that the low voltage cutout on the cell wasn't working. Fortunately the cell recovered and is on charge now. Conventional reckoning is that 50% = runtime so it has a runtime of 20 hours and 15 minutes. It'll actually produce useful light for something like a day on a 2400mAh (Probably optimistically rated) cell. It will produce some light for another 14+ hours. Given that hardly anyone is ever in darkness for more than 24hr at a time and it is dark here for about 16 hours a day but I'm asleep for 7-8 of those, I should get 3-4 nights of usable light out of it. Ignore the spikes at 10 and 14 hours - was looking under the desk with a bright light.
So, without farther ado, here's the runtime chart.
Very nice! I fixed the size for you, the height was at "80" instead of blank.
So as far as I can see, it produced very usable light all the way to about 22 hours. Very impressive.
