Think you will sell more Olight i3s-cu if you tell us mode order?
H/M/L or is it M/L/H as standard i3s ? Hidden strobe?
Usually CU stands for copper, I wonder why olight chose that abbreviation.
i3s CU
Specifications:
LED: Cree XP-L CW
Runs on: 1 x AAA Battery, from 0.9-2.0v (Included)
Output/Runtime:
High: 180 lumens / 42m
Low: 20 lumens / 10hours
Moonlight: 2 lumens / 96 hours
Max Beam Distance: 50m
We cannot confirm mode order until arrive…They can change without notice.
I can only speak for myself on this one but for me at least when it comes to posts from this site I always seem to find the links don’t ever seem to work on posts that are more than five minutes old, the website is a mess and the regular prices are way to high. I guess I should persevere and dig out the bargains and convert dollars to pounds and check up info on what they sell on other sites to find out more information about what the products are they are selling but then I think if they can’t even adequately sell stuff what are they going to be like when it comes to delivery or worse still problems with faulty goods?
Interesting light for the price. Could you please verify that the maximum brightness of 180 lumens isn’t a mistake? It sounds like an awful lot for a 1xAAA light, and it looks like an easy typographical error since the normal i3s is 80 lumens.
Just confirm the data from Olight, it show XP-L V4 max 180lm. I will verify once stock arrive.
Super interested in this light. I really like the look of the copper. There only seem to be BRASS and GOLD available unless I am mistaken?
Edit: I assumed there was copper available. My apologies
Thrunite tis: http://www.hkequipment.net/product-p/tis.htm
Olight i3s-CU max output is similar to Thrunite Tis with XP-L so not impossible.
“CU” model name is odd, I am a bit color blind and in advert I think it looks a bit red?
Is it some kind of alloy, not brass? If CUs modes is like standard i3s,not a bad flashlight me think.
Aliexpress adverts talks about 3minutes turbo mode.More lumens and runtime than we have here.That sounds like fake if you ask me.
And then there is a Maratac brass xpg2 from last xmas to compare with.
Please, When is the expected availability of Olight i3S Cu & Ti in HKequipment?
REGULAR PROMOTION Coupon HKE80 - 8%off for all stuff price US$30.00 or above (Still can get points, but cannot join with other coupon or promotion)
Olight S10R Baton II - Cool and Tiny design, USB Rechargeable - Coupon S10R2PVD
Olight Piston Flashlight - PL-1 with Blue Light - Coupon Valkyrie
Olight R20 Javelot Flashlight - Compact USB Rechargeable with XPL HI - Coupon R20JXPL
Are you planning on stocking the Neutral White version of the Ti4T penlight?
Yes, we planning import NW, but still wait TN confirm.
I find it a bit annoying to be honest. Thrunite uses Ti as a model designation on lights that aren’t titanium… and then releases titanium versions. Is the TiS steel? No, it’s aluminum! But wait, there’s a steel version too! LOL and a titanium version! Now CU but not actually copper (I guess technically brass is partial copper). It only breeds confusion and I wonder why they do it or if it’s intentional. It’s starting to look more and more deliberate.
I look forward to learning more about the i3s CU, including the mode sequence, and whether the brass is lead free
and I would be even more interested if a high CRI version becomes available
I have an Alum i3s, its my primary edc. I love how light weight it is, and how smooth the threads are. Its modes are M-H-L 20-80-.5, with NO PWM.
I think the “CU” version will probably use a different driver, so maybe the sequence will change too.
Thrunite TN4A with XPL HI version
Thrunite - more for Tix Series - Ti5 XP-G2
Not for $52.95…
The Convoy 365UV has a Nichia UV LED in it already and it’s only $25.67 the only other thing needed would be the filter for a couple of dollars more.
