I was able to get the O-ring correctly seated by carefully putting it in place (which is precarious, but doable). I had to stretch the O-ring a bit to pop it into the small groove where it fits.
Next, I placed the centering ring over the emitter, and stacked the lens and reflector (with O-ring) on top. I lightly balanced the lens on top of the O-ring.
Lastly, I slipped a pencil (eraser first) through the bezel, and gently pressed the eraser down on the lens. By pressing down on the lens, the lens, reflector, and centering ring are held in place so they do not rotate when you screw on the bezel.
Thus, the O-ring was held in place while I slipped the bezel over the lens and screwed it back onto the head.
As a tailstanding lantern you can just place a film canister (the ones you get from intl-outdoor) upside down on the light, just loose with the lid still on it (helps diffusing)
Use it however you wish. I think a better adhesive should be used at the edges. The Fujik is too soft and still allows the mcpcb to twist. If you post a link be sure to mention the post number so people with different posts per page settings can locate it.
I recall searching a while back and finding those round-hole spacers are commercially available too.
As are some with adhesive.
They just picked the wrong one when assembling this light, I think
I checked out a light i had used it on and it seemed to have hardened, but i am not sure if it is fully hard beneath the mcpcb, it isn’t sticky and all the residue around it are more like plaster than anything remotely sticky anymore.
Unfortunately it isn’t are very successful mod (a XHP50 in a way to small double AA host with to little heatsinking) so i don’t want to take it apart, because i know i will never put it back together again when i have all these other fun mods ongoing
I used it to hold down the mcpcb that wanted to raise because of to stiff wires, and for that it wasn’t very good even after i placed it under pressure for a few days it still later seemed to not hold down the mcpcb hard enough. So as a glue it isn’t very strong if something is pushing against the bond.
I will get some AA for future similar needs.
But i also used it to mount a few 10W 12v red & amber leds on a old big pc heatsink without having to tap holes, to screw it down & for that it worked great just what i needed & i will use it like that again.
I just checked that bond & it was solid as a rock i would probably have to use a chisel to remove if i wanted to. So 2 well prepared very smooth surfaces will bond very firmly at least if there are’t any forces actively pulling them apart with this stuff.
hank, i think i posted the link to those very cheap 10w 12v red & amber leds in one of your threads, they work really nice if you have some 12v already setup somewhere try them out :), they where crazy cheap and seem to have a wider spectrum than the single color XP-E2’s we use in lights.
I wonder any of you can describe how hard the AA glues? Is it permanent as in you have to use so much force you almost damages the parts to get them apart or is it enough to bend with something and the bond breaks without twisting the mcpcb for example.
The problem with rounding out the hole is the disc loses it’s centering capability which is half the reason it’s there. The other half being to set the led to the correct height in the reflector. I’d recommend either fixing the ring to the star so it doesn’t twist or using a butterfly spacer that stats put and also doesn’t twist.
I cant help with the one you linked as I haven't used it. The two Fujiks I have used. I did buy a similar looking product to the one you linked from a local electronics store along time ago. I cant remember how well it worked but once I opened the lid and used it once the rest of the product in the tube went hard.
My other two A6’s seem to be affixed to the star. Only the one with the 1A tint is stuck to the reflector. I’ll probably end up gluing it down to the star, too. But until I’m ready to do that, I’ll just leave it as is and avoid opening the head up. 0:)
As I described in post #184 of this thread, moonlight mode was not working in my BLF A6. There was also a tint shift that seemed to come and go, making the beam yellow.
Without any fuss, heyanqing1 made arrangements to send me a replacement head. It arrived today. All I had to do was unscrew one, and screw on the other. All is now working well, and the 3D tint on the new emitter may be even better than the nice 3D tint on my other A6.
The easy fix aside, this really worrying with all those BLF-A6 lights out there, you really must know what you're doing with this light. It happened to the minus-wire in your light but it could just as well have been the plus- wire
Sorry guys… I’ve been pretty busy lately…… I think I need to take some of the great knowledge given here and get it into post#2. That way if you need to direct someone to your advice you can link it. I realize some of you had great ideas that have not yet made it to the original post. I will do my best to review the thread and get that updated as time allows. Thanks for all of your input thus far and if you have something that you’d really like to see in one of the first two posts let me know!
“Long tap: Do a long (longer than 1.5s) half-press to reset to the first mode (if mode memory is turned off).”
My version (latest batch) takes about 5 seconds to reset to the moon mode with a long press. Conclusively, turning off the light then on within 5 seconds registers as a medium half-tap so goes in reverse rather that straight to moon.
