Uncoated might be slightly more appealing, but I would accept both, coated or uncoated.
Just don’t make the bezel blue please. And could the button be made out of copper too? plastic button on beautiful brass light is just wrong…
clearly unfinished is the way to go .
the upside of these lights is you could use them to fix the shut off valve under your sink and … use them to fix the shut off valve under your sink.
I’m with you, that uncoated/ss or gunmetal whatever is the best option for this light. I’ve got the original black ano light and it does not take 18350. I wouldn’t expect this to either. 16340 works fine through.
For me it depends on the coating. If it's clear lacquer then forget about it, I'll take the uncoated. I'm a patina fan more than anything so safest bet is uncoated.
I saw on another forum where Marshall at GoingGear said they were PVD coated. I don’t know exactly how that works, but some googling around informed me that normally PVD coating copper requires that it be chrome plated first, then PVD coated using a copper colored dye. That’s kind of cheating, if you ask me, so I wouldn’t be very I interested in that either.
Good thing I’m a big fan of raw copper, patina and all.
