BLF A6 FET+7135 Light Troubleshooting and Mod thread
Did it get wet from rain? Or did you drop it into a puddle, etc? Just wondering to gauge how water resistant it is (or isn’t).
If you’re in to high amps I would polish the ring some how.
Light rinse under the tap to clean it off after doing some soil work in the garden.
For the record, this only happens with the new replacement head. The old head didn't leak at all even when submerged in a bucket. Old head had low mode problems.
Another observation, I tried to lego the reflector portion of the old head to new head, it wouldn't screw tight. If I had to guess, I would say that the erratic manufacturing tolerances is not only affecting whether light turns on or not, in some cases like mine, the manufacturing tolerances affects waterproofness as well.
You might check the O-ring — notoriously a bit too snug in the early ones so it would slip out of the groove and apear behind the lens.
But if they substituted a thinner (cross-section, like 0.5mm or 1mm) rather than wider (inner diameter, something under 20mm) O-ring, it might not slip out of the groove, and yet, wouldn’t fill the groove so wouldn’t keep water out.
Just speculating, of course. Sometimes fixing one problem causes another problem elsewhere. It’s one of those QA/QC checklist items.
I could be wrong but I think xzel87 is saying that it’s leaking where the entire head screws into the body and not from the lenses side. Checking the O-ring where it screws into the body is a good idea. Maybe it’s missing, damaged, etc.
That’s pretty unusual. First time anyone has mentioned an issue like that, I think.
If you have tools to flash the driver it should be relatively easy to investigate and fix, but without those tools it likely won’t change. There could be a driver component out of spec or something, like maybe the big and little capacitors got swapped. Hard to say by guessing though.
Correct. To be more precise, it's the reflector portion that screws on to the head. Checked and relubed the orings, no damage to them whatsoever. Still leaks. I just don't risk it and submerge it in water anymore. I'm sure it would be fine with splashes (rain) but submerging is a big NO.
Abit dissapointed with the waterproofing of my unit but nevertheless still a good deal considering what it is.
Tried adding some conductive lube/bulb grease?
Of course if it’s hot when it gets wet and cools off, it’ll pull a lower pressure and suck water in unless it’s really tightly sealed.
Maybe a thicker o-ring would help? Sounds like the current one is slightly too thin.
Currently Bang-goods is going to be shipping me a new tube, since mine is shorter than spec, but by bypassing the tailcap to turn on the flashlight, I just noticed that I also received the wrong LED tint. I ordered a 1A (cool), but I think I received the warm light version (5a). It took me 2.5 weeks to convince them that my flashlight was defective and since I have the wrong LED, would it be worth trying to get another LED, or would they just assume that I am trying to scam them out of a flashlight and cancel my replacement tube. I don’t have another flashlight with a known LED tint, but I have a no-name flashlight in comparison on a white surface to try to show the different tints. Left is the A6 and the other is the cheap one.
Can't see your pic.
Do any of these work, if not any place where I can post them for them to see.
https://drive.google.com/open?id=0ByG0qQW\_\_8R1aW91TE9UNHVGcE0
https://drive.google.com/file/d/0ByG0qQW\_\_8R1aW91TE9UNHVGcE0/view?usp=sharing
Yeah the left is absolutely not an 1A cool white tint.
I don’t want to seem like I am trying to get a free flashlight out of them, but I didn’t receive what I ordered, In your opinion should I just be happy with my incorrect order and hope that the replacement tube will fix my light or should I take the chance and try to get both my in-spec tube and correct LED (or complete head, depending on how hard it is to swap out) and risk having my tube canceled for looking like I am trying to milk there profits and get free parts. I guess at the end of the day I just want the flashlight to work, but I would much prefer to get what I ordered.
Why are you assuming they would think you are scamming them?
Just ask politely for what you ordered and try as best you can to provide evidence that they send the wrong light to you.
Just my pessimistic personality I guess.
Be nice. Until it’s time to not be nice - Patrick Swayze
In this case it’s a good idea to just keep being nice until it’s resolved but depending on your level of dissatisfaction don’t let it go past the the paypal time limit and let them be not nice instead.
I was not able to use paypal, because the link did not work for what ever reason, so I had to just use my debit card.
I would want them to correct the issues. But then again 5a tint isn’t the end of the world. Take it outside once you get your new tube and check it out. The warmer tints are pretty sweet looking on natural scenes. You may really like it! I lucked out and every light I’ve ordered had worked but I couldn’t swap parts between my bare light and my anodized lights. Tail cap to deep.
Guys I’m looking at TIR lens. Don;t know if it will fit and I need help!
http://www.kaidomain.com/product/details.S020644
http://www.kaidomain.com/product/details.S021698
Do i need this? http://www.kaidomain.com/product/details.S020961
And another thing, why cant I open the bezel of my anodized A6 but I can on the bare Alu one?
