Easy Mini MAGLITE 2-Cell AA Mod *now includes pictures and build details*
40 posts / 0 new
dthoang
Last seen: 1 year 3 days ago
I have been itching to do a simple mod of the venerable Mini Maglite 2-Cell AA flashlight and think I have come up with one of the simplest and cheapest true mod, not just an off-the shelf LED module replacement.
Here are some features:
  1. aluminum pill that can fit 16mm round MCPCB
  2. boost driver to use 2 AA cells with current limiting to boost battery life
  3. frosted TIR with nice flood
  4. same twist operation
Estimated cost is $6.
Details of build with pictures will appear soon. I’m posting this as a teaser for now.
11/3/2015
This is my first build post on BLF. I’ve learned a lot from reading many other fantastic builds so this is a way to give back.
First the final product:
Beam shots:
Here are the build steps illustrated using a new mini maglite.
The pill and driver were taken from a cheap AA zoomie that can be had for $1.99.
So much for DO NOT REMOVE.
The mini maglite looks like this disassembled.
The top of the battery tube original and after 1 minute of sanding.
Here is the bezel with a gasket I cut from an old 35mm film canister holder.
The pill was a perfect fit! I added a spring to the driver.
The lens is also a close fit. This second mini maglite might end up as an non-zoom aspheric.
Here is a 21mm frosted TIR I got from led-dna on ebay. It is shown next to original reflector and XP-G2 7A LED replacement. This particular TIR is perfect for this build because it is shorter than the other TIRs I have. This is critical because of the little clearance in the mini maglite head.
Here is a closeup of the driver, which originally had three modes. I removed the mode controller chip and replaced it with a 7135 linear constant current regulator. This light is intended as a gift so I want it to last longer on 2 AAs. Even with 350mA to the LED, it will be brighter than the stock light.
This pill is hollow so I added some Artic Silver Ceramique 2 to help a little. But it should not have heat problems with 350mA. I had to widen the plastic spacer with a 5/16” drill bit to better fit the TIR. I made a poor attempt to make room for the soldered connections.
That’s it for the pictures. Here are some final notes.
I bought two cheap zoomies: one black and one golden. One of them, I forgot which, came with three modes and what looks like a genuine Cree XP-E. The other came with a one-mode driver with a genuine LB POS.
I used the XP-G2 7A because I have several and thought this is a good project for it to maintain the incandescent look of the original Maglite.
For the cheapest build, just use the pill as-is and the cost is $1.99. Add $0.40 for the frosted TIR.
The pill qualifies as a drop-in so you can build several pills with modes, different tints, different LEDs, etc.
one year rookie
Edited by: dthoang on 11/03/2015 - 14:54
hank
hank's picture
Last seen: 35 min 34 sec ago
got me
dealgrabber2002
Last seen: 18 hours 57 min ago
Oh, I want to see. Subscribed
M4D M4X
M4D M4X's picture
Last seen: 4 hours 29 min ago
subscribed!
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
LowLumen
Last seen: 1 hour 35 min ago
Subscribed. Thanks, always interested in a budget 2AA mod.
DBSAR
DBSAR's picture
Last seen: 1 hour 25 min ago
same here, need to see. Smile i have several 2-AA mini mags that i need to mod.
dchomak
It’s not April Fools you know, it’s November!
cnrffl1
Last seen: 7 hours 3 min ago
I have a 2 AA mini mag light. And I want it brighter. Subscribed.
ReManG
Subbed… Looking forward to this…
ALL of my links are non-affiliated for your pleasure...
My Reviews
Lithium Ion Battery Safety 101
MtnDon
MtnDon's picture
Last seen: 18 min 2 sec ago
subscribed.
BLF Member Map Add your name and location.
emarkd
emarkd's picture
Last seen: 2 weeks 18 hours ago
Well count me in too. There’s like half a dozen of those things around here and they could use some attention.
Gunga
Gunga's picture
Last seen: 24 min 58 sec ago
Wow. $6? Cool.
rockhound42
rockhound42's picture
Last seen: 1 day 8 hours ago
subscribed.
dthoang
The full build post is now up.
one year rookie
DBSAR
DBSAR's picture
Very cool mod! Smile
DavidEF
DavidEF's picture
Last seen: 1 day 21 hours ago
Hey, I have a few of those cheap zoomies around. I wonder if this will work with the Harbor Freight cheapie Mag clone. I may have to find out. I don’t know if I’d want to buy a real 2AA Mag just to do this with. Maglite is real proud of their flashlights. Cash
- The YKK Philosophy
Rufusbduck
Rufusbduck's picture
Last seen: 10 months 2 weeks ago
You should post a link in the Modding links thread so it doesn’t get lost in the annals of BLF.
Scott
ReManG
Golf clap!
Well done, well done…
My Reviews
DavidEF
DavidEF's picture
I just looked around, and it’s basically $15 just for a new 2xAA Mag Mini. Anybody know where it can be bought for (significantly) less than that?
Rufusbduck
When I first started modding them they were $8 but still only $10 at Freidmans. A small flat rate box will hold several(more if out of the blister pack) so it should be possible to get 6 or more for $11 each. A while ago I sent a package to EU with blue and red 2D and 2AA lights. 6D’s are about $30.
Scott
LowLumen
Nice work, but a 7135 is a linear regulator and won’t work with 2AA: voltage is too low (unless using 2AA single use lithium). When battery voltage drops below LED vF (about 2.6-2.8 volts here) LED will get very dim/moonlight.
Use a boost driver or just direct drive.
dthoang
LowLumen wrote:
Nice work, but a 7135 is a linear regulator and won’t work with 2AA: voltage is too low (unless using 2AA single use lithium). When battery voltage drops below LED vF (about 2.6-2.8 volts here) LED will get very dim/moonlight. Use a boost driver or just direct drive.
The driver is a boost driver. I took out the 3-mode chip and put the 7135 right before the LED.
one year rookie
dthoang
I get mine from Sears. I wait for Sears to send me offers like “10,000 surprise points for purchase of $10 or more.” I combine those points with the 3,000 points I get every month for being a Shop Your Way Max member.
I’ve gotten several lights and other goodies for free or almost free that way.
one year rookie
dthoang
I uploaded the wrong picture for the driver close-up. Here it is.
I’ll fix the OP now.
one year rookie
hank
hank's picture
Wow.
Can you give us a macro photo showing that location on the board for that 3-mode chip?
OH, you just did! thank you, I can see the 7135, so ought to be able to figure this out.
Is there something similar you (er, I) can do with a single-mode driver? (those GearBest $2 zoomies say they’re one-mode in the description, which is not always reliable)
And I recall there are some variations in the 7135 chip — anything in particular to watch for?
ImA4Wheelr
Last seen: 3 weeks 19 hours ago
Nice work.  Congrats on the build.  So the zoomie pill threads into the head?
I take it you sand the battery tube both for electrical contact and so that it can still screw all the way down?  Or did you add a spring to bridge contact from the battery tube to the pill?
LowLumen
Got it, I misread; didn’t realize the linear was placed after the existing boost.
dthoang
hank wrote:
Wow.
I bought two AA zoomies and got different drivers and LEDs, so unfortunately this is a one-off. I just placed an order for two more of the same lights from GB. Who know what I’ll get.
I did some research before putting in the 7135 chip. The boost chip looks like an ME2180.
ME2180 datasheet
This is a DC-DC boost converter that has regulated output voltage. Because of this, I can put the 7135 after it.
Some drivers use constant-current boost chip, such as the PAM2803, where the output voltage is not regulated but the current is. With those chips, the 7135 is not needed and the sense resistor can be changed to get the desired current.
one year rookie
Rufusbduck
Would it be possible to power an Attiny from the boost and use it to control the 7135? An mmu might be able to fit on a layout that small.
Scott
dthoang
The pill just drops in but with very little clearance. I only sanded the battery tube for electrical contact. I was lucky that the TIR and pill combined fit perfectly. It took exactly one turn of the tube to turn on the light. Yes, I added a spring to the driver to allow it to make contact with the battery.
one year rookie
dthoang
I don’t see why not. The ME2180 is designed to power microcontroller-based devices such as a wireless mouse. The tricky part is to make everything fit. What makes it possible is that the ME2180 only requires an inductor and two caps. Other boost converters chips require a schottky diode, sense resistor, and sometimes an FET.
one year rookie
