Hah! Thanks! I had gone into my account and changed it for topics and comments but I didn't realize you could change it with input format! I probably clicked that when I first started but didn't really want the advanced editor and then totally forgot it was there. I'm pretty new to forums......:) Thanks again!
FWIW, you can also just add some HTML and/or CSS to your posts when you need extra formatting. It works, and that’s what the advanced editor does. It also makes quoting easier for the rest of us, since it won’t have gratuitous symbols and <span style=“foo”> tags and redundant attributes everywhere getting in the way of the text.
For example, if I quote 1dash1’s post above… it looks like this:
Heat the part with female threads and cool the part with the male threads. People have also wrapped in tape and gently used pliers. Or also used penetrating oil leaving the light on it's head so it doesn't get in the driver.
The head and pill should unscrew from the battery tube as a unit if they’re stuck together so yes, just run it on turbo until it’s pretty warm but you can still grab it to unscrew then immediately stick the pill end on an ice cube for 5-10 seconds. A wide rubber band doubled over a few times on each piece might help with grip.
I got i open, and it was so easy when I used all the tricks together.
First i heated it by running it in turbo a few times without holding it to get it extra hot, and while it ran I took some ice cubes and crushed them to a slush. Then i quickly removed the searingly hot head and put it head down in the ice slush for ~10 seconds. and then i used a silicon oven liner for extra grip and finally I got it open easy
The threads where super gritty, but now i can at least make this anodized BLF A6 in to the triple it was always meant to be.
I usually go with a teflon-based (PTFE) grease… though I’ve been lazy about it lately and have like a dozen lights I haven’t properly cleaned and lubed yet.
I have some “Super Lube” from The O-ring Store, but am going back to furniture wax with carnauba, bee’s wax and orange oil. It seems to be more slippery.
Yeah it works great, i don’t use thread lubes that are going to get close to my skin that i can’t eat, :bigsmile: and coconut oil dosen’t go rancid because of the mct component in it.
And if it gets on your skin it is an amazing skin oil.
I would never use fluoride based compounds(teflon) close to my skin, i don’t even use teflon based cookware only ceramic coated ones, stainless and glass, teflon is nasty toxic stuff :Sp
Interesting, furniture wax could be a good alternative.
I think i am going to experiment with some coconut oil, bees wax, jojoba & liquid lanolin oil combination to see if i can get a longer lasting and even slipperier thread lube.
If anyone wants to try, the trick is to heat them up together so they mix before gently cooling them down.
I don’t think lubricants increase resistance, because they are squeezed out where the metals touch. There is a thin film that may remain, but that doesn’t seem to affect resistance(?) They reduce corrosion that does add resistance, especially in things that haven’t been used for a while. I think lubrication also helps by slowing the wear of gold plating. The gold is another way of avoiding corrosion.
Weird maybe, but it seems after I Nyogel bare or close to bare threads, I always seem to get a little more out of the lumens measurements - same cells, everything else the same. Just did that last night, and I've seen it several other times. Nyogel is supposed to be non-conductive, but still seems like the best thing around. I'm so glad a while back I bought a large tube from a BLF member, who bought up a bunch of ol Motorcraft tubes for cheap.
