+1, The Bondhus are excellent, most of the allen/torx sets in the stores nowdays are really crap, poor fit, soft metal, there’s some real junk out there. The Bondhus are high quality, Made in USA. I use them for work. I’m getting this set of shorty size for my knives with torx (star):
You can buy the combined metric and standard Eklind ball hex wrench sets from Enco for about $10-15 for both. Eklind Allen wrenches have been very good for me, rarely rounding off unless they’ve been used a LOT.
For torx wrenches I highly recommend the Wiha precision torx drivers. I bought my set from Amazon.
The three sets should be enough to take apart just about any knife.
Edited to add that I have used Bondhaus hex keys, they’re very comparable to the Eklind, but not enough better to justify the higher price.
I ended up buying
table(table#posts).
|Bondhus 31732 Set of 8 Star L-wrenches
Short Length
sizes T6-T25 |Bondhus 20199 Balldriver L-Wrench Double Pack
10999 (1.5-10mm)
10937 (0.050-3/8-Inch) |
Thanks for the info beam0. I wonder if Spyderco put some pressure on, and that’s why the compression lock models are hard to find. Unlikely, but just a thought.
Thanks KKW, I checked them out, the Eklind hex wrenches look good too, but the Whia torx set at nearly $70 on amazon is way over my budget, the Bondhaus torx set I linked is only about $11.
I thought that too. Because they are a true “counterfeit” I compared it to a real one and its pretty much spot on. Either that or the cheaper version sells a lot better.
I like Spyderco’s top lock/compression lock, but I’m undecided if its better than a liner lock. It seems like the compression lock on these was designed for lefty’s. To unlock I have to bring my thumb up over the top, for right hander’s like me I think it would be better with the cutout on the left side of the knife?
My new preferred opening method on these; the “Spyder Drop” 8) :
I like the the Axis lock on the SpyderGanz, I wish they would have did the Para2 clones with the nice thumb ramp & choil jimping .
I also like the “Arc Lock” on some of the the SOG knives, its real smooth and the stud is only on one side.
Manx, Google compression lock. Sal Glesser, owner of Spyderco, can explain it much better than any of us. It is a proprietary, Spyderco designed lock, and it is much stronger than a liner lock.
Thanks, I see what you mean, with the index finger its like “pinching” between finger and thumb, I’m going to try it that way for a bit and see if its better for me, a little awkward right now since im so used to using my thumb. On my clones the C-Lock is pretty stiff.
I agree, these C81 clones are my best CN knives and I have many. At this price it couldn’t be real S30v as marked, however it must be a decent steel because mine is holding an edge VERY well, I’d say its at least 8cr13MoV.
At nearly 9” and only 95g I think it will fit my needs well for a large, thin and lightweight knife for SD carry when wearing shorts and lightweight pants.
It’s actually about the same weight as my Large SOG Trident, which is EXTREMELY light, but I think this Endura4 is a lot thinner. If I really like it a lot I’ll eventually get the real one (probably the less expensive VG10 version)
Guys, I was thinking if we should create a thread of reputable AE stores selling sought after blades. This info is then constantly updated in OP. I think it’ll be easier for us all to refer to that list!
I have that exact model - I find it absolutely superb. My only very minor gripe is that the upper edge of the compression lock is a wee bit sharp so could do with the 90 degree angle softening a little with a file. I haven’t got round to doing it yet. I think mine worked out at about £17 but it is still incredible VFM.
