ALL THINGS BUDGET KNIVES
The “liner lock” is placed on the spine of the blade as seen on the knives here
ignore the green axis lock knife
close up
Thanks KKW, I checked them out, the Eklind hex wrenches look good too, but the Whia torx set at nearly $70 on amazon is way over my budget, the Bondhaus torx set I linked is only about $11.
I thought that too. Because they are a true “counterfeit” I compared it to a real one and its pretty much spot on. Either that or the cheaper version sells a lot better.
Nice photo comparing the SpyderGanz to the Para2. Are your Paramilitary2’s clones from Ali Express?
I like Spyderco’s top lock/compression lock, but I’m undecided if its better than a liner lock. It seems like the compression lock on these was designed for lefty’s. To unlock I have to bring my thumb up over the top, for right hander’s like me I think it would be better with the cutout on the left side of the knife?
My new preferred opening method on these; the “Spyder Drop” 8) :
I like the the Axis lock on the SpyderGanz, I wish they would have did the Para2 clones with the nice thumb ramp & choil jimping .
I also like the “Arc Lock” on some of the the SOG knives, its real smooth and the stud is only on one side.
My SOG Trident Tanto with Arc-Lock:
Manx, Google compression lock. Sal Glesser, owner of Spyderco, can explain it much better than any of us. It is a proprietary, Spyderco designed lock, and it is much stronger than a liner lock.
From top to bottom:
  1. Spyderco
  2. CN clone
  3. Ganzo version
The clone is as good as the real deal and have taken a lot of use
The compression lock is easy to manage right-handed using index finger
I flip the blade in-out using the lock only
Thanks, I see what you mean, with the index finger its like “pinching” between finger and thumb, I’m going to try it that way for a bit and see if its better for me, a little awkward right now since im so used to using my thumb. On my clones the C-Lock is pretty stiff.
I agree, these C81 clones are my best CN knives and I have many. At this price it couldn’t be real S30v as marked, however it must be a decent steel because mine is holding an edge VERY well, I’d say its at least 8cr13MoV.
Just ordered one of these on the 11.11 sale
$14.79 :wink:
Endura 4 FFG (ZDP-189 Blade Steel)
At nearly 9” and only 95g I think it will fit my needs well for a large, thin and lightweight knife for SD carry when wearing shorts and lightweight pants.
It’s actually about the same weight as my Large SOG Trident, which is EXTREMELY light, but I think this Endura4 is a lot thinner. If I really like it a lot I’ll eventually get the real one (probably the less expensive VG10 version)
I’m thinking of buying a Ganzo G716, does anyone here own it ?
What do you think about it ?
The best price I could find until now is on FastTech
It’s still budget, but I would not be against a coupon/better price…
Damn thats a nice Ganzo! Didn’t see that till today! I’m saving up for an Ontario Knife Company Chimera Survival Knife HEHE
Guys, I was thinking if we should create a thread of reputable AE stores selling sought after blades. This info is then constantly updated in OP. I think it’ll be easier for us all to refer to that list! :wink:
Please check FastTech shipping cost
Last time I checked it was almost $30 to Europe
It kills all knife-deals there for me
$18.21 at GearBest
I have that exact model - I find it absolutely superb. My only very minor gripe is that the upper edge of the compression lock is a wee bit sharp so could do with the 90 degree angle softening a little with a file. I haven’t got round to doing it yet. I think mine worked out at about £17 but it is still incredible VFM.
I am ordering one this week. I want to try the serrated edge blade!
LINK !! HOwd I miss this? Where! J)
Wow, I didn’t checked the shipping cost…only 30$, what a bargain… :Sp
Thank you FT, but not this time…I hate ordering from GB as well but if it’s the only choice well…will try
It’s a pleasant folder for the money. The chekering of the G10 is quite agressive so you don’t have to worry about having a firm grip on it. :slight_smile: I chose the part serrated version :
Is the flipping of the blade smooth? No lateral or vertical play?
I have one of those. Mine weights 94 g and it comes with a slightly thinner blade than the real one (2.9mm vs. 3mm).
