“NyoGel® products were developed for wide-temperature applications requiring water and salt-water resistance. The 774 series consists of silica thickened synthetic hydrocarbon of various viscosities depending upon how much mechanical dampening is required of various components. The damping greases also provide good water resistance.
The 756 series utilizes a silica thickened hydrocarbon that includes the incorporation of carbon black since it was designed to be electrically conductive for instrument and bearing applications.”
While we’re off topic, I would like to say that the lubricant thing is way overdone. The battery tube going into the pill up top should be left alone, dry contact between the two conductive components is best. At the tail, where the battery is removed to charge on a regular basis, only the smallest amount of lube to prevent the o-ring from tearing should be utilized. This will find it’s way onto the threads whether you like it or not, and will need to be cleaned regularly or you’ll be wearing black thread stripes. I try to keep it from being on the bare end of the tube and the contact point in the tail cap as much as possible.
I’ve had to repair lights where someone used way too much lube and the resulting black mess down in the tail cap virtually blocked the pcb from making contact. Thoroughly cleaned the amperage went up to the expected values.
It seems you are correct. 760g is not conductive, but the above site does not state that. On the other hand 768g is supposedly conducting, but the above site does not even mention the product.
As I said before, my observations with Nyogel 760G say something different with dependency on quality of threads a big variable in all this, but of course lubes like Nyogel 760G should be used lightly and maintained properly. I've never seen it turn dark gray on anodized threads like on Convoy's and Eagle Eyes or this Manker BLF A6 for that matter, but on bare alum threads that are frequently used, yes, of course the aluminum micro fragments will stick in the lube and build up with more and more usage, turning it into dark gray sludge, specially if it's over applied.
I did not specifically check output results with/without Nyogel on a stock BLF A6. I just take it for granted it's better with than without it from past experiences, but once in a while when I have checked it before/after, it's either equal or better after applied to both head end and tail end of the body tube threads.
Not sure it matters but mine is set to no memory, 4 mode. I guess that means I don't have "moonlight", but instead low. Shouldn't matter but maybe it does?
Using a naked NCR18650GA.
1. Turn light on with full click (now in low)
2. 3 half presses to get cycle to turbo
3. Let it sit for 45 seconds, watch it step down, wait a few seconds
4. Long half press to reverse cycle. It will go down to low (or first mode) but not any further (NO turbo>strobe>batt check>bike mode)
5. Turn light off for a bit, say, 10 seconds. Still won't reverse into special modes.
6. Wait another 10 seconds and everything works fine.
By following Mark's instructions, I was able to replicate this behavior.
Thanks, Mark.
I tested one of my A6 flashlights. It has the same bug!
I repeated the test, but entered Turbo mode directly from low. Same result. I also repeated the test in the mode group with 7 output levels. Same result.
One thing that seems odd is that the long half press in your step 4 seems to jump directly to low (4 modes) or moonlight (7 modes). I expected it to simply go to the next lower level. In the mode group with 4 modes, for instance, the lowest mode is level 1 and the highest mode is level 4. After the 45-second timeout in level 4, the light steps down to level 3. From there, a long half-press should go to level 2, not level 1.
ToyKeeper has programmed 3 press styles, a short press bumps modes forward, a medium press engages reverse, and a long press takes the light back to the beginning or in this case low. So it’s working exactly as programmed.
Waiting 10 seconds and seeing it repeat the process makes me think there is an issue with the off-time capacitor.
I think it's been said before the heat from turbo mode really messes with the capacitor. So click timing after running turbo is really whacky. I tried mine and got some weird results as you said but super fast clicks do run the modes forwards. Not necessarily a bad thing being that I've not really needed turbo for long periods let alone needing to go into strobe or bike afterwards.
Hey guys and gals,
My BLF A6 showed up today along with my blue Convoy S2+ host.
My plan was to change over the tail switch from the S2+ to the A6, but fortunately the whole S2+ tail switch threads onto the A6 tailcap. unfortunately the A6 tailcap does not fit on the S2+.
Mode switching and programming all work flawlessly.
Here’s the proof
Known issue, and to be expected. The off-time capacitor they used is sensitive to heat, so the button timings change depending on the temperature of the light. While hot, it’s faster… and while cold, it’s slower.
This effect was reduced by 80% before production, but not eliminated entirely.
If you use one of RMM’s drivers instead, the heat sensitivity is reduced by like 95% so it’s barely noticeable even when very hot or very cold. RMM uses the best available components, and he has an improved board design.
Do you guys and gals think this light would still benefit from the tail spring bypass mod with the S2+ tailcap installed? Can the S2+ switch handle that kind of thing?
But the metal switch is still functional even with the current draw of a tripel?
My plan is to build a triple with an A6 driver in a S2+ host (with metal switch), but I couldn’t find more info (max. Amps) about the switch.
The light works fine… it just compressed the spring so far that even a light tap will cause it to change modes. It’s fixable by stretching the spring out (or putting in a new one) and adding a spring bypass.
For higher-amp lights like a triple XP-L, I have a solid post on one end of the battery and a really strong spring on the other side (q-lite springs are actually pretty awesome).
