Agree
Ordered 3 extensions. Want to use three KK26700 in the Y3. Will modify/machine the last extension to allow for extra length. If the last extension ever shows up in the mail. It’s been almost 6 weeks since I ordered.
Arrived!! It took 25 days, not so bad
The extension tubes where inside the same pack of the flashlight…So the second tracking only for they was not my.
I put 1xC Alkalines battery, but it is too short. Put 4xC Alkalines (2 not fresh, 2 new) the flashlight blink, unusable. Put 3x18650 and it run very well! I’m waiting 1x26650, can’t wait
But, I’m asking if it does not run with 4C Alkalines, with the others 3 extension, so others 3/4 battery, it will run or it will blinkies?
+1
Mine from GB CNQG, with 2 extension, works fine with 4xC fresh alkalines (Duracell). I guess if you add more batteries work best, not exceeding 8xC (total).
I get the blinkies with fresh 4 NiMH C (4.8 volts). It’s the low voltage 2 battery lithium warning signal. Guess I’ll have to get a total of 5 extensions and run 8 NiMH batteries or use a dummy of some type.
Is this light still very good bang for the buck?
I am looking for a thrower to add to my stash.
If i order this with 2 extension tubes and run (2) 26650’s, roughly what is the run time on this light?
Most excellent flashlight. Stock on two batteries it pulls a little over 1A. So roughly about one hour per 1000ma of battery. So a pair of 4000ma batteries (two cells)will give just under 4 Hours on high. A pair of 6000ma batteries will get about 6 hours. Be warned mod fever is strong on this flashlight.
