I used to like the HD2010 for a thrower in the 26650 class, this L2 is like the evolution of that light. Much better looking, much more refined, with the same diameter but considerably deeper reflector. And it’s about time! lol (I’ve got the L2 sitting beside a grey 2010 that pulls 6.49A on it’s de-domed XM-L2) The beam profile is nicer in the L2, tighter hot spot from the HI, overall nicer light by a good margin.
When’s the second round of pics coming?
Thanks for the pics Dale. Im tempted. Did you get rid of the red barrel or something?
Well this is cool. I didn’t know about this light except I saw it online and wanted one but they were all out of stock
The standard 97yd shot to the 55 gallon oil drum, Canon G1X ISO1600, f/5.6, 1/2 second exposure, manual settings manual focus, 2 sec timer on a tripod.
4X optical zoom (112mm equivalent)
Same camera settings, 4X Optical, white barn is 610 yds distant
oooh I like it. Thanks for the beamshots. How about some comparison shots with other similar sized lights? (to show size of the L2)
in comparison to Yezl Y3
reflectors of Convoy L2, Yezl Y3, Convoy C8
Thank you for the pictures of the reflectors. That adds a nice perspective.
Here is another shot of it with other known lights for size comparison.
I have to say I love the L2. Even stock it out throws almost anything I own. Thanks Dale for giving us a better idea of this light’s potential. SWEET!!!
I got it as host only, really like it. Such a nice chunky, well built light. However, the reflector has some imperfections, little dents, not too happy about that. Still not sure what I’m going to do with it, XP-L HI, XP-G2 or even XP-E2, someone figured out a way to dedome a 219C properly?
I think I’ll play around with it today. Let you know how it goes.
Very pleased that I have ordered one. Thanks for the pictures.
A comparison shot of a convoy C8 and convoy l5 (/clone).
Mine came with a little damage but I’m not complaining.
I really like this light overall. I’m passing the info on to Simon about the little damage stuff though. Dale’s came without a switch retaining ring and yours a dented reflector? That is not cool. On happier note I can tell you with certainty that Simon will take care of it and replace any missing or damaged parts. He did confirm that the light absolutely does come with a switch retaining ring and he offered to ship one to replace it but Dale already made his own. Contact Simon and I’m sure he will replace the reflector. Mine is flawless and all should be.
Ooh and more exciting news! Simon is making a run of the double length X6 type tubes for us! I’ll let you know the details soon. They will be unbranded. :bigsmile:
Chouster, how do you like it compared to the Y3?
Damn! I hate you! :bigsmile:
Now I have to buy another L2………
Although, not sure about that. I absolutely want a dual cell tube but don’t really have a use for it at the moment 0:) .(the current driver wont work with 2 cells, right?)
I guess that’s part of being a flashaholic. 8)
Damn guys, help me out. What should I do with the L2 I already have and what should I do with that dual cell tube?…
I have a second host on the way. :bigsmile:
The LD-2 from LED4Power can run the 2 cell configuration and at 6A or even more, so it’s a splendid candidate for a driver for the 2 cell L2 with an MT-G2 or XHP-70 in it. Oh boy, this is gonna be fun! An LD-2 driven L2 with MT-G2, 2 cell TOO sweet!
(perfect timing too, I only have 10 MT-G2 lights and it’s been a while since I’ve built one.)
Yeah, you’re right I should stop. It’s costing us too much money. I’ll tell Simon to cancel the tubes…
NOT!!! As my good friend Dale told me if you want the double length for looks and feel you can still run a single cell configuration with a dummy cell to bridge the gap. I may end up doing that. I’ll probably wait for the L6 for a 4 die emitter setup. I can’t get over the throw on the current L2 so I just want more power pushed through a XPL-HI emitter with the smooth reflector. My stock L2 hangs really well against almost all my modded lights. I think I’m in love. :heart_eyes:
Thanks man. I ordered the host from Simon, but that one is still on it’s way. The one I received is the one I ordered a few days later from Banggood. Contacted their CS about it, sent some pictures their way.
@PD68
In terms of build quality, it’s much better than the Yezl. Also in terms of heat transfer. The Yezl has it’s fins on the head, but the LED and the driver sit in the middle part. The Convoy is much heavier and feels much beefier. Yezl has side switch plus reverse tail clicky, Convoy has forward tail clicky, no e-switch, what I personally prefer in that kind of light (with the Yezl that e-switch doesn’t bother me, because I have a LD1 in there and don’t have to change grip to switch modes). Also the threads on my Yezl are really not that great, especially the none-anodized ones between battery tube and middle part, no comparison to the ones on the Convoy, which are very nice thick square-cut threads, that came lubed and feel great. The only threads I don’t really like on the Convoy are the driver retaining ring threads and the driver retaining ring itself. Threads on it are thin and the ring itself is also too thin for my taste, seems fragile to me. Had Convoy C8 driver retaining threads and ring ruined lately, also very thin ring with very little threading on it. The ring from the Convoy L2 at least is made out of brass and doesn’t appear to be that fragile.
As long as it works it’s not a real critique, it’s more of a suggestion for improvement.
Yeah, I think with the reflector I may had bad luck. I’d recommend buying this light, it’s great, and I’d recommend buying it from Simon.
I put a XP-L HI on sinkpad in there together with a FET-driver with guppydrv, that I had lying aroung, wanted to do it quick without any fine adjustments, and than see how the beam looks like and if I have to raise the emitter or so. So yeah, now there’s a XP-L HI in there, just used the spacer for XM-L2 that came along with it. Hotspot is very tight and there’s a corona that’s quite big, but not ugly, I like it.
Since my Yezl and L2 have the same XP-L HI, they should be quite comparable, although the Yezl has the 5A-LD1-driver whereas the L2 has a DD/FET-driver. I’m going to do some beamshots as soon as I can.
That’s it.
Going to put a XP-L HI and fet +1 driver in there.
I have some reverse clicky’s on order so when they arrive I try to put one in the L2.
Does anyone know of a driver that has a input voltage for 1 *and *2 cells and an amperage of around 4 - 5A? (for single 3v emitter use)
Really want to use this light as a thrower with 2 or 1 cell.
Surprisingly, my L2 host showed up today , along with a Blue S2+ host and the blue and red shorty tubes . Tracking # never worked. Wow, the L2 is a beauty. Also got in the supposed XP-L V6 0D LED's from FastTech.
I was curious about the reflector size (width) - it's 54 mm I.D. compared to 51.5 mm I.D. of an HD 2010, plus of course the obvious larger depth.
