Egg-zactly! We need to filter out that annoying visible light! I’ve wanted to do this for ages, but the only option, other than an expensive custom-fit filter was found on a page suggesting that I buy and break open an incandescent blacklight bulb and tape the broken glass over the light. :Sp
It appears inherent of 365nm led design that apart from the peak around 365nm there is a low intensity broad band of visible light (400nm leds do not have that, and I am testing an LG 385nm led at the moment and it also does not seem to have the problem). Only Nichia found a way to minimise this (but it is not completely absent).
So the visible light problem is not restricted to cheap leds (the expensive Ledengin 365nm led also puts out the whitish light), and a uv-pass filter just fixes it very effectively.
Thanks for this clarifications guys
Interested, altho’ I already have a couple of these ordered.
As with a lot of things bought this way, I’m somewhat dubious that we’re getting first quality, rather thinking we may be getting cheaper seconds, but time will tell.
Interested. One or two, depending on price.
Same here.
Interested
I will take 3 if this goes ahead. Suitable packaging should be part of the deal, a simple ziplock bag wil not cut it.
Just received the Jaxman U1 today… The filter makes a huge difference compared to a bare MTN or Convoy S2 UV emitter.
I might be in as well depending on the price.
ZWB2 is 365nm-pass right?
I know there are also ZWB1 and ZWB3 but don’t remember which wavelength they are for.
I would be interested in 2 or 3
Found this graph for reference:
I’m in as well. Will they be offered in more than one diameter?
Bump?
On aliexpress they can be found in various diameters, and can probably be made in any diameter as long as you buy enough of them. I think that for a group buy only 20mm and 18mm could raise enough interest, perhaps 12mm (there will probably not be hoards of people who want their 365nm led in a C8 )
Doing a google search for ZWB2 filters I suddenly came across Gearbest, not sure if there will be a separate group buy price, but they list the 20mm x 2mm ZWB2 filter for $3.99 :-)
Which is good enough for me, ordered one, let's see when it shows up.. (or if it shows up at all, I never know with Gearbest lately, my Olight S1 is still lost and Gearbest does not want to take responsability)
Also doing a Google search for ZWB2 filters, I ended up at DealsMachine. Their price is also $3.99. They are using the same picture as GB.
But I must admit that I’ve never bought anything from them. For the moment I’ll try to over-ride my trigger finger.
http://www.dealsmachine.com/best_288536.html
Who has any experience buying from DealsMachine?
Thanks for the information djozz.
For those interested and as indicated in the FastTech deals thread, the UV S2 is available for $ 14.32 and there is a 10% coupon on top of that “XMAS”.
https://www.fasttech.com/products/3760700
3 orders and no problem, 4 soon.
You’d better go with the 5 pcs on GB for $5.01.
There is a 20% coupon on DM at the moment “Thanks”, but coupons work the same way as on GB. Anyway there are some good deals ( LG MJ1 4 pack for $ 18.79 ). Be careful, free shipping is not available on all products ( Pana NCR18650B protected 4 pack for $ 14.39 with coupon but $ 6.21 shipping ).
I… a few orders. The biggest $80-90. No problem.
+1
P.D.: DealsMachine is “sister” of GB and EB. Before it was called AHappyDeal.
I had not seen the 5 and 10 pack, but I do not want 5 anyway It confirms that these filters could be much cheaper as soon as the demand was there :-)
