You sound a little shitty TP? Did you miss out on an invite?
I always celebrate World Toilet Day. Life sucks without your Porcelain Pal… and a lot of people on this world don’t have a decent one…
My daughters (2) are all dun with school, out in the real world. My older one is a teacher and an assistant high school coach for girls soccer - watched them win the state championships over the weekend - NY catholic schools. She had a full ride at Providence College for soccer, Big East - those were the crazy days, all over the country to catch her play. Haven't seen a girls soccer game in a long time before this past weekend - brought back lot of memories...
It sounds like exciting times again. You must be very proud of them.
I spent a week in NY mid year and loved the place. I have no idea how anyone parks with a two inch gap between cars though. If I ever win the lotto I'd love to come back in the winter time.
Thanks Tom E. I'm going to try to install and try out this new version today in a SRK with 4 219C's today. So it should be pretty high current.
Do you have a version of this FW that is small enough to port back to the 13a? I have quit a few 13a's with momentary switches that I would like to update.
Uhhh - was think'n bout it, but right now this is 3500 bytes (3.5KB), and only 1000 bytes available on a 13A. I've been doing the bent pin thing on a 85 and swapping out 13A's. Did a few, so far so good, but almost all needed a little touch of the iron on at least 1 pin - it's not working for all 8 pins every time for me, but little careful TLC gets it fixed up quick.
I believe the e-switch support alone required more code space that a power switch driver, so can't do what TK did for sure, but even hers requires a Tiny25 (2KB).
Didn't do the same "fix" yet either for my 13A e-switch firmware yet. Not sure what you are look'n for - this full functionality or just this bug fix... For the full functionality, I'm even way past the capacity of a Tiny25 (at 2KB).
TK can, and does, compact the code down more than I do. I don't have the patience to do that level of bit tweaking that Dr Jones is so famous for - I want functionality and usability over size.
Sorry, meant, do you have an older version that you feel should work and would still fit in the 13a. I totally understand the latest has many new features that just won't fit.
Ohh- sure. Haven't touched it in a long time, but it works well - but would benefit from the same exact bug fix. Not all drivers had the flicker though.
This link google drive folder has the version for FET+1, and the older version with a single output - both 13A versions.
Update: in my test light, Supfire M2-Z, I've been using the wight 22mm FET+1 board with an 85. I experienced flaky operation on occasion all along I believe - blinks, sometimes it even locks up. I added a 0.1 uF cap on the zener pad and seems like the flaky intermittent problems went away. So, I left the stock 10 uF on the C1 pad. I believe this light and the SupFire M6 were the only two I've used this driver board on, at least with 85's, and both had intermittent problems in the stock C1 setup - caps on the zener pad seem to solve it.
Thanks. I think you had a solid 85 version that you published that was still under (or very close) to 1K. Not sure what all you had done to it. I'll try to port it back and fix the issue you mentioned above. If that doesn't work I can go to the 13a version you mention above.
Regarding the newest FW you released: I didn't finish my SRK to test your new FW last night. I should finish it today and then I will report back.
I built up this light: tinywind ultrafire UF-T18, with a 219C on a 16mm Noctigon, using Richard's driver board: https://oshpark.com/shared_projects/acdEm3rR he posted here in post #163. It works great on a laptop pull cell @3.2V, works intermittently on a Panasonic 2800 mAh @4.15v, and doesn't work well at all on a SANYO GA @4.2v.
Quick review of UF-T18: nice compact 18650 e-switch tube light, it's a real UltraFire (driver is branded UltraFire), real SS retaining ring in the bezel, easy thread lock-out on the tailcap, body mounted side switch with 3 wires: grnd, switch, and bonus: RED LED in the switch! But the side switch is not so good - lot of force needed for the thumb, works ok on the tip of the index, or can use your finger nail, but don't think the rubber would last long on finger nail use. Bottom line: the switch is a killer disappointment without a fix, but I am not a side switch modder...
The problems appear to be the same issue I had in the other lights with the 22mm wight FET+1 driver, but now I don't have any zener pad available after the diode. I'm sure the problems have something to do with the low Vf, high amps of the 219C (5000K from Richard). I'll try piggybacking a 0.1 uF on the C1 cap, and see how it works. If it fixes the problem well, this may be the ultimate solution going forward for all 25/45/85 builds.
Richard's board design is pretty good, but using a SIR800DP, there is very little pad space to solder on the LED- wire to. A 22 AWG wire barely has enough to grab on to. I don't think a 20 or 18 AWG wire would be an option - no space, too tight against the resistors. I also have all 3 sizes of PD's DoubelDown drivers (https://budgetlightforum.com/t/-/35301, also post #202 here) - the LED- pad looks better, but haven't tried a board out yet.
Update: the piggyback 0.1 uF helped - tried a Pana PF and seems to work 100% where before it was failing, but on a SANYO GA, strobes don't work, unexpected blinks, etc. - same old problems. Maybe try another stacked 1 uF so I'd have a 10, 1 and 0.1 in the stack?
Boy, dunno... This light is a PIA to be experimenting on - desoldering wires from a sunken LED, 3 pt. soldering of the driver to the brass pill edges.. yuk . No time now - gotta assemble some furniture - my wife went shopping at IKEA...
I am a little surprised that the 0.1 uF made any difference. It really should be right up against the MCU to fulfill its purpose. It is standard practice to have these 0.1 uF decoupling capacitors VERY close to the MCU. We are fortunate not to have more issues with the layout of typical drivers.
In this case best I can recommend is to have a 0.1 uF straddle the MCU. Glue it diagonally to the top of the MCU and run leads/jumpers directly to pins 4 and 8. Pain in the butt for programming though.
Next best option is leave out D1, at the risk of frying the MCU when reversing the cell by accident. Re-use its pads to fit a bigger capacitor.
Did you try running at 4 MHz? That should also give you more room before brownout.
Sorry, really dunno the specifics or converting to 4 Mhz - suspect there'd be some testing. I'm gonna try the piggyback 0.1 cap now. Dunno what glue to use (?) - might just have to suspend it. Thought super glues were NG for this stuff - not sure... Again, I'm not so used to this experimentation and not set up well for it.
Sorry I didn't get any testing in yet. This damn Kung is kicking my arse. One problem after another every time I work on it.
No prob - ImA4Wheelr
DEL - that dang little cap across the MCU worked !! At least so far. Before on a SANYO GA strobe didn't work at all, and now it's working flawlessly so far. Accept the dang thing gets so hot so quick. I'm using 22 AWG LED wires, added spring bypass's on the tail spring and in a tiny driver spring I added - original driver had no spring at all.
A pic of the UF-T18:
Here's the driver in it's final/current version:
Here's the driver spring w/bypass (used a 26 mm wire in there - very short):
At the tail, I got 6.3A with the GA cell - crazy #'s, but with the 219C 5000K, I'm getting about 1,000 lumens out.
Note: Both added caps above are 0.1's, but, one is 50v rated (square on the MCU), and the thinner one must be a lower V rating, but not sure what it is.
I'm thinking we need a board design with a 0806 pad for a cap that gets + after the diode, close to the Vcc MCU pin #8, and either goes to a strong grnd, or gets to a ground close to the grnd MCU pin #4.
I dunno how it would fit on a 17mm board with the wide pads for a 45/85, but, thinking this will be the ultimate solution - using a 0.1 uF cap, or thereabouts.
I also would love to have pin #3, the spare I/O pin wired to a pad for a secondary switch, or ON/OFF LED output. I think the MCU pin #3 can work for that.
Any takers? PD68? RMM? pyro1son?
FWIW, I finally merged in Tom E’s eswBrOutCfg project.
Also, I’m still eager to hear about further developments on the issues you see on strobes and other sudden flashes. The cap over the MCU is interesting; I wonder if it could be placed somewhere directly on the board or if perhaps some other solution might work better.
Now I’m really confused. I think I’ve dropped the ball on this topic…
Wasn’t the conclusion that the cap should get + before the diode? Or are you considering one before and another after? Don’t most of the drivers have the cap + after the diode?
Leave it with me
10uf and 1uf caps?
If space was an issue, the board could use the SSU footprint and the cap be placed under the MCU. It would require the SU MCU package to be used and the pins to be bent in. When this is done, the MCU sits high enough to clear small 0805 caps underneath. Bent legs really make program clipping much easier.
Mike - yes. The large cap should remain before the diode, small cap after, at least that's what it's looking like. Think it gives us best of both. The test light continues to run smoothly. I got 3 lights now that had the problems and fixed now, all slightly different in cap values and placement, but all have a high value and low value cap, and the low value is after the diode.
The last driver, RMM's, is using a 0.1 uF cap, not 1.0 - DEL recommended the 0.1, though might not make much of a difference (I think).
Edit: that may be a viable option bout the bent pins technique. I am a bit concerned though bout the soldering of the MCU pins - certainly not as robust as when they lay flat on the pads, normally. I've done a few though and plan on doing more, and seems to be holding up well, but usually have to touch up a pin or 2 by hand after reflowing.
