MH27 looks quite interesting. Count me in.
Names added. #BGB.
Sign me for the MH27
Budgets are stretched but a must have light!!!
Interested in the MH27.
List updated.
I’m in for the MH27.
Thanks
Thanks
Daily list update. Price will depend greatly on the number of participants so keep them coming!
FINALLY!! They are here today!
Edited
Did a quick measurement just now. Model A registered 3.3A with 18650VTC4, which is 0.2A higher than my MH20. Output would be higher with 2xCR132A according to specs.
Note: my measurement is usually at the lower end compared to the other fellow members.
Wow, nice !
Cool! I want to see you open them up. Please?
Mainly I want to know:
- Is it glued up tight or easy to get into?
- Are the driver and charging circuits distinct from each other?
Bezel is not glued for B. I managed to remove it with the lens. Reflector did not came off as it was held down by black o-ring. LED should be accessible but I stopped at that point because I did not want it to be scratched by mistake or contact with dust.
It could be different... cos I got different readings between A & B (to be confirmed later).
As for the clip, it fits perfectly with SF and even Convoy S2+ without modifications(kind of over-sized).
Thanks Freeme!
I already ordered a clip because I was hoping it was smaller than the normal convoy clip, but it still looks like a very nice clip.
I got my two ec-r16s yesterday. Looks like the plastic disc for reverse polarity protection means you need button tops. Flat tops won’t work. Kinda a bummer, because I wanted to use the 18350s I already had.
One light seems to work okay with my red efest 18350 flat top. The disc is a little loose on the other, so no dice on that one.
I just ordered yet another 18350. a purple efest button top. I figure I can also use it with my blf a6 shorty tube.
The light that begrudgingly works with the flat top is nice. I gave it to my wife. She really digs it. It’s stupid bright for the size and price. The tint isn’t too blue, and it charged the battery to exactly 4.2v. I used my android phone charger. Lol!
Let’s hope the other one works with the button tip on order.
Consider my interest expressed in the BOSS
Freeme, thanks for adding my name to the list.
In case I forget, I may need a poke when it comes time to pony up.
Can I get the info on A,B,C and D please?
Definitely interested in the BOSS1. Will need to see a sample sent to an appropriate party to verify quality though.
I’m interested BOSS1.It would be possible with OP reflector?
